Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 07-28-2010, 12:31 PM   #1
ToneWrx02
Member#: 239095
2002 Wrx
Default Question bout injectors and topmount intercooler and more
So I can get my hands on helix injectors new for 200$ 820cc.
I've heard that they have some issue bout itment and idling. But
all those issue came from sti side feed people. Will i have the same issue with them? On my 2002 Wrx? Will 820cc be enough to run ethanol? Or they not big enough..?
I found a top mount intercooler.. I don't have enough money for a better one
.. Cause I'm purchasing tactrix cable and the wideband kit with gauge.
Anyways my mods are built block 2.0L Je pistons 8.5:1 comp ratio
eagle rods, stock heads.. For now.. I may build them or il just cam it most likely.. Vf30 turbo. Down pipe uppipe, catless, sti exhaust. The the rest of my mods are act flywheel and clutch.. Short shifter.. And other stuff.
I will upgrade turbo later in a few months. But will that top mount and the injectors be a good combo? Will I be able to run ethanol..?
http://www.cxracing.com/mm5/merchant...=IC0004-Y-PIPE
ToneWrx02 is offline   Reply With Quote
Old 07-28-2010, 12:48 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
820cc should be more then enough room for e85 with the vf30 so i wouldn't worry about that!
The IC will be better the the stock 2.0 top mount but a lot of people will tell you to go with an sti IC if you're looking for a cheap solution. The one you're looking at will work just fine but the sti will cool just as well and you can usually get them cheaper.
Mike
GrimmSpeed is offline   Reply With Quote
Old 07-28-2010, 12:59 PM   #3
ToneWrx02
Member#: 239095
2002 Wrx
Mike
Awesome info. Il look for a sti top mount but I havnt been able to find a good deal. The reason I'm going cheap on intercooler is because I moved away and my parents let me borrow there honda pilot. And they need it back asap, my Wrx block is done and getting out together. And il be going back to do fi USB touches like tune and injectors and intercooler. I have 3 weeks I'm working 32 hours overtime. So that's 78 hours I'm working a week. Killing my self.. Anyways my next check will cover my rent and phone bill. Then the next check will cover the tactrix and wideband and gauge setup, it will also cover the injectors.. Check after that will be about 600$ so then 200$ go aside for gas to travel home and back. 300$ go to intercooler, the rest is for food. I may hit 700$ in my check.. But yea I'm being rushed or else I would get a AMR intercooler. Well if anybody has mre info bout helix injectors and how they react on a Wrx let me know. Can't wait to run e85 hehe. Well I'm off to sleep then back to work.. And I just got off work..
03 stock parts only 25,000 miles on parts turbo,tgv's,injectors,intercooler,and more jeremywrx15554 Engine/Power/Exhaust 9 05-25-2009 04:18 PM
Fs Socal: Wrx Parts Blitz Exhaust Pwr Topmount Intercooler And Various Intakes bumbfro Engine/Power/Exhaust 1 02-08-2009 06:57 PM
Utec, UniChip,Stock-Injectors,Turbo,intercooler and more devinmaier Engine/Power/Exhaust 8 02-16-2007 03:14 PM
FS - Stock wrx injectors, fuel pump, intercooler and bypass valve Eraz3r Private 'For Sale' Classifieds 5 04-12-2004 11:23 AM
FS: Wheels and tires, Intercooler, and rails jwrx South East Region Forum 3 09-23-2003 10:22 AM
