Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 10-18-2008, 11:24 PM   #1
R3HM
Member#: 191618
2003 WRX
Subaru Banner What's a good way to clean under my hood?
my engine and the components are dirty. I was wondering if any one can tell me a good way to clean it. And if there's a good product that is made for exclusively this. Thanks in advance!
R3HM is offline   Reply With Quote
Old 10-18-2008, 11:47 PM   #2
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
uh.. I just spray mine down with degreaser and take a pressure washer to it. Then I keep it clean by just wiping it down with a cloth and any kind of light cleaner every other day or so.
Ah, and if you have an SRI obviously be careful with water, and don't target plugs or wires.
96SubyImpreza is offline   Reply With Quote
Old 10-18-2008, 11:47 PM   #3
Impreza541
Member#: 160822
2007 Forester XT
Beige
courtesy bump, I would like to know also.
Impreza541 is offline   Reply With Quote
Old 10-18-2008, 11:53 PM   #4
R3HM
Member#: 191618
2003 WRX
do i just spray everything with degreaser or just the metal? do you take it to a car wash and use the pressure washer?
Old 10-18-2008, 11:55 PM   #5
KB21
Member#: 186441
2004 Impreza WRX
+1 I'd like to have a more detailed advice as well.
For example, how careful should I be with the TMIC?
KB21 is offline   Reply With Quote
Old 10-18-2008, 11:57 PM   #6
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
My dad works at a dealership so they have a pressure washer there, but yea you can use one at a carwash. Well, you only need degreaser if everythings really disgusting and then I spray it on solid metal components (be careful with the intake manifold because there is a lot of accessories on it.) I try not to linger too much in there with water but I'd give it a good blast.
Old 10-18-2008, 11:57 PM   #7
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
yea, dont hit that with a pressure washer.
Old 10-19-2008, 12:17 AM   #8
wrx_owned
Member#: 173766
2007 impreza wrx
use simple green then spray with pressure washer
wrx_owned is offline   Reply With Quote
Old 10-19-2008, 12:23 AM   #9
R3HM
Member#: 191618
2003 WRX
what about the alternator is that bad to get wet?
Old 10-19-2008, 12:35 AM   #10
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
I wouldnt try to drown it but chances are its not gonna die if it gets wet. I know i've sprayed mine a few times.
Old 10-19-2008, 12:40 AM   #11
NightHawk
Member#: 175181
Simple green and a tooth brush works for me! and i use cold water with a hose, no nozzle.. slow stream does the trick. and it does not hurt the TMIC to get it wet... otherwise why would there be a scoop..
NightHawk is offline   Reply With Quote
Old 10-19-2008, 02:06 AM   #12
Nicklz
Member#: 94096
2003 WRX
simple green eats aluminum
although they supposedly have an aluminum safe version now, but don't know if it's as effective as the original......
Nicklz is offline   Reply With Quote
Old 10-19-2008, 03:09 AM   #13
KB21
Member#: 186441
2004 Impreza WRX
I'll check on the aluminum-safe simple green. Can you guys recommend another good (i.e., safe and effective) degreaser brand to use?
Easiest way to clean UNDER the car..? XanRules Car Care & Detailing 26 02-14-2010 02:37 AM
How to clean under my hood? DJS_02_WRX Car Care & Detailing 17 09-29-2009 02:45 PM
What's the best way to clean the engine compartment under the hood? rabbit92x Car Care & Detailing 4 11-27-2008 10:06 PM
What's a good way to clean a Nintendo? DoinkMobb Off-Topic 14 10-27-2004 01:00 PM
I got egged, what's the best way to clean it? Robmat Car Care & Detailing 4 04-28-2002 06:58 PM
