Welcome to the North American Subaru Impreza Owners Club Monday June 18, 2018
Old 12-20-2012, 12:43 AM   #1
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Default wrx axles, sti hubs?
So working on my midi design. I have my ej22t at the machine shop getting checked, s20 heads came in, got my front spindles over the weekend.
Anyways....
I have a 5mt out of a 2001 Forester. I'm going to make an adapter out of the center diff to make it into a fwd. It's going to need a front lsd. So I'm trying to decide on axles and knuckles/hubs. My current plan is to use wrx female axles and sti 5x114.3 front hubs. I believe they are both 27 spline and the same diameter. This way I will have cheap replaceable axles (and easy to get quickly).
The car will only weigh <1500lbs and will probably be traction limited, so I'm not super worried about the tranny.
So does that combo sound feasible?
SurfWagon is offline   Reply With Quote
Old 12-20-2012, 02:54 PM   #2
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
04 STI had axles with female inner ends and will connect to the 5mt. And they will also fit in the 05 STI 5x114 hubs.
jake
KONKILR is offline   Reply With Quote
Old 12-20-2012, 03:16 PM   #3
pillarguy17
Member#: 103392
you are good on the 5x114 spindle and bearings to wrx outer cv
not sure about the trans side of the swap
if you need abs to work (not sure what kind of car your building), check out the lic motorsports tone ring adapters
pillarguy17 is offline   Reply With Quote
Old 12-20-2012, 05:43 PM   #4
suberdave
Member#: 101865
88 GL-10 STi
check out http://subarugears.com/Products.html for the spool you will need. i tryed welding up my center diff for FWD in my Mid Engine Coupe. but blew it out twice in a few hundred miles. now i have this subaspool and have not had any issues as of yet.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-20-2012, 09:58 PM   #5
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Thanks for the help
Been trying to decide whether to attempt to weld my own or buy one. Where did yours break?
Old 12-24-2012, 03:11 AM   #6
suberdave
Member#: 101865
88 GL-10 STi
at the welds. if you use the stock splined parts, they are hardened steel. they have to be heated up to weld, and they do not leave much room to weld.
if i were to do it again, being towed twice (even with AAA), is not worth saving the cost of the billet part.
-=Suberdave=-
Old 12-26-2012, 11:25 AM   #7
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Valid point!
Old 12-26-2012, 03:53 PM   #8
elysiumplain
Member#: 341671
Default yep
-=Suberdave=-
x2 this^
elysiumplain is offline   Reply With Quote
Old 01-07-2013, 11:37 AM   #9
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
does anyone know if there is any difference between the sti 05-07 front hubs and the 08+
Old 01-09-2013, 11:28 PM   #10
02rsti
Member#: 343114
2002 subaru impreza
metalic black
i will like to know the same i got a 08 sti swap and trying to put in into my 02 rs and i got 08 axels and everything ...
02rsti is offline   Reply With Quote
Old 01-10-2013, 11:44 PM   #11
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
I believe they are the same. Saw a thread of someone using 08+ assembled hubs on 05-07.
