Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 08-06-2018, 12:09 PM   #26
TWDP
Member#: 350518
2006 STi
Not much done to the car lately, had to throw in a new axle in the rear and a new brake line.
Currently the car doesn't have a steering rack in it since I went to change it out, but the hard lines on the rack are so rusted that they'll need to be replaced with it.
TWDP is offline   Reply With Quote
Old 08-13-2018, 11:15 PM   #27
TWDP
Member#: 350518
2006 STi
Swapped the nasty corroded rack out of the car since it had been leaking.
Ran into some issues since I forgot the lines on the rack do not come with a new rack and mine were unusable. After ten days managed to get them in from a subaru dealership
Next I finally got around to aligning the car, which for this I bought a at home alignment kit.
and a step by step video and review of the kit that I used if anyone is curious.
I've done the string with tape-measure method in the past and it's always a pain, but this kit was really easy and will pay for itself after three alignments. I'm going to find out how close I got it too, with an alignment check on Monday.
Old 08-18-2018, 10:04 PM   #28
TWDP
Member#: 350518
2006 STi
Got an alignment check done
The specs I set with the kit
FR Camber -2.6 Caster 2.8 Toe out 1/32nd
FL Camber -2.6 Caster 3.2 Toe out 1/32nd
Total front Toe 1/16th of an inch out
RR Camber -1.5 Toe 0
LR Camber -1.4 Toe 0
Actual specs
FR Camber -2.7 Caster 2.8 Toe out 0
FL Camber -2.7 Caster 3.0 Toe out 0
Total front Toe 0
RR Camber -1.5
LR Camber -1.3
Rear toe 1/32nd in
I maxed out Camber in the rear and went a little bit too much in the front after playing with the ride height and it increasing the camber, but I'm just going to stay where it is.
After redoing the Toe when I got home I saw what I did wrong and just rushed my measurements and corrected it. I may get another check just to make sure I'm good now, but it got me closer than some alignment shops have in the past.
Not too bad seeing as I could have had it right on if I had taken a few more measurements.
Old 08-18-2018, 10:22 PM   #29
TWDP
Member#: 350518
2006 STi
Installed my OMP Steering wheel and NRG quick release that I got from rally.build. I love the feel of the wheel, really changes driving the car. It's a little small for how slow the rack is on the car but that'll be fixed once I get around to doing the column quickener.
also got some "cheap" gravel tires from zestino to mount on the Method wheels and test fit them on the car and I threw on some Rally Armor mud flaps I had sitting in my garage for the past year or so from my STi
Old 08-18-2018, 10:23 PM   #30
TWDP
Member#: 350518
2006 STi
Here's the install of the OMP wheel and hub
Unfortunately the Rallycross I've been planning on going to tomorrow was canceled, so I rushed a bunch of stuff and prep to get it ready for no reason.
Old 08-28-2018, 09:52 AM   #31
TWDP
Member#: 350518
2006 STi
Since I had some free time from the RallyX being canceled I installed a sequential shift light I bought awhile back.. because if I have all the cool stuff then I'll get fast just like the Pros ..
Anyway It's more for the safety of the engine and shift a little earlier so I don't overspin the engine, since the revlimit is 8250 on this thing.
If anyone wants to get one of these,
it took awhile to show up, since it came from the UK, but was a lot cheaper than anything I could find in the states
Old 08-28-2018, 09:54 AM   #32
TWDP
Member#: 350518
2006 STi
Finally got to RallyCross the car since the swap. The event was around four hours away and was a very slow and tight course.
I really have to relearn the car since it is completely different and I can't drive it worth a crap, but it was still a blast.
Old 08-28-2018, 11:14 AM   #33
danscomp
Member#: 305358
Originally Posted by TWDP View Post
https://youtu.be/CJRzeCNfbvU
More info about the shift light please....Specifically wiring
danscomp is offline   Reply With Quote
Old 08-28-2018, 03:00 PM   #34
TWDP
Member#: 350518
2006 STi
In this video I did the install and went into depth on what the light required.
It is a very easy install with just hot, ground, and tach signal.
Old 09-03-2018, 09:19 PM   #35
TWDP
Member#: 350518
2006 STi
Got around to putting a new timing belt on the EJ207. It was the original belt.. so close to 20 years old though only around 55k miles on it.
then I went and picked up this thing..
It was getting pretty old driving to work with no A/C in my "race" car since the RS was my daily before the swap.
It's just an 07 2.5I base Impreza, but it's great on a commute.
Though my driveway is starting to look like a crappy used car dealership
Old 09-21-2018, 01:44 PM   #36
TWDP
Member#: 350518
2006 STi
Had some time to start working on the Quick Steering column a couple of weeks ago and finally got it done after finding time with the storm.
Here's the video on how I made it and the before and after on how it drives.
Here's how it started with the spare column I got from a junk yard and the Howe pieces to integrate it into the column.
Then came the column disassembly, separating the other portion from the inner steering shaft and then figuring out where to weld it in.
I shortened the spline couplers so it would fit in the lower round portion of the steering shaft. Mounting it here allows the column to still be able to collapse 6-8 inches, if it needs to.
I just went around tacking it into place, making sure there wasn't any binding issues before fully welding.
Then needed to section the outer portion for the quickener.
And then just bent a section of 1/8" plate and notched it to fit around the column, to serve as a mount.
Excuse those really terribly drilled holes in the mount lol...
Then used masking tape so the outer portion fit snuggly around the quickener.
and put it all back together.
The rack from 16.5:1 to around 11.5:1 or from 3.7 turns lock to lock to 2.2 turns from lock to lock.
It didn't seem to noticeably increase the steering effort and the pump keeps up just fine so far.
Old 09-23-2018, 08:55 PM   #37
TWDP
Member#: 350518
2006 STi
Stripping of the RS has begun.. and now all the fun of removing sound deadening.
Since the AutoX was canceled I'm going to have some fun with the car tomorrow as a last Hurrah with the turbo motor.. before I pull it into my Garage for probably the next year of it being down haha.
Side note: if anyone needs interior pieces for an RS mine are in good condition and would prefer they go to good use rather than just sitting in my attic
Old 10-16-2018, 08:26 PM   #38
TWDP
Member#: 350518
2006 STi
I haven't had much time in the last couple of weeks to work on the car due to work but I've managed to strip all the interior, the engine/trans, and removed all the sound deadening.
I didn't get many pictures of it all but if you want to follow along the videos are up on my channel.
Old 11-25-2018, 08:34 PM   #39
TWDP
Member#: 350518
2006 STi
Been awhile since I've updated this thread, but progress has been happening, just really slowly with work.
Got everything stripped out of the car and starting seem welding it all
Then moved on to get all the glass out of the car.
I also cut out the stock seat mounts which you can kind of see in that picture.
I definitely got a litttle carried away with the spot weld cutter and had to fill in quite a few holes the next day after I went completely through the floor a few times.
Started on the front pin stand mounts
I only got the fronts done since I need to take care of some rust in the rear portion of the rocker panel before I can make the mounts in the rear.
I went a little overkill on them with 1.5" .095 tubes, but after reading some stories of bent pins from guys that went with 1" tube and .75" pins I decided to go bigger and this is what I had laying around. 1.25" tube should fit in there well with the .060 clearance too, but I'll figure that out when I actually go and make the stands.
Old 11-25-2018, 08:37 PM   #40
TWDP
Member#: 350518
2006 STi
Then I mounted and welded up the reinforcements plates I got from rally.build.
Thinking about it after the fact I should have just stitch welded them in place and left about an inch of un-welded area every few inches. Anyway the welds look pretty terrible on them, I'm still trying to get the hang of welding thick plate to this 20g steel.... or I guess that's the best excuse I can come up with lol.
Then I finally began the cage construction with the main hoop.
I'm happy with how it turned out. I wanted it to be as tight to the chassis as possible so in the event I wreck it maybe there will be less damage . It could have been a little tighter, but as long as I can get around it all to weld it I'm happy with it.
Old 11-25-2018, 08:55 PM   #41
TWDP
Member#: 350518
2006 STi
I managed to get the front lateral bars done.
These were pretty tricky and the first one took two attempts, they came out alright. Definitely takes some practice with making them to get the fitment spot on.
Finally got my seats in, I ordered Bimarco Grip seats since they were the cheapest with Halo headrests and FIA rating, but after waiting seven months the company had no idea where they were so I order these.
So far I like them a lot and they're pretty comfortable, but I'll see once I actually mount them and can drive the car.
I got all the rocker boxes done for the cage and they're tacked into place now
And then I moved on to plating the rear strut towers and making the mounting points for cage to tie into.
Thinking about it after the fact I should have made them wider so I could extend them to where the strut tower meats the sheet metal on the side of the car.
and then today I made the windshield bar and got everything tacked in so I can get the roof bars done tomorrow.
Old 11-29-2018, 02:01 PM   #42
subyrally
Member#: 52662
2009 WRX. 06 Baja
17 Crosstrek 85 brat
loving your build, it looks like it is going to be fun
subyrally is offline   Reply With Quote
