![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 12558
Vehicle:2002 Impreza WRX Midnight Black Pearl |
![]() Ok.....
I've had the WRX for two months now, been searching around for wheel info because something just isn't right with the look of the stock 16x6.5 WRX wheels and RE92's. I've decided the car "looks" under-tired....the tires dont fill the wheelwells top to bottom and dont get close to the edge of the fender flares....Is the problem the wheel size, tire size, or a combination??? I'm looking for summer wheels, and want to get something that looks better, fills the car out a bit more and does something for the styling. I've got a set of new RE92s that I wanted to use (16"), but will consider other options. My only real concern with running a 17 is that I drive gravel roads from time to time (TSD) and Michigan roads are full of potholes, and I dont want to run a real low-profile tire/wheel combo that is succeptable to bending wheels at every turn. Will a Moda R2 16x7 with a 50mm offset look better than the stock WRX wheel (fill the wheelwells better) while not stressing front end components? Would '00-'01 RS2.5 wheels be better? Or, would I be better with a 17, and if so, who makes reasonably priced ones?? Thank you! Ben
#2 |
Member#: 7958
Vehicle:09 GH B+ |
![]() Scrappy,
The only two ways to fill the wheel wells top top to bottom is taller tires- not good choice- will effect your gearing negatively or lower your vehicle w/ lowering springs or coilovers. 16's would be a better choice for gravel (more sidewall) but if it's just occasional, a quality 17" wheel would more than suffice. Any wheel w/ a 5X100 bolt pattern w/ 48-53mm of offset will work and not negatively stress any suspension components. Tire width, you don't mention sedan or wagon, but if sedan several people are running 225/50/16 tires on the stock rim (7 or 7.5 width would be better though). RS wheels fit fine (they are 16X7). If your budget is limited tire upgrades will yield much more bang for the buck. The OE rim is actually a pretty good rim- strong, relatively light at ~ 16 lbs. Big Sky WRX |
#3 |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
![]() I just went to 16x7 wheels for my snows, and they do fill the wheel well out better than the 16.5s, for reasons that I have yet to be able to discern. They actually look like 17s. It's a pretty cool effect.
Note that I'm using the Fox 5s from Tire Rack, which are 50 offset. They aren't the lightest wheel, but for snow wheels, who cares? For your needs, I think a 16x7 wheel would do quite nicely, though a sturdy 17" wheel like the P1 would also fit the bill. Kevin |
#4 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
![]() like posted above, fitting some 225/50R16 tires to the stock WRX rims is a good way to go. The tires are about as big as you'd want to fit to the wheels so they look really meaty on there.
What are my best options for home defense shotguns? | Captain TinklePee | Off-Topic | 186 | 02-08-2009 11:53 PM |
What are my best options for getting rid of a bunch of ammunition? | MikeCee | Off-Topic | 65 | 12-16-2008 01:40 AM |
99 Impreza L with a 2.2, what are my 2.5 options with the least amount of wiring? | scobaru | Subaru Conversions | 18 | 06-05-2008 11:35 PM |
What is my best option with stock stereo? | speeddoc74 | Newbies & FAQs | 21 | 04-03-2008 11:11 AM |
College housing and loans, what are my best options? | kedrin | Off-Topic | 11 | 05-23-2006 12:23 AM |
