Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 02-18-2010, 10:31 AM   #1
scooby1320
Member#: 190138
2007 vf39 awd tuned
white
Question Easiest way to push in the pistons when changing brakes?????
Hey guy today when I get off work I'm finally gonna change all four brakes for the first time, just wanted to know what's the easiest way to push in the pistons, I drive a 07 Wrx tr
Thanks
scooby1320 is offline   Reply With Quote
Old 02-18-2010, 10:50 AM   #2
f1speeder
Member#: 138854
2011 WRX
When I did my 06 WRX TR, I just put a C clamp over the old brake pad and tighten it. I didn't even have to open the bleeder valve to release the pressure.
Very easy.
f1speeder is offline   Reply With Quote
Old 02-18-2010, 10:51 AM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
On a 4-pot/2-pot setup.
Remove pins
Remove anti-rattle clip
Wiggle the pads so they are a little loose
Take ONE pad, slide it out
turn it 90* and reinsert half of it.
Use it as a lever to push back the piston(s) on that side
Insert new pad.
Remove other old pad
Repeat.
Put clip and pins back.
When you're done replacing the pads do a quick bleed, and then bed them in properly.
Old 02-18-2010, 10:51 AM   #4
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
^agreed
Dirty25RS is offline   Reply With Quote
Old 02-18-2010, 11:10 AM   #5
evan_impreza
Member#: 115276
98 v9 RSTI
207 + rotated 30r
C-clamp and a small piece of wood is what I use.
evan_impreza is offline   Reply With Quote
Old 02-18-2010, 11:50 AM   #6
jeisen
Member#: 27258
who dat be dat was?
most auto parts stores sell a tool like this. just place an old brake pad between the clamp and the pistons and you are set.
jeisen is offline   Reply With Quote
Old 02-18-2010, 11:57 AM   #7
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
this is one of my most prized and favorite tools ever:
happs subi is offline   Reply With Quote
Old 02-18-2010, 01:06 PM   #8
scooby1320
Member#: 190138
2007 vf39 awd tuned
white
Thanks guys I guys I'll try the c clamp with the. Brake lol
Old 02-18-2010, 01:25 PM   #9
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
i use crow bar or big screw driver with the pad still inside the caliper.
Kenji815 is offline   Reply With Quote
Old 02-18-2010, 01:26 PM   #10
Mechie3
Member#: 120152
I like to use quick clamps. Fast, easy, and the rubber grips don't marr the 4 pot surface.
Mechie3 is offline   Reply With Quote
Old 02-18-2010, 02:18 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Remove pins
Insert new pad.
Repeat.
THIS
Everything else posted in this thread is a total waste of all involved and should be deleted as misinformation.
Old 02-18-2010, 02:58 PM   #12
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
Yup.
Works for sliding calipers.
None of those work for fixed calipers.
Old 02-18-2010, 03:01 PM   #13
jeisen
Member#: 27258
who dat be dat was?
reading comprehension fails me
Old 02-18-2010, 05:17 PM   #14
STi-MAN
Member#: 70252
05 STI
blue
on the topic of this.. what about on a non turbo legacy rear calipers slider calipers?
STi-MAN is offline   Reply With Quote
Old 02-18-2010, 05:37 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Pistol grip quick clamp
Old 02-18-2010, 06:11 PM   #16
STi-MAN
Member#: 70252
05 STI
blue
^ no other home remedy way? thanks for the info.
Old 02-18-2010, 06:15 PM   #17
Turn in Concepts
Member#: 93646
Many Track Records
C-clamp. I really like the pistol grip one though as I can operate it with one hand.
put the old pad in place against the piston, and press it in.
IF you're going to be doing a full bleed you can also just open the bleed valve and push it back by hand.
easiest way to take apart the hawkeye headlight?? scooby1320 Interior & Exterior Modification 17 03-03-2012 03:36 PM
Easiest way to clean UNDER the car..? XanRules Car Care & Detailing 26 02-14-2010 02:37 AM
What is the easiest way to take out the bottom 2 19mm bolts on struts? jaytheman Newbies & FAQs 47 02-02-2010 01:01 PM
Is there a way to vote in the presidential election without leaving my house? eurojax Off-Topic 8 10-01-2004 01:16 PM
easiest way to change brake fluid NRTmotorsports Brakes, Steering & Suspension 15 05-12-2004 01:55 AM
