Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
View Poll Results: Leaky Valve or Poor Rings?
Poor Rings 1 12.50%
Leaky Valv 7 87.50%
Voters: 8. You may not vote on this poll
Old 08-23-2006, 10:54 PM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default Leaky Valve or Poor Rings? Video inside
Alright as the title state which one do you guys think it is?
I was using this site as a refernce
http://www.therangerstation.com/Maga...acuumLeaks.htm
Here is the video
Let me give a little more info.
This is an EJ25 with wrx heads, sti head gasket.
Invidia DP
STI uppipe
Perrin Crank Pulley
UTEC
Misfire occur randomly on cylinders. (mostly 2 and 4)
Compression test results:
1 - 165
2 - 180
3 - 175
4 - 175
Any idea's guys?
NITROS is offline   Reply With Quote
Old 08-23-2006, 11:27 PM   #2
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
boxer motor . lumpy idle ,these to will make a guage jump. as for the misfires .... has the car been tuned? compression is increased with the gaskets you are using this will cause misfire problems.. compression looked ok to me was it hot or did ya check cold?
sonic rx is offline   Reply With Quote
Old 08-23-2006, 11:38 PM   #3
NITROS
Member#: 41561
04 GT3076 2.1
The engine was tuned to by me its pretty smoothe the IDLE AFR is messed they jump up and down between 14.2-15.5. Most of the time 14.7 - 15.1.
The vacuum check was done on a hot engine.
the compression check was done on a warm engine.
Old 08-23-2006, 11:47 PM   #4
Jasper
Member#: 80136
2006 Ford F-150
15.1 ?!
christ you run it lean. please dont tell me its that high above anything but idle?!
what do the plugs look like? are all your timing marks lined up?
(the misfire could very easily be caused by running that lean...makes predetonation VERY easy)
Jasper is offline   Reply With Quote
Old 08-24-2006, 12:02 AM   #5
RP31
Member#: 123574
2005 STi
CGM
Originally Posted by JasperSTi
15.1 ?!
It does say idle AFRs.
I run my car 13:1 at redline.
RP31 is offline   Reply With Quote
Old 08-24-2006, 12:59 AM   #6
subalou1
Member#: 57966
2002 wrx Sedona Red
[email protected], best trap 131
off topic but is 13:1 at redline lean?
subalou1 is offline   Reply With Quote
Old 08-24-2006, 02:26 AM   #7
NITROS
Member#: 41561
04 GT3076 2.1
15.1 ?!
I dont run it liek that. it runs itself like that. the AFR are not stable they jump up and down at idle. i run 11:1 at red line.
Old 08-24-2006, 03:25 PM   #8
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
when you use wrx heads with sti block ,and use stock head gaskets . you make more power with less timing ,and less boost. if you are running more timing you are probably causing your misfires that way. i run a similar setup ,but my heads are p&ped and i am running 264 cams with oe head gaskets,and a built (forged internals) 2.5l . timming and your afr would be my concerns. my vacuum moves a little also.
Old 08-24-2006, 04:34 PM   #9
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
15.1 is NOT lean for cruise or idle Jasper. This is normal for it to jump around a bit. Lean cruise is 15.4 to 1. This engine looks normal to me. Misfire codes are common. The ECU;s are very sensitive to it.
Clark
AZScoobie is offline   Reply With Quote
Old 08-24-2006, 04:40 PM   #10
Jasper
Member#: 80136
2006 Ford F-150
Clark
he said up to 15.5:1, which is what bothered me
my idle and cruise is set to 14.7:1, and doesnt stray far from that (+/- .2 maybe via borrowed LM-1)....and for safetys sake i run it 11.2:1 @ redline, and ~ 11.5:1 most anywhere above 5200rpm. for a TD04 powered 2.0, it pulls like a freight train, so im rather happy with it.
Old 08-24-2006, 05:04 PM   #11
AZScoobie
Member#: 8785
netcom.com
Ok Great. But even 15.5 is not real lean.. I was just pointing that out. The idle and cruise AFR can be changed from the factorys 14.7 to 1 in the map. I run most cars around 15.4 to 1 which returns a slight gain in fuel economy according to owners.
Cya
Clark
Old 08-24-2006, 07:13 PM   #12
RP31
Member#: 123574
2005 STi
CGM
<threadjack>
Clark, do you happen to know what the leanest mixture is that the ECU can see before it throws a CEL? I assume it is load site dependent... Do you know anything about this? I'm tuning my car to run on E85 using a UTEC, and I keep getting a CEL for running too lean of a mixture. I am running 12-15:1 depending on load, and I can't figure out why I keep getting the CEL. The only times AFRs go above that are during shifts and while coasting.
</threadjack>
Old 08-24-2006, 07:31 PM   #13
AZScoobie
Member#: 8785
netcom.com
You get the Bank to lean codes when the Fuel trims are out of wack. Get an OBD Scan tool and check your long and short term trims. Adjust the injector scale settings or the 0 column to get the Trims near zero and your problem will go away.
Clark
Old 08-24-2006, 07:34 PM   #14
RP31
Member#: 123574
2005 STi
CGM
Ahhh, okay. Thanks! I will do that.
Old 08-24-2006, 08:52 PM   #15
NITROS
Member#: 41561
04 GT3076 2.1
At cruise my AFR are spot on 14.7 - 14.8 its only at idle it feels like it runs really rough. They are also spot on when im WOT.
I do feel the misfires when they occur. Hippy mentioned that it might be the lighthen crank pulley causing the misfires. I bought one off a nasioc member and it got here today.
I have to say that in the subaru manual it said the vacuum should be a steady 17.72 mg in.
Old 08-25-2006, 01:15 AM   #16
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
hippy blames everything on lightend crank pulley even engines blowing up. if tuned for it they will not throw a misfire.lightend flywheel do this sometimes but can also be tuned for to reduce the times it throw mfc.
Old 08-25-2006, 11:06 PM   #17
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
dont feel like reading rest of thread but from what ive learned at school. A fluctuating vac test like that is most likely a valve train problem. Most likely a messed up valve.
doing a leak down test might help. If you do deicde to do one, do this.
Once the cylinder has pressure in it (make sure the cylinder your testing is at top dead center compression stroke). Listen for a "hissing sound" put your ear on the exhaust, oil cap, intake, radiator. It might be easier to hear these sounds witha stethascope (sp?)
If you hear noise from your exhaust, exhaust valve is messed up.
noise from Intake means intake valve.
noise from oil cap or dipstick means messed up piston rings.
and last and least likely, bubbles in the coolant reservoir or radiator cap means blown head gasket.
hope that helps some
bubba03wrx is offline   Reply With Quote
Old 08-26-2006, 01:24 PM   #18
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Originally Posted by bubba03wrx
... A fluctuating valve like that is most likely a drivetrain problem. Most likely a messed up valve. ...
The pressure-test How To will be helpful to many... but you didn't mean 'drive'train, did you?
ka mano is offline   Reply With Quote
Old 08-26-2006, 09:37 PM   #19
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
im sorry i must have been on crack last night when i wrote that. I mean a valve train problem
Old 08-27-2006, 12:43 AM   #20
Division By Zero
Member#: 7555
Your survey lists: 1.) Leaky Valves or 2.) Poor Rings. You shoud have included a vacuum leak issue. That's what I think it is IMHO. Try spraying starting fluid or similar at the vacuum hoses, intake manifold sealing points, PCV valve, etc. If your idle changes when spraying at the given area then that's you issue.
Division By Zero is offline   Reply With Quote
Old 08-28-2006, 04:14 AM   #21
NITROS
Member#: 41561
04 GT3076 2.1
I will do a leak down when i come back from arkansas next friday. same for the vacuum. I have installed the stock pulley the car seems to run alot better, i havent experienced (felt) any misfires yet. I need to clear my CODES and we'll see.
Thanks for you help guys.
Valve Tick/Piston Slap. Video inside, please help! Disco_Inferno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-07-2009 11:11 PM
Leaky valve cover gaskets: 1998 2.5 DOHC MaddMax Legacy Forum 5 02-01-2007 12:39 AM
Jumpy vacuum, Leaky Valve? NITROS Built Motor Discussion 0 08-23-2006 11:12 PM
Leak Test - leaky valve guide Joncas Normally Aspirated with bolt-on Forced Induction Powertrain 18 01-18-2005 05:05 AM
Leaky valve covers? wRxbeater11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-11-2004 01:59 PM
