Welcome to the North American Subaru Impreza Owners Club Wednesday December 11, 2019
Old 06-05-2018, 02:19 PM   #1
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Default Replacement Product for "Showroom New" Trim Dye?
Years ago I bought a product called "Showroom New" that was essentially a black or grey product that you could use to dye and restore automotive trim. It worked amazingly well and would stain the crap out of your hands, paint, etc. if you were sloppy with application. The rags you applied it with were also permanently black. It was great stuff.
Now I've run out of my little 4 oz bottle and it looks like this stuff has been out of production for some time...
I've done some research, but most of the reviews are mixed about whether or not the products are a "permanent" solution.
So, what do you folks recommend for a "permanent" black/grey trim restorer? I'm familiar with Back-to-Black, but that is a super temporary product. I'm hoping to find something I'll only have to touch up every few years.
car_freak85 is online now   Reply With Quote
Old 06-05-2018, 02:51 PM   #2
blue-sun
Member#: 15934
2017 Jetta GLI
Tornado Red
I haven't tried this method, but I have read about it online and it seems to work.
CN: Heatgun or clean transmission fluid should restore your plastic trim pieces, but you need to keep them protected to stop it from repeating.
blue-sun is offline   Reply With Quote
Old 06-05-2018, 04:05 PM   #3
CGM_WRX
Member#: 66280
2005 WRX Sedan
Crystal Gray Metalic
I haven't tried it personally but have seen good results from Solution Finish.
CGM_WRX is offline   Reply With Quote
Old 06-05-2018, 04:09 PM   #4
Obviously Tyler
Member#: 395955
2019 Mazda 3 Premium
1999 Miata 5MT
Never used this myself but I've always had really good luck with Chemical Guys products.
And this looks like an easy mask-off and spray type of application.
https://www.chemicalguys.com/Black_o...ir_spray_1.htm
Obviously Tyler is offline   Reply With Quote
Old 06-06-2018, 12:50 PM   #5
car_freak85
Member#: 13530
EJ205
Thanks for the suggestions, I'll have to look into these.
After looking into that Chemical Guys product, it sounds more like a Back to Black-type product than a permanent restoration. The word "dressing" is my clue there, but I could be missing something (running on 4 hours sleep...). I'm hoping to find something along the lines of a plastic dye.
Old 06-14-2018, 05:23 PM   #6
xbgen2
Member#: 487142
the BEST product to use to blacken any exterior plastic trim is Forever Black, which the VW community has been using for over 15 years...its a dye that actually dyes the trim black again, not just some product that makes the trim look black again until the product wears or washes off...
xbgen2 is offline   Reply With Quote
Old 06-21-2018, 12:08 PM   #7
car_freak85
Member#: 13530
EJ205
If it's good enough for the VW crowd (and there are a metric ton of them around here), then it's good enough for my 30-year-old Subaru GL!
Old 06-21-2018, 04:13 PM   #8
STi320
Member#: 148655
2005 STi CGM
'Black Trim Kote' and 'Gray Trim Kote'
https://www.amazon.com/s/?ie=UTF8&ke...ejn9vqz7_e_p38
STi320 is offline   Reply With Quote
Old 08-28-2018, 06:29 PM   #9
car_freak85
Member#: 13530
EJ205
Ok, following up with my original post:
I ended up buying this bumper dye kit. It sure does the job, at least a week out from application.
I did notice that it didn't really look even until I got two or three coats on there, and even with the provided applicator, I didn't feel like the product was going on level. It leveled out as it dried, however.
I'm about a week and a half out from applying the dye, and it seems to be holding up just fine. I'll update this as I dye more parts and get more UV exposure.
Old 03-20-2019, 06:00 PM   #10
car_freak85
Member#: 13530
EJ205
Nine months later and I'm not exactly thrilled with the longevity of the product I used. As the product ages it does look an awful lot like a paint versus a dye.
I will probably use up what I've still got, then pursue other alternatives.
Old 03-25-2019, 04:11 AM   #11
tim417
Member#: 499122
Default Restoring Trim
I am about to restore some extremely oxidized trim for a friend and have heard good things about Adams Polishes Black Trim Restorer. It is similar to the product in the first post in that it is a dye for plastic trim. I intend to dye the trim, allow it to cure the prescribed 6 hours, and then apply the ceramic trim coat to seal it all in. I'll take some photos and post them here.
I have had great results from various Adams products. Not the cheapest by far, but generally excellent products overall. Their detail spray is the bomb.
tim417 is offline   Reply With Quote
Old 03-25-2019, 11:03 AM   #12
soloz2
Member#: 260128
2019 WRX Limited
Lapis Blue Pearl
CarPro Dlux works extremely well to bring back faded trim. I used some on an 06 Legacy and 98 Outback where the trim had been oxidized and gray instead of the dark gray or black as intended. Because it's a coating, it also lasts. I sold both vehicles about 2 years later and all the trim still looked amazing.
soloz2 is offline   Reply With Quote
Old 03-25-2019, 01:45 PM   #13
car_freak85
Member#: 13530
EJ205
Originally Posted by soloz2 View Post
CarPro Dlux works extremely... Because it's a coating...
Kind of trying to avoid "coatings." Looking for dyes. I'll give that Adam's product a look.
Old 03-26-2019, 11:39 AM   #14
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
I recall a similar discussion elsewhere...might have been a Porsche forum. Wurth Dye Plast seemed to have been the consensus for a professional quality product. Not sure if you can get it in the USA though. Might need to order from Europe.
Scooby921 is offline   Reply With Quote
Old 03-26-2019, 01:09 PM   #15
car_freak85
Member#: 13530
EJ205
Yeah, you're right, that stuff is hard to come by. Amazon sellers won't ship to the U.S. and ebay is almost a quadruple markup, and still ships from Europe.
I'll still probably pick up a tube or two...
Old 03-27-2019, 10:56 AM   #16
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
I may end up there as well. My wife's Mini has a lot of graying black trim plastic. I was using Black Wow to recondition it, but that only lasts a couple months. I most recently purchased Polish Angel Black Bond to see if it lasts longer and protects better. For the money I would have been better off over-paying for the Wurth stuff form Europe...except I completely forgot about it until you bumped this .
Old 03-27-2019, 12:46 PM   #17
car_freak85
Member#: 13530
EJ205
You want to split the purchase, save on some shipping? Best price I've found (that ships to the States) is on eBay...
Old 03-28-2019, 03:35 PM   #18
mojavecrosstrek
Member#: 499425
Thanks for the thread and replies guys...
I ended up getting an 18' Crosstrek and some cleaner I used stained all the plastic trim around the body with white crap I can't get off. Going to try some of these products.
mojavecrosstrek is offline   Reply With Quote
Old 06-04-2019, 05:03 PM   #19
car_freak85
Member#: 13530
EJ205
I picked up a couple tubes of the Wurth product. Will be applying it this week and will report back.
Old 09-18-2019, 12:27 AM   #20
TriAxis 6
Member#: 377862
2017 Z06/Z07 & Fozzy
Admiral Blue & CWP
If you can find this stuff, I promise youíll love it. A little bottle lasts a great long time.
From Hungary with love!
http://wolfs-chemicals.com/index.php...im_coat_150_ml
TriAxis 6 is offline   Reply With Quote
Old 09-19-2019, 04:50 PM   #21
car_freak85
Member#: 13530
EJ205
Once I use up the Wurth dye I will check out the Wolf nano dressing, thanks for the tip!
Old 09-19-2019, 09:07 PM   #22
TriAxis 6
Member#: 377862
Admiral Blue & CWP
No problem. Good luck finding it, it can be difficult. Itís about $40 a bottle but it should last you quite a long time.
Old 09-20-2019, 02:19 PM   #23
car_freak85
Member#: 13530
EJ205
The Wurth product was a Euro-only, similarly priced to the Wolf.
Old 10-09-2019, 03:08 PM   #24
ilovedemhotrides
Member#: 326147
Still holding up after the initial dye ? How many months now ?
ilovedemhotrides is offline   Reply With Quote
Old 10-15-2019, 12:42 PM   #25
car_freak85
Member#: 13530
EJ205
I don't think I've even used it yet! Got motivated in the spring to detail all the things, then fell off over the summer as I got pulled in different directions. Once the shop is cleared out I'll pull in the bugeye and see how it performs.
