Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 01-09-2013, 01:31 AM   #376
gmhracer
Member#: 267343
2006 STI
Originally Posted by SpicyPeaNut View Post
Theres a small grommet just behind and above the pedals. I ran mine through there
where on the engine bay side is it and how did you get to it on the bay side?
is it under the Master cyl/ brake booster?
gmhracer is offline   Reply With Quote
Old 01-09-2013, 03:21 PM   #377
Extreme Dimensions
Member#: 264277
wow that is a great write up and work done! O.C.D. to the extreme but VERY well done!
Extreme Dimensions is offline   Reply With Quote
Old 01-09-2013, 03:44 PM   #378
SpicyPeaNut
Member#: 43310
1978 Brat
Yup, driver side under the booster. Stick you head up near the pedals in the car. There is a medium to small size black rubber grommet. Careful when you try to run the wire, you cab easily pop it out . Ask me how I know lol
SpicyPeaNut is offline   Reply With Quote
Old 01-18-2013, 07:08 AM   #379
lentotheism
Member#: 321113
2012 STi Hatch
Default since you're OCD...
ever think about trying to mod your needles white to match?
*waits for DIY* lol
lentotheism is offline   Reply With Quote
Old 01-18-2013, 11:22 AM   #380
SpicyPeaNut
Member#: 43310
1978 Brat
*waits for DIY* lol
This is the first thought that popped into my mind. How would we do this?
Old 01-18-2013, 04:37 PM   #381
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
there are other gauges with white needles. they were mentioned in this thread.
ChesterWRX is offline   Reply With Quote
Old 01-18-2013, 07:13 PM   #382
lentotheism
Member#: 321113
2012 STi Hatch
they don't look half as nice as the Defi's though. here's someone who tried: http://www.toronto-subaru-club.com/f...e-pointer.html
the red seeps through+unfortunately
Old 01-18-2013, 07:21 PM   #383
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
that's pretty slick.
the needles don't bother me at all though.
Old 01-19-2013, 12:07 PM   #384
SpicyPeaNut
Member#: 43310
1978 Brat
Yeah fairly certian they were mot Defi branded. Show me a direct match for the 08+ sti gauges made be Defi.
Old 01-19-2013, 12:43 PM   #385
Ziggyrama
Member#: 53665
2011 STI Stg2 w/ ELH
Focal 2way Active w/ DSP
There aren't any so if you have to have Defi, you're porked. If you have to have a perfect match, consider another brand.
Ziggyrama is offline   Reply With Quote
Old 01-19-2013, 12:53 PM   #386
SpicyPeaNut
Member#: 43310
1978 Brat
Yeah, that was my original point
Old 01-19-2013, 02:50 PM   #387
Ziggyrama
Member#: 53665
Maddad gauges are a spot on match. Worth considering.
Old 01-21-2013, 03:27 AM   #388
BrendanTheGreat408
Member#: 271207
2011 WRX
Which color Defi wires go into which fuse? I tapped into 4, 24, and 14 but it doesnt look quite right I wanted to do it the way OCD said but he didnt say which COLOR goes to which fuse. Thanks
BrendanTheGreat408 is offline   Reply With Quote
Old 01-21-2013, 03:11 PM   #389
manualmotive
Member#: 339206
RIP Totalled 13 WRX
White 14 BRZ
Anyone get theirs done by a shop? If so, how much did you pay solely for the install?
manualmotive is offline   Reply With Quote
Old 01-23-2013, 11:53 AM   #390
TurboMoe
Member#: 186897
Question for those with multiple Defi gauges. Obviously OCD combined his wires as I'm sure most everyone has. The Defi instructions say "Do not join multiple power wires". Just wondering if anyone has had issues related to that. I'm guessing it's just Defi covering their ass in case someone does it and fries their gauges, they can say "we told you not to".
TurboMoe is offline   Reply With Quote
Old 01-23-2013, 12:07 PM   #391
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Read the manual.
Mine have been combined since before this guide was posted and it's been fine. The fuse should mitigate most of the risk.
xluben is offline   Reply With Quote
Old 01-23-2013, 12:12 PM   #392
Ziggyrama
Member#: 53665
I don't have Defi gauges but I'll take a shot at it. It's likely a default disclaimer to keep the warranty claims at bay. I am sure Defi would rather have you set them up on separate, fused circuits with no common power feed. It assures that you have no issues with pulling too much current through a single wire to satisfy multiple gauges' requirements. That can theoretically lead to problems like excessive heat, inconsistent current or frequently blown fuses. It may be your fault in the end but that does not stop people from calling support and claiming that the gauge caused a fire in the car. You should be fine provided you size the wire and the fuse correctly. My $0.02.
Old 01-23-2013, 02:38 PM   #393
TurboMoe
Member#: 186897
Thanks guys, pretty much what I was thinking.
I also thought of the BF setup I had in my '05, tapped into the clock harness. All three gauges and the control unit were powered by one source, which is essentially the same thing. Wish there was a decent 60mm mounting setup for my '11, I loved my old setup.
Old 02-03-2013, 08:30 PM   #394
ixwrxxi
Member#: 334215
2015 Forester
I'm ready to tap the wires into the fuse box and this is what I tap into,
Red wire-12V Battery - Fuse # 3 - DOOR LOCK
Orange wire-IGN - Fuse # 26 - IG2
White wire-Illumination - Fuse # 16 - ILLUMINATION
Black wire-GND - Grounded
My question is Fuse #26 what is IG2? I'm looking at my Owner Manual and the Manual state fuse # 26 is (power window relay / radiator main fan relay) is that the correct fuse to tap into?
the correct fuse box is located under the instrument panel behind the box cover on the drivers eeart side right?
Thanks
ixwrxxi is offline   Reply With Quote
Old 02-03-2013, 09:28 PM   #395
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
OP. where did you get those fuse taps?
gsrcrxsi is offline   Reply With Quote
Old 02-03-2013, 10:54 PM   #396
scx89
Member#: 269388
2011 Impreza WRX
obp
Pepboys or autozone
scx89 is offline   Reply With Quote
Old 02-06-2013, 05:17 PM   #397
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Just curious, but has anyone hooked up their gauge(s) to the dimmer switch? It'd be nice to control the brightness of the gauge along with the OEM speedo cluster instead of by turning your headlights off
Mr Wrex is offline   Reply With Quote
Old 02-06-2013, 05:46 PM   #398
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
i would think this will cause problems with the gauges and sensors versus actually dimming the gauge - due to the drops in voltage.. voltages should be consistent for gauges i believe, otherwise amperage will rise and you'll blow something.
Half Crazed is offline   Reply With Quote
Old 02-06-2013, 07:41 PM   #399
Ziggyrama
Member#: 53665
Some gauges have adjustable illumination
Old 02-07-2013, 11:13 AM   #400
DwnShft4WRX
Member#: 319398
2012 Impreza WRX
WR Blue
Subscribed for this weekend!! Great write-up.
DwnShft4WRX is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 07:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 08:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 05:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 04:15 AM
