Welcome to the North American Subaru Impreza Owners Club Saturday September 22, 2018
Old 06-03-2010, 03:51 PM   #1
2_Liter_EJTurbo
Member#: 145084
1995 Impreza LSTI
Default TD05 Evo III 16G
So i have been thinking about getting an evo 3 16g from blouch for my 20k wrx. I was thinking on putting some sti 550 injectors in, swapping the turbo and getting my ecu re-flashed to run properly. Eventually I will get a standalone unit and have it professionally tuned most likely at PDX Tuning.
Is this a bad idea with out building my lower end first? I really don't want to pop my engine. Thoughts, suggestions?
2_Liter_EJTurbo is offline   Reply With Quote
Old 06-03-2010, 04:49 PM   #2
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
you should already have 550 injectors...the car should be fine with a tune unless you wanna push 18+psi daily
Cbgrandtheftauto is offline   Reply With Quote
Old 06-03-2010, 04:52 PM   #3
luka
Member#: 194742
1993 Impreza WRX JDM
Has anyone put in an EVOIIIB16G on an EJ20G? I'm assuming you can either
1) run a silicon 90 bend or
2) intake manifold spacers and go underneath like suberdave?
As for your question... I plan on doing the exact same setup and running the car to the ground. BUT, I do have a spare shortblock at my disposal when that happens so downtime will be minimal (hopefully).
it will also depend on how hard you plan on beating that motor... boost levels?
luka is offline   Reply With Quote
Old 06-03-2010, 08:10 PM   #4
2_Liter_EJTurbo
Member#: 145084
1995 Impreza LSTI
My 20k is rocking a td04 stock turbo with what i have been told are 440 cc injectors. I also was just introduced to the FP 68HTA... Now I get to research this turbo...
But as far as how hard I would be pushing my engine/turbo is going to be based on how much the stock bottom end. Even if I run the stock 14.7 psi it will still be flowing more air into the engine.
Old 06-05-2010, 12:51 AM   #5
RHD 93 STi
Member#: 241290
2004 Forester
JBP
hmm. has anyone tried a quick 90 inlet... if so, whats the result?
RHD 93 STi is offline   Reply With Quote
Old 06-06-2010, 09:38 AM   #6
rs182
Member#: 197511
1999 2.5RS
if your stock turbo is a tdo4 what you have is a late 20g not a 20k. You will def. need bigger injectors for a 16g. Keep in mind these motors are 9:1 so tuning is pretty critical and you can not run as high of boost
rs182 is offline   Reply With Quote
WTB: 16g, big 16g, or Evo III 16g bcWRX-02 Private 'Wanted' Classifieds 17 08-28-2008 02:40 AM
WTB: EVO III 16g or TD05 18g nukka-cp Private 'Wanted' Classifieds 7 04-11-2008 08:02 PM
want 16g or evo III 16g turbo mmmRex21 Private 'Wanted' Classifieds 1 04-10-2008 07:49 PM
Application 02wrx: Ported FP 16G vs FP EVO III 16g ezzzey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-07-2008 02:28 PM
which do i get? EVO III 16G vs 16G vs TDOH5 16G subbiedo04 Newbies & FAQs 21 01-14-2007 06:49 AM
