Welcome to the North American Subaru Impreza Owners Club Friday January 19, 2018
Old 12-30-2013, 11:06 PM   #76
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Originally Posted by endleesss View Post
I think i got a lemon, CEL P0011 and P000A. on 9/26/13 Dealer then moved intake oil control valves from left to right and cleaned the codes. 2 days later. 9/28/13 today, i got another CEL now, code P0000. 26 days of owning a brand car, 2 CELs this subaru is a piece of junk!
wonder what yer clutch looked like
Old 01-21-2014, 12:17 PM   #77
vaughnsubi
Member#: 377301
2013 Impreza WRX Ltd
Metallic Silver
Apparently this wasn't covered under warranty as it was a spider inside the emissions filter which the local dealership charged $214 to wipe off.
vaughnsubi is offline   Reply With Quote
Old 01-21-2014, 12:21 PM   #78
vaughnsubi
Member#: 377301
Metallic Silver
Originally Posted by Supraru View Post
Yes you're still under warranty. Haven't you read through your warranty information you received when you bought the car?
Unfortunately, it wasn't covered--"act of nature"--charge was $214 to remove a spider's cocoon from the emissions filter.
Old 01-22-2014, 08:53 AM   #79
Supraru
Member#: 23313
99' 2.5Rs
black
Hmm that sucks. When we clear out spider condo's it completely under warranty. Even if it comes back with a new web it's under warranty. I would call Subaru on that and question the charge. Maybe we good will it or something but asking doesn't hurt. Not only that but the spider condo on the new wrx isn't the same as ones in the past. It can still cause a code but it would have to be a pretty good web in there which I've rarely seen but I'm sure I could happen. Hopefully it stays away.
Supraru is offline   Reply With Quote
Old 01-30-2014, 01:12 PM   #80
cookies12345
Member#: 380247
Default Could it be that I need 5.5k work on cylinders???
The car runs fine, though it's gas mileage has slipped a bit recently. 24.3 to 22.6, but temps been in the single digits when I drive in the am. 2008, 105k miles, I bought it in 2010 with 50k, wrx turbo, stock all. Don't drive it really hard, though I enjoy what it can do.
cookies12345 is offline   Reply With Quote
Old 01-30-2014, 01:25 PM   #81
Wrbboost
Member#: 362505
I've been having these lights come on for awhile. I recently changed my headunit and of course had to disconnect the battery, and ever since then I haven't had any lights come on. so I would recommend trying that, couldn't hurt
Wrbboost is offline   Reply With Quote
Old 01-30-2014, 01:28 PM   #82
cookies12345
Member#: 380247
I will. It's sitting at the dealer now while I decide what to do. Still owe 8 grand on it too. Sigh. I'll try resetting it.
Old 02-01-2014, 08:04 PM   #83
esan6
Member#: 201361
09 Impreza
Default Same issue 09 Impresa 2.5i
I just did a spark plug and wire change on the car. I also replaced the air filter. When I started the car I got those same lights. I will check the plug on the mass on the air filter to see if it will fix it. All I know is that the car is running worse than prior to the tune up.
Do I need to reset the computer? YES I DO> I disconnected the ground on the battery and held the brake down for about 25 seconds. Reconnected the battery and started it up, lights are cleared and car running fine now.
Also, for those that do not know. If you get a check engine light the traction light will come on and the cruise light will blink this is normal for the Subaru.
esan6 is offline   Reply With Quote
Old 04-07-2014, 11:04 PM   #84
tonnguyen
Member#: 298928
2011 Subaru WRX
Cobb downpipe and Invidia Q300
Cobb OTS stage 2
This happened to me a couple nights ago. I went WOT through 2nd and 3rd and at the top of 3rd gear I heard what sounded like afterfire. I looked down at my dash and noticed the check engine and traction control lights were on, as well as my cruise light flashing. The car didn't seem to be in any kind of "limp" mode. It was driving normally.
The next morning, I tightened the gas cap as some on this thread suggested. Didn't really seem to tighten since it just kept clicking. But that did the trick! All the dash lights returned to normal when I started the car.
I'm not too sure of the exact reason it happened in the first place as after fueling, I always turn the gas cap 360 degrees after the clicking starts. But I did realize that I was low on fuel (probably drove about 10 miles after the gas light had turned on) and it was about 45 degrees F out the night it happened.
Just thought I would share
tonnguyen is offline   Reply With Quote
Old 08-25-2014, 12:41 PM   #85
Jaymee63WRX
Member#: 399913
2013 Impreza WRX
Default Check engine, traction, blinking cruise
I just had the same issue. Did a little research, tightened my gas cap, but went ahead and dropped off at the dealership to check it as it is only a couple of miles from my house. It was in fact the code for a loose gas cap. They reset the codes to turn them off. So its ready to pick up at no charge.
If I had driven it a bit longer would they lights have gone off I wonder??
Jaymee
Jaymee63WRX is offline   Reply With Quote
Old 08-25-2014, 01:23 PM   #86
Supraru
Member#: 23313
99' 2.5Rs
black
Jaymee
Well when the light comes back tell them you'll save them some time and tell them to order an engine harness.
Old 09-21-2014, 01:04 AM   #87
amananderson
Member#: 258459
Default Had same problem!
Man i'm so grateful for NASIOC! I nearly freaked out, all the lights came on and the bilking cruise light, I didn't know what to think. I'll try the gas cap fix in the morning, if not I'll take it in since it's still under warranty.
amananderson is offline   Reply With Quote
Old 12-04-2014, 04:33 AM   #88
blackhemiwrx
Member#: 406795
2011 WRX STI
Pearl White
Default mine came on
mine came on just cruising around, tightened gas cap and filled my tank as it was halfway, was due for oil change and decided to get one done , still light did not go away, called dealership and set up appointment and asked if ok to drive around with check engine light and gave me a go ahead. check engine was still on at this point ,drove for a lil bit after and went WOT getting on the highway in 3rd and fourth and next thing i looked down and light was gone
next step cancel appointment lol
blackhemiwrx is offline   Reply With Quote
Old 12-29-2014, 02:08 PM   #89
biifar09
Member#: 409593
Default p0852
Hey so I'm reading through this and I'm getting the same thing (sort of) I went to advanced and I got the code p0852. Happened to me when I was driving fairly hard but nothing extreme I would say. Also can advance clear the codes to see if it won't come back on or would it go off on its own if the gas cap was fixed? If anyone has any advice about this code that I'm getting I'd really appreciate it.
biifar09 is offline   Reply With Quote
Old 12-29-2014, 03:16 PM   #90
Supraru
Member#: 23313
99' 2.5Rs
black
You have to get the evo gas cap upgrade or else the code will come back.
Old 12-29-2014, 03:19 PM   #91
biifar09
Member#: 409593
Are you serious? Evo gas gap upgrade that's a thing? I feel like your screwing with me
Old 12-29-2014, 03:26 PM   #92
Supraru
Member#: 23313
99' 2.5Rs
black
Yes I am. All you people really need to stop thinking because your cel is on it means your gas cap is loose.
Second you went a step farther then most here and actually pulled the code. Now search the code and see what it is telling you is bad.
Third your asking questions and don't have your car info filled out. For all we know you Vance a Chevy cavalier.
Old 12-30-2014, 08:44 AM   #93
Uncle Scotty
OK buy Nates beans
if that code is correct---this is VERY IMPORTANT
then the gas cap wont matter a bit
and I find it IMPOSSIBLE.....TOTALLY impossible that people in 2015 have not figured out how to use the ****ing internet to find such easy information out about things
im just ASTOUNDED that these things continue to be any sort of issue at all
Old 01-04-2015, 02:13 PM   #94
legacyboy
Member#: 408121
2012 Legacy GT DIT
JDM
following with interest. mine did the same thing but has electronic park brake light on along with blinking red key ... let's see what the dealer says
legacyboy is offline   Reply With Quote
Old 04-22-2015, 06:23 PM   #95
whatisboom
Member#: 380631
2012 WRX
Black Pearl
Not the worse thread-necro ever, but I'm getting the lights, but no codes when I read it with my accessport. Anyone seen that before? I've reset the ecu a couple times and it has come back a few days later. I'm going to try and go easy on it to see if it might be overboost problems, but i find it weird there are 0 codes every time it happens.
whatisboom is offline   Reply With Quote
Old 04-23-2015, 03:34 AM   #96
Uncle Scotty
OK buy Nates beans
AP isn't a real code scanner....get the codes read with a real scanner
post the codes....the verbage is irrelevant
Old 04-26-2015, 10:16 AM   #97
02Rone
Member#: 349556
2013 WRX Premium
Had this happen this morning, searched the forum, then put my gas cap on....I'm an idiot
02Rone is offline   Reply With Quote
Old 11-25-2015, 11:20 AM   #98
SPinnerguy
Member#: 393704
2017 WRX
It was the gas cap for me. THANKS!
SPinnerguy is offline   Reply With Quote
Old 01-13-2018, 07:13 PM   #99
Forums 12
Member#: 480561
Default Subaru Tribeca 2012 3.6l check engine light cruise control flashing traction control
Originally Posted by cobler19 View Post
I started my car today and noticed the check engine light and traction control off lights were on while the cruise control light was blinking, but there wasn't any whining noise or anything. The car is a brand new 2011 WRX with only 270 miles on it...obviously it needs to be taken in, but what could cause a problem like this in such a new car?
It is the mass air meter on top of the air intake tube connecting out to the air box.
Most likely a lose, open or short.
Jiggling the wires should cause the fault lights to clear on the next restart.
Turn engine off, jiggle wires/ reseat connector, restart and the fault lights will be extinguished. Hope this helps !!
Forums 12 is offline   Reply With Quote
Whining noise, check engine light, Traction Control, Blinking Cruise jcoble Newbies & FAQs 21 05-14-2011 01:52 AM
09 Impreza - CEL and Traction Control light, blinking Cruise Control CrotchMonster Service & Maintenance 4 10-17-2010 04:38 PM
Blinking Cruise Control, CEL, Tire Pressure, AND Traction Control Lights ALL on The Database Electrical & Lighting 5 03-14-2010 04:32 AM
Check engine, traction control, cruise control lights tantric rex Service & Maintenance 0 07-08-2009 09:33 PM
Already get CEL, no traction control light, and blinking cruise control! Shohin Newbies & FAQs 17 02-04-2008 02:08 PM
