Welcome to the North American Subaru Impreza Owners Club Friday December 6, 2019
Old 04-11-2016, 03:00 PM   #1
Effers
Member#: 221803
2010 WRX Limited 5DR
World Rally Blue
Default 2008+ Impreza/WRX/STI - B Pillar Rust
Started noticing rust bubbles underneath the vinyl stickers on both front door B pillars.
Wondering if anyone has had this happen and how you fixed? I am aware that the stickers can be purchased however is the rust underneath manageable?
This seems like a design flaw considering both front doors have rusted in the exact same area. When you take a look at the inner facing side of the same area there is definitely rust visible.
http://i.imgur.com/TPMy75s.jpg
Effers is offline   Reply With Quote
Old 04-11-2016, 05:05 PM   #2
ramo14
Member#: 444344
2008 impreza
red
that looks bad
i hope you find a solution
ramo14 is offline   Reply With Quote
Old 04-24-2016, 09:15 PM   #3
PapaG
Member#: 7734
2017 Gti
I have the same thing, but only on the drivers side. It seems like it's in the exact spot where I place my thumb when opening the door. Mine is just bubbled, and has been for a while...can't see the rust yet.
PapaG is offline   Reply With Quote
Old 05-07-2016, 07:29 PM   #4
n7slc
Member#: 443545
2015 WRX Limited CVT
Lightning Red
Better get it fixed. My '08 started as just a small bubble last
year and I thought it was just surface rust. I told myself that I'd get it fixed
this summer and it's turned into a serious cancer. I suspect that water gets
trapped inside the door at that spot, for whatever reason, and it turns into
this. I see this as a MAJOR repair and will likely be easier to just
replace the door.
The passenger side appears to be unaffected so far.
Not sure what to do with it at the moment. I've got to fix some paint damage
on my wife's MY11 Silverado first.
n7slc is online now   Reply With Quote
Old 05-07-2016, 11:44 PM   #5
Floody420
Member#: 419597
2016 WRX PRM 6MT
2002 Audi A4
Interesting. I have a '16 and I notice there are white-ish prints on the passenger side where my girlfriend gets in (lotion and crap). I wonder if that eventually leads to this.....
Floody420 is offline   Reply With Quote
Old 05-07-2016, 11:46 PM   #6
Floody420
Member#: 419597
2016 WRX PRM 6MT
2002 Audi A4
Honestly though, if you peel of the "black out" tape, sand it down, put some mud on it sand it down, then reapply new black out tape, should be ok
Old 05-09-2016, 11:17 AM   #7
Effers
Member#: 221803
World Rally Blue
I believe the issue is a manufacturing flaw. The water likely channels in from the top of the sticker opening of the door and moisture pools in that area eventually leading to rust.
It's the only explanation as I do not ever touch that area of the door yet I have the same issue on the drivers side.
Unfortunately out of warranty and unlikely that the dealership would even help with repairs...
Old 05-11-2016, 05:37 PM   #8
HKelters2.5
Member#: 446707
I'd say this is you best option. Might have a tough time matching the black out tape so might plan on doing both sides to be safe.
HKelters2.5 is offline   Reply With Quote
Old 05-11-2016, 10:32 PM   #9
dingobite
Member#: 82391
08 OBP Sti
Subframe for my front seats have had rust on them since I had the car it probably a assembly defect or was exposed to rain salt before it was built.
dingobite is offline   Reply With Quote
Old 08-03-2016, 07:36 PM   #10
otakusan
Member#: 391393
2011 STi Sedan
I swear this is a manufacture defect... how can cars this new have this type of rust problems. I have the same thing happen to my 2011. Subaru of cause denies warranty.
otakusan is offline   Reply With Quote
Old 08-08-2016, 11:26 AM   #11
Effers
Member#: 221803
World Rally Blue
I might attempt a fix before winter rolls around. Here are the part numbers for the tape sash in case anyone was also looking.
I hope there aren't any other surprises once the tape comes off...
90422FG021 TAPE DR SASH FR RH
90422FG030 TAPE DR SASH FR LH
Old 08-08-2016, 11:53 AM   #12
n7slc
Member#: 443545
Lightning Red
I had mine repaired a few weeks ago. The shop sand blasted the area on both sides and used a structural epoxy filler of some sort to inhibit rust and provide strength since mine was rusted all the way through, and then a normal filler to smooth out and paint. I'll post up a picture when I can.
Old 08-08-2016, 02:36 PM   #13
otakusan
Member#: 391393
2011 STi Sedan
Mine was a little less worst than yours and when I had it opened up, and saw that the whole inside was rusted away, I took it to the body shop.
The body shop end up cutting out more than 1/2 the B-pillar sheet metal on the door.. It was all rusted through. What you already see from the outside, it's easily 10 times worst on the inside. Also, there is a good chance that when you remove the chrome window seal piece, it will get bent out of shape and you will not be able to reuse that. It's an expensive piece to replace too $90Cnd from my local dealer.
Best of luck with your repair.
Old 08-15-2016, 12:00 PM   #14
monsieur kam
Member#: 452680
2008 Impreza 2.5i
I haven't seen any rust on my '08 2.5i yet. And I live in the salty winter state, Indiana. Anyway, I would plan on ordering the new trim pieces. Pop those off and sand/grind off any rust, paint to avoid future rust, and replace.
monsieur kam is offline   Reply With Quote
Old 08-16-2016, 12:27 AM   #15
BraveSTi
Member#: 262030
USELESS ass soft-subbie-paint....wonder when my number is up
BraveSTi is offline   Reply With Quote
Old 08-28-2016, 12:44 PM   #16
p0staldude
Member#: 299478
2008 WRX
I have the same problem, just sanding it down is not enough. It rusts from the inside, if it shows from the outside, it means that it rusted through.
Here is what mine looked like:
http://i.imgur.com/Z2wHa6E.jpg
Without the vinyl, not too bad right?:
http://i.imgur.com/QWhMsVv.jpg
After 10 sec with a wire wheel, you can see the hole:
http://i.imgur.com/mlAczAS.jpg
The back was as bad:
http://i.imgur.com/9eYVgot.jpg
http://i.imgur.com/PeaP4SZ.jpg
After sandblasting
http://i.imgur.com/1KGAtrd.jpg
Patch:
http://i.imgur.com/FRJnNAp.jpg
http://i.imgur.com/RFYFWxK.jpg
p0staldude is offline   Reply With Quote
Old 08-31-2016, 01:37 AM   #17
BraveSTi
Member#: 262030
GOOD work.
Its just ridiculous that you even have to do that.. to an 8 year old car no less
Old 02-03-2017, 05:13 PM   #18
landoficensnow
Member#: 332534
2013 WRX Hatch
A bit late to the party... but I have the exact same issue!
Upon closer inspection this same kind of rust is happening on all the door seams of my 2013 WRX Hatch.
Subaru said they would do a 'good faith repair'--however this is totally a rust perforation warranty claim. Subaru did acknowledge it was an issue but denied handling it through a warranty claim.
I am slated to have this work done in the spring (car is stored for the winter).... However I am considering taking them to small claims if they do not replace the doors and the hatch.
This thread proves this to be a larger issue.
landoficensnow is offline   Reply With Quote
Old 02-04-2017, 10:57 PM   #19
SpicyPeaNut
Member#: 43310
1978 Brat
Anyone know the source of how the water is getting into the doors? It would be pointless to fix the rusted bits only to let water find its way back in and start rusting it all over again.
SpicyPeaNut is offline   Reply With Quote
Old 02-04-2017, 11:00 PM   #20
otakusan
Member#: 391393
2011 STi Sedan
that area should be completely sealed when the door was manufactured, If something was in there that caused the car to rust from the inside like that within 5 yrs.... it's a defect! Even thou Subaru won't admit it
Old 02-05-2017, 10:55 AM   #21
p0staldude
Member#: 299478
2008 WRX
There is a hole at the top of the window frame. It's used to attach the weatherstripping to the door with a plastic clip.
The problem is that there is no drain at the bottom of the window frame
Old 02-05-2017, 07:02 PM   #22
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
thats some crazy rust. ive made it a habit to wipe all the door jambs and apply fluid film since the car was new. no rust soo far. i also wipe and protect the undercarriage and rear fender lips.
424wrx is offline   Reply With Quote
Old 02-06-2017, 12:52 PM   #23
stevie.oh
Member#: 420318
2009 2.5i
i've noticed a little bit of rust creeping through on the hatch on my '09, right below the wiper arm. water seems to pool here and it's starting to take its toll. looks terrible
stevie.oh is offline   Reply With Quote
Old 02-07-2017, 09:47 AM   #24
GalaxyBlueDude
Member#: 381955
2014 WRX
World Rally Blue
Hey,
FYI Subaru has a corrosion warranty? Use it.
GalaxyBlueDude is offline   Reply With Quote
Old 02-09-2017, 08:55 PM   #25
ObewanKenobi
Member#: 428583
2017 Impreza Sport
Venetian Red Pearl
Kind of upsetting that an 8 year old car would get rust in a spot like that. I might not be surprised if it was in a wheel arch but that is not a spot I would expect to rust.
ObewanKenobi is offline   Reply With Quote
