#1 |
Member#: 2173
South East
Vehicle:2005 LGT Wagon 5MT ABP |
![]() I have been looking into either the S-AFC or S-AFR. Do these units employ the O2 sensor to read and adjust parameters? If so, does it utilize one or both O2 sensors and will a CEL eliminator on the rear O2 sensor prevent the S-AFC (or AFR) from working properly?
Thanks- Robmat
#2 |
Member#: 2173
South East
![]() bump
#3 |
Member#: 27132
Vehicle:1999 2.5 RS-T Rally Blue |
![]() It does nothing with either O2 sensor. The S-AFC alters fuel by modifying the signal from the MAF or MAP sensor before the ecu. However, on a MY98-99, you can wire it up so that you can monitor the front O2 sensor voltage from the sensor check screen.
#4 |
Member#: 2173
South East
![]() Thank you
How to extend o2 sensor without wasting 30$ on extension? | Un0RiGiNaL | Normally Aspirated Powertrain | 21 | 05-16-2009 04:45 PM |
Is this guy distantly related to the Bushes? | Coati | Political Playground - Chaotic Neutral Edition | 6 | 10-28-2005 05:35 PM |
Fairfax county's "finest" is at it again. *relates to the Loudon Co Wings inccident* | Valhakar | Mid Atlantic Impreza Club -- MAIC | 74 | 12-02-2004 03:54 PM |
what is the part number for a rear o2 sensor? | Homemade WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-01-2004 07:31 PM |
how to install O2 sensor, fuel filter and air control valve | Suladed | Service & Maintenance | 4 | 11-11-2001 09:30 PM |
