Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Closed Thread
Old 08-13-2012, 11:42 PM   #7676
waltah
Member#: 317856
Originally Posted by kyletakahero View Post
What color car do you have?
Lightning Red
waltah is offline
Old 08-13-2012, 11:48 PM   #7677
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
xluben is offline
Old 08-14-2012, 12:55 AM   #7678
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
^heat issues?... good choice though
FLEX'N WRX is offline
Old 08-14-2012, 01:23 AM   #7679
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Not really. Just thought it would be a good idea after a heat wave came through.
Looks like your is installed a little off to the side. The wastegate arm cutout isn't lined up right.
And how do you mount your heat shield without the bracket?
xluben is offline
Old 08-14-2012, 01:46 AM   #7680
Supawrx11
Member#: 287591
2012 sti
Obsidian Black Pearl
Supawrx11 is offline
Old 08-14-2012, 02:06 AM   #7681
Jdmoon86
Member#: 283328
2011 SWP WRX 4-door
TorquedPerformance Stage2
^ THat is a sick car....
Jdmoon86 is offline
Old 08-14-2012, 02:39 AM   #7682
FLEX'N WRX
Member#: 163672
GV
I'm sure that's why the cutout is larger than the arm... To accommodate positioning. The bracket for the PW TMIC has the heat shield attached. Dual use of the bracket... Tight fit, that's why the cutout is slightly left in comparison.
Old 08-14-2012, 03:22 AM   #7683
FLEX'N WRX
Member#: 163672
GV
and the spotter
Old 08-14-2012, 03:27 AM   #7684
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
Originally Posted by Supawrx11
Can we trade cars? Lol. You are doing it right, good sir.
Black07STiGuy is offline
Old 08-14-2012, 10:30 AM   #7685
Smitty33
Member#: 270048
2011 WRX Sedan (DGM)
Stage 2 (Bren Tuned)
Originally Posted by FLEX'N WRX View Post
Are you running the stock turbo with the Process West? I keep going back and forth about what intercooler to run...
Smitty33 is offline
Old 08-14-2012, 11:44 AM   #7686
The Duke
Member#: 264877
and the spotter
What gauges are those?
The Duke is offline
Old 08-14-2012, 11:59 AM   #7687
Improbus
Member#: 278439
2011 WRX 411HP/406TQ
1997 Legacy Outback EJ25
I believe they are the standard SPT Gauges directly from Subaru. I'm not sure if the mounting hardware is the SPT mounting hardware though. They appear to be mounted to the steering column and they look pretty good. Some more shots from the drivers perspective and how they were mounted would be awesome. Did they every fix that electrical issue in the SPT Boost Gauges ?
Improbus is offline
Old 08-14-2012, 12:26 PM   #7688
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
They aren't SPT gauges. Not sure on the brand though.
rmj is offline
Old 08-14-2012, 12:37 PM   #7689
FLEX'N WRX
Member#: 163672
GV
Decide between TMIC/FMIC first. If you're certain about a TMIC, it's the best option available.
They are Subaru gauges, but definitely not SPT. Quality is superior to SPT thanks to DEFI. Ive had them for almost a year and never issue. They're in the SMY cluster.
Old 08-14-2012, 01:39 PM   #7690
Laexreme5
Member#: 315264
2012 WRX
Where did you get them?? They look fantastic. I'm trying to stay to the Oem look as possible and I love that they say Subaru in them
Laexreme5 is offline
Old 08-14-2012, 01:46 PM   #7691
Improbus
Member#: 278439
Probably here:
Japanparts.com Parts Manufacturer: Subaru Parts Name: METER SETS
They are 62,700 yen which is about $795.48
If they are in fact just DEFI Red Racer 52mm Gauges you can buy the American equivalent manufactured by DEFI for much less. Around $450-$500 for both.
Improbus is offline
Old 08-14-2012, 02:24 PM   #7692
dankdisciple
Member#: 313664
@Supa: I'm sure that you've answered this many times, but save me the searching for it please? What lip you got there?
@Everyone: My DGM '12 is still bone stock, and im in no hurry as its my DD grad present to myself, but apart from engine upgrades, whats a good order for mods. Tints next week, thinking that maybe the coilovers first? then wheels then exhaust? Or a build order link would be much appreciated also..
dankdisciple is offline
Old 08-14-2012, 02:42 PM   #7693
Improbus
Member#: 278439
Black Aero Type VR Carbon Fiber Lip
My opinion of build order:
1.) ACCESSPORT ACCESSPORT ACCESSPORT - hands down best $600 Investment for your vehicle.
2.) Pick What's more important to you. Go Fast Pew Pew time, or go bling bling purdy times.
If Fast Pew Pew Time:
3.) Grab A Downpipe
4.) Grab a Decent 3 inch Cat back.
5.) Grab an intake if you like whoosh sound but won't really create a huge performance boost until higher Horsepower.
6.) Custom Tune and be happy time
7.) Sky is the limit. Bigger Turbo, electronic boost controller, bigger TMIC, or FMIC, headers, over 22lbs of boost new By Pass Valve etc...
If go bling bling purdy time:
3.) Tint/overlays if you like them
4.) Good set of coilovers if you like adjustability or a good spring/shock combo to address some body roll and handling plus less wheel gap.
5.) Wider Wheels with some meat for some more rubber contact.
6.) Lip Kit if you are into that kind of thing.
7.) Sway bars maybe if you like it a bit stiffer.
8.) Engine Bay Dress up. Radiator Shround, pulley cover, Bigger Turbo Heatshield
8.) Sky is the limit after that.
The reason I split this up was in my opinion its easier to stick with one area of a project and complete it and then move onto something else than trying to do everything at once. Also, set aside a budget that you are comfortable spending on modding your car. Are you looking to spend 4K, 10K, 15K? This all should be factored in. Remember even though you love your car the likelihood of getting the money out of it that you put in is unlikely so make sure you are comfortable about what you spend on it because you won't see that money again most likely. Also remember modding your car comes with the standard "You Pay to Play" if you buy cheap parts, don't install them correctly, or mistreat the vehicle and it goes boom its on you and no one else. Sometimes Subaru is cool and will fix it and sometimes they tell you you are **** out of luck. I would take a month or two sit down get a budget together and do your homework before you start any kind of modding. It will help you decide on a plan, direction, look and it will come together more appropriately. This of course is all my opinion.
Improbus is offline
Old 08-14-2012, 02:46 PM   #7694
_davin
Member#: 260501
2003 miata SE
Blurple
I think sway bars, coil-overs and meatier tires should go in a third handling category.
And the cat-back is really just for noise.
_davin is offline
Old 08-14-2012, 02:50 PM   #7695
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
lies
Celery GT-5 is offline
Old 08-14-2012, 02:57 PM   #7696
arod15
Member#: 304906
2015 STI
CWP
Would personally save tons of money and get a tactrix cable with a TP tune.
arod15 is offline
Old 08-14-2012, 02:57 PM   #7697
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
I would maybe say it's the most "convienent" investment.
INKMAN is offline
Old 08-14-2012, 02:57 PM   #7698
aznh0f00l3on
Member#: 236867
2011 STI
CGM
Anyone feeling the carbon trunk wing combo?
aznh0f00l3on is offline
Old 08-14-2012, 03:00 PM   #7699
Improbus
Member#: 278439
Originally Posted by Celery GT-5 View Post
lies
While I do agree there are other just as good, cheaper options, the Cobb provides as INKMAN has said the most convenient solution to someone new in the game. The plug and play ability is nice. The ability to flash back to stock. Plus in my opinion its easier to find someone who can tune via cobb than it is to find an open source tuner.
Improbus is offline
Old 08-14-2012, 03:02 PM   #7700
FLEX'N WRX
Member#: 163672
GV
^This post reeks of laziness...
Improbus seems to have been designated 'question answerer' of this thread
Any of you have pics to include?
Closed Thread
('11-'14) 2011-2012 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 151 04-29-2014 09:35 AM
01-07 wrx and sti drivetrain? xj bmx Newbies & FAQs 13 01-26-2012 04:30 PM
('11-'14) 2011 wrx/sti picture thread (for real this time) guamanian_powered Impreza Forum 1 11-17-2011 12:51 AM
Anyone have the 06-07 Impreza WRX and STI master part number and picture list STEALTH-WRX Interior & Exterior Modification 0 08-22-2008 03:12 PM
The Official World One STI and SEMA picture thread.. WorldOne Member's Car Gallery 25 11-29-2003 06:21 PM
