Welcome to the North American Subaru Impreza Owners Club Monday August 15, 2022
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-08-2022, 10:59 PM   #1
bobsagator
Member#: 457569
2004 Baja Turbo MT
Default Shifter Bushings
I need some help with the shifter bushings for the Baja. I got the Whiteline
Whiteline KDT957 Gearbox - Linkage Selector Bushing kit to get rid of the sloppy side to side action of the shifter. Installed today and still getting about 3" of lateral movement when in gear. Now I see there are more potential bushings to get for the linkage, see HERE for the four bushings that looks like are next on my list (two 35035A and two 35035F).
But then I find this linkage replacement with the statement that "The cars prior to this in that 1998 to 2005 timeframe have a linkage that is riveted together and cannot be serviced or upgraded." But per the parts diagram it appears that the bushings are replaceable.
So which is it? Who has successfully replaced either the Baja linkage bushings or full linkage? There is a considerable cost difference to getting the linkage if the four tophat bushings will work.
bobsagator is offline   Reply With Quote
Old 05-11-2022, 09:41 AM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Your halfway there. Replace the joint and bolt on the transmission shift rod. Just buy OEM - the bolt in that kit works on something - but NOT Subaru...
You need:
joint 35047AC030
roll/spring pin 633046020
nut 023508000
flange bolt 901000169
(all for 04 Baja)
Elbert Bass is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
