Welcome to the North American Subaru Impreza Owners Club Tuesday August 3, 2021
Old 10-18-2007, 09:27 AM   #1
IllNastyImpreza
Member#: 36333
98 RS
GT30R, closed deck madnes
Default Where does my knock sensor go ???
ok I've got my entire engine back together !
I finaly cranked it up last night (no exhaust at all )
But I've got my knock sensor just grounded to the top of the motor (only ran for about 3 seconds)
I need to put the knock sensor back where it belongs... can someone place fill me in here. Thanks !
IllNastyImpreza is offline   Reply With Quote
Old 10-18-2007, 09:51 AM   #2
shaw169
Member#: 120088
2001 Z3
Search a bit for more:
shaw169 is offline   Reply With Quote
Old 10-18-2007, 10:25 AM   #3
IllNastyImpreza
Member#: 36333
98 RS
where is that diagram from ?
thanks !
Old 10-18-2007, 10:33 AM   #4
shaw169
Member#: 120088
2001 Z3
club wrx, thread on knock sensor location. Pic originally probly out of one of the manuals.
Old 10-18-2007, 10:43 AM   #5
IllNastyImpreza
Member#: 36333
98 RS
cool.... must be a newer style motor than mine...cuz I only have 1 cam sensor... and its on the front driver side
I'm throwin the knock sensor in the right spot now.... thanks!
Can't wait to get her up and running !
Old 10-18-2007, 01:36 PM   #6
SAIKOU
Member#: 92718
04 WRX 2.5 Hybrid
torque it, i don't know the exact but mine is at 25lbs and works. anyone got the right value?
SAIKOU is offline   Reply With Quote
Old 10-18-2007, 03:43 PM   #7
afmardve
Member#: 57698
03 wrx
torque to 17.4 foot pounds. The sensor wire needs to be on a 60 degree angle relative to the rear of the engine. to the right.
afmardve is offline   Reply With Quote
Old 10-19-2007, 07:01 PM   #8
bboy
Member#: 56468
04 Improved STI
Dirty White
^^^Lots of people move it, but those are the directions.
Old 10-19-2007, 07:08 PM   #9
IllNastyImpreza
Member#: 36333
98 RS
does this really matter?
I'm having a problem getting her running right.
I start her up, and she runs PERFECT for about 3 minutes.
Then it starts bogging and bucking and spuddering, and the CEL comes on...
it does the exact same thing 3 times in a row(after I reset the ECU)
I thought it might have been a ground problem so I moved some grounds around... but to no use.
I would check the code, but my code reader doesn't detect alot of the Subaru codes
anyone have any ideas ??
where is the knock sensor on 03/04 impreza? qtr_wrx Normally Aspirated Powertrain 5 10-26-2007 03:23 PM
What does a Knock Sensor do? brianecarlson Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-14-2005 05:40 PM
Where is the knock sensor? SubaruGenki Normally Aspirated Powertrain 5 08-18-2004 12:07 PM
Where does my brake fluid go? Rusty the Scoob Brakes, Steering & Suspension 2 07-12-2002 02:17 PM
Where does my O2 sensor go? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 10 11-12-2001 03:31 PM
