Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 12-02-2012, 06:06 PM   #326
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Originally Posted by SpicyPeaNut View Post
Thank you for making the already clear info, crystal clear. I want to be sure I have no questions before I rip my brand new car apart
no problem dude. take pics and post a review. help others.
good luck and let us know how it goes. i hear you on molesting a perfectly good subaru.
ChesterWRX is offline   Reply With Quote
Old 12-02-2012, 06:09 PM   #327
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
ETA: did you buy fuse taps?
that was the most confusing part for me because the lines on the Defi gauges have an inline 3a fuse. so i was really confused about using the double slotted fuse taps with a second 3a fuse.
so in the end, you remove the fuse for power and illumination and insert the double slotted fuse tap. but the regular fuse on one slot to re-complete the circuit and a 3a in the second slot.
i got my 3a fuses at Radio Shack and the fuse taps at Advance Auto.
lots of fail vs. running around. but it was fun. wasting gas and what not.
Old 12-03-2012, 02:01 AM   #328
scx89
Member#: 269388
2011 Impreza WRX
obp
Just installed the same combo! thanks for all the info
A few things I had trouble with
You need add-a-circuit fuse taps, they're expensive
The alternator was a bitch to remove
Here were my steps:
1) remove cover
2) Loosen (a couple turns) alternator hanger bolt (on the right side of the alternator where it allows it to swivel
3)Take off tensioner bolt (it's a bolt parallel to the floor and connected to the tensioner bracket.
4) Take off the tensioner bracket bolt
5) Take off the alternator hanger bolt
6) Take the alternator out by pushing forward and pulling back, kind of a rocking motion towards the left. (put in the same way)
I routed the wires through the driver side fender with the wheel on (i just turned it for more accessibility). I took out 2 of the fender well plastic push ins and one Phillips head push pin. I stabbed the grommet on the top where there wasn't any wires so it was easy to sort out.
You have to choose a really good place to ground and the area I used is to the left of the fuse box. I opened the door and pushed in from the fuse box area to pop out the plastic covering. You'll see a good spot there.
scx89 is offline   Reply With Quote
Old 12-03-2012, 12:54 PM   #329
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
I'm pretty sure this has been asked before but I couldn't find it. One the fuse taps, which location replaces the stock fuse and which is the add on for the gauges. Is it the slot closest to the panel when plugged in? I used the same one for both slots but finally found some 3 amp ones that I want to swap in.
Thanks guys!
jester8798 is offline   Reply With Quote
Old 12-03-2012, 01:01 PM   #330
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Thanks guys!
This worked for me.
http://i1058.photobucket.com/albums/...ps6d253cdc.jpg
Old 12-03-2012, 01:09 PM   #331
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Sorry, I'm looking at work and for some reason it blocks certain pictures. That could be one of them I saw earlier that wasn't coming through. I'll check it out from home I guess haha. Thanks.
Old 12-03-2012, 01:29 PM   #332
scx89
Member#: 269388
2011 Impreza WRX
obp
why is oil pressure so high on a cold start up?
Should I be waiting until it drops to about 80?
Old 12-03-2012, 06:23 PM   #333
JRCrutc
Member#: 309978
2017 WRX Limited
Lapis Blue Pearl
Usually the new wire is directly inline with the fuse slot. Also generally this is the slot farthest away from the prongs that go into the original fuse slot. You can always check this by removing one of the fuses and seeing if your powered object still gets power, if it does then it is the other fuse (and if it won't power on, then you have found your fuse).
JRCrutc is offline   Reply With Quote
Old 12-04-2012, 01:19 PM   #334
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Thanks for the feedback guys, I got it sorted out last night!
Old 12-05-2012, 12:14 AM   #335
Shackletown
Member#: 314629
2012 STI
The original fuse should go into the slot closest to the prongs. New fuse for the add on in the slot farthest from prongs.
Shackletown is offline   Reply With Quote
Old 12-05-2012, 02:41 AM   #336
scx89
Member#: 269388
2011 Impreza WRX
obp
yeah, make sure you use the stock fuses otherwise your trunk and key remote wont work!
Old 12-05-2012, 02:57 AM   #337
SpicyPeaNut
Member#: 43310
1978 Brat
Just curious but do these gauges have adjustable brightness? Or are the illumination on or off?
SpicyPeaNut is online now   Reply With Quote
Old 12-05-2012, 10:09 AM   #338
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
The Defi gauges dim when you turn the lights on but they're not adjustable.
Old 12-05-2012, 11:15 AM   #339
SpicyPeaNut
Member#: 43310
1978 Brat
Thanks!
Old 12-05-2012, 11:26 AM   #340
Dskier360
Member#: 327709
2011 WRX Premium
DGM - Stage 2
Checkout the white needle series from Prosport. I have them and they are reasonably priced and they match the OEM gauges perfectly! They don't dim but depending on how you wire them the gauges can be white (brighter) when the headlights are off and red when the headlights are on (the brightness is about that of the highest level on the OEM and the color matches including the white needles). I have them wired up for red all of the time but when it's bright out the color fades a little and doesn't match since there aren't any shrouds (might be able to put the ones on that come with but I didn't want to). I'll take some pictures later and post them up (day and night).
Dskier360 is offline   Reply With Quote
Old 12-06-2012, 02:57 AM   #341
scx89
Member#: 269388
2011 Impreza WRX
obp
Side question:
Is the oil pressure needle supposed to fluctuate quite often?
When i let go of throttle, my oil pressure drops from 80 psi to 50 then to 60 then to 40 all pretty quickly. Is it normal for it to fluctuate like that or is it supposed to go straight from 80-40 and stay there? Thanks
Old 12-06-2012, 10:25 AM   #342
O.C.D.
Member#: 19640
2003 WRX Sedan
Yes, the engine builds pressure when driven.
O.C.D. is offline   Reply With Quote
Old 12-06-2012, 01:17 PM   #343
rdowner22
Member#: 329284
02 WRX Sport Wagon
hahahahah! That "Prosport" link^^^^.
But in all seriousness, I love the Prosport electrical gauges! I personally think they look sweet and they are pretty reliable.
rdowner22 is offline   Reply With Quote
Old 12-07-2012, 12:37 AM   #344
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
I just finished the install yesterday and success! everything works. Big thanks to O.C.D. Without this write up I would be lost.
Quick question for anyone wiring this up in an STI. It is a tight squeeze in the bay trying to T off of the bypass valve hose. I didn't snap a good picture of my set up, but lets just say it is not pretty and involves some zipties for peace of mind. I did find this set up from THIS write up.
Anyone else have pictures of how they set up the T here? Also where did you purchase your actual T? I am having a trouble since the bypass hose has quite a bit larger inner diameter.
Thanks for anyones help.
JSchell1309 is offline   Reply With Quote
Old 12-13-2012, 10:27 AM   #345
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I was about to rip my sideskirt and some other panels off to get the plastic out from the fender, but then I saw you do it with the wheel off. Definitely saved me tons of headaches and whatnot. I cannot thank you enough O.C.D for making this guide
Old 12-13-2012, 06:03 PM   #346
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
i got it done and i can barely turn a wrench. Im did a number on that fender liner but oh well its back on. The alternator was a 6/10 difficulty for a novice like me. Getting it back on properly with the belt nice was a bit of a pain. everything else good.
you also need a small wrench to get the pressure sender threaded into the bung cause there isnt much space for a monkey wrench.
the T for the boost hose needs to be purchased at an auto parts store.
THANKS O.C.D for the help i really appreciate it :P
BroBroBroBroBro is offline   Reply With Quote
Old 12-14-2012, 02:06 AM   #347
Iorikusanagi
Member#: 340572
Does anyone have experience with Depo Racing gauges? I have most of the installation complete I am just stuck trying to power the gauge. The instructions tell me to connect one wire to "acc" and the other to "Battery (+)" I have have fuse taps connected to each wire and a 5A fuse for the new connection. I just dont know where to connect them after that.
Iorikusanagi is offline   Reply With Quote
Old 12-14-2012, 03:03 AM   #348
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
OP lists where he went for each on first page
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 26 - IG2
Illumination/Dimmer - Fuse # 16 - ILLUMINATION
SenorDucK is offline   Reply With Quote
Old 12-24-2012, 03:28 PM   #349
SpicyPeaNut
Member#: 43310
1978 Brat
I just wrapped up installing mine. I ran all the wires, buttoned everything back up except for 1 piece. The oil pressure sending unit. I've got the oil pressure gauge installed and hooked up (power/ground/illumination/ignition) so the gauge boots up and looks nice. However because I haven't installed the actual oil pressure sending unit the gauge bounces off of 130-140 PSI.
Old 12-25-2012, 05:24 PM   #350
pre0wned
Member#: 285335
2008 WRX
Does anyone know the dimensions of the T-piece that is supposed to come with the Defi boost gauge (and maybe where I could get one)? I purchased the gauge for the holidays and it is missing the T-piece.
pre0wned is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 07:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 08:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 05:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 04:15 AM
