Welcome to the North American Subaru Impreza Owners Club Saturday February 27, 2021
Old 11-06-2018, 09:39 PM   #26
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Originally Posted by Underboosted View Post
I can't really seem to find a wheel cleaner that says it's safe for brake pads. Does anybody know which brands/types of wheel cleaner won't also eat away at brake pads?
It seems that if cleaner can remove even long untreated stuck-on brake dust, how does it not also eat away at your brake pads when you spray it on? Isn't brake dust, just brake pad particles and road fallout, stuck to a surface and sometimes rusted in because of the high iron content in the pads? Why don't cleaners that remove that, eat away at your pads as well? I'm more thinking long term repeated use over a year or two?
Should i stay away from high acidic cleaners or just use a mild, paint safe degreaser to treat tough spots? I typically just use Griots car wash, then detail spray and a mircofiber cloth, but really want an easier solution to clean the STI wheels, a spray on/off no scrub solution would suit me best, but i don't want to cause premature wear on the pads cause im lazy.
Because brake dust is actually rotor dust. Unless you have metallic pads, the amount of iron is very low. Also, even if the acid reacts with the brake pads and rotor, it's all surface once you rinse it off.
jasonwrx86 is offline   Reply With Quote
Old 11-06-2018, 09:41 PM   #27
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Originally Posted by standardtranny View Post
That's as much $ as 5qts of synthetic oil
If you just do wheels, it will last a long time. A whole car application can take about 200ml at a time.
Old 11-07-2018, 08:44 AM   #28
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
Vote for Sonax.
I used to use Eagle All Wheel and Tire cleaner. Its cheap and works ok.
I switched to Sonax and my wheels still look brand new.
I do use a cheap wheel and tire cleaner sprat, but just for the tires.
vapore0n is offline   Reply With Quote
Old 11-07-2018, 02:06 PM   #29
oichan
Member#: 492327
19 WRX 16 STI
17Mk7R 20Supra 20Forester
I looked at all sorts of wheel cleaners, but at the end of the day I just use car shampoo and a boar's hair brush / MF wand to agitate.
oichan is offline   Reply With Quote
Old 11-08-2018, 12:31 PM   #30
Caramidaru
Member#: 493751
Default canada?
anything for Canada users?
Caramidaru is offline   Reply With Quote
Old 11-09-2018, 07:07 PM   #31
LowandSlowDC5
Member#: 473341
2012 WRX
World Rally Blue
As other have said, Sonax! P21S is also pretty good!
LowandSlowDC5 is offline   Reply With Quote
Old 12-05-2018, 03:30 PM   #32
WREXJake
Member#: 474259
2005 WRX
18L
Originally Posted by jonmw531 View Post
2011 STi, 62k miles. My wheels are filthy. As in, pressure washer (at a safe distance) won't cut through all the brake dust. What cleaner/process do y'all recommend?
IronX is great, worth the money.
WREXJake is offline   Reply With Quote
Old 12-18-2018, 08:10 PM   #33
EastEndRaceshop
Member#: 492744
Meguair's Wheel Brightener works amazingly for me! Eats brake dust and works perfectly on any clear coated/OEM wheel.
EastEndRaceshop is offline   Reply With Quote
Old 02-01-2019, 09:34 PM   #34
AlanBarry
Member#: 497243
ddddddddddddddddddddddddddddddd
AlanBarry is offline   Reply With Quote
Old 02-08-2019, 04:38 PM   #35
Marcio58
Member#: 497517
I like the Sonax wheel cleaner plus its made in Germany and goes on green and turns red when it absorbs brake dust
Marcio58 is offline   Reply With Quote
Old 02-09-2019, 04:06 AM   #36
Creativelemon
Member#: 497536
New wheels lol
Creativelemon is offline   Reply With Quote
Old 02-09-2019, 02:02 PM   #37
EastPhilly
Member#: 491030
I traded for some BRZ wheels that were used for a while. Has some baked on dust in tough spots. I tried Griots, Chem Guys, WD40, and some regular washes. Nothing will get that last little bit off besides clay bar. I spray it on, use a good brush, and can get about 95% off, but I'm still trying for that last little bit before sealing and waxing it. Once the weather warms up I guess I'll buy some IronX and use my pressure washer with it.
EastPhilly is offline   Reply With Quote
Old 02-26-2019, 11:23 AM   #38
aneil93
Member#: 406655
08 Impreza 2.5i
Spark Silver Metallic
Simple Green is usually my go-to.
aneil93 is offline   Reply With Quote
Old 03-03-2019, 11:24 PM   #39
gc8subie626
Member#: 498574
I use soap and water, but thatís my opinion
gc8subie626 is offline   Reply With Quote
Old 03-04-2019, 12:34 AM   #40
carsebuco
Member#: 482289
I bought into all these IronX comments and got myself a bottle of it, only to realize what's on the wheels isn't brake dust at all - it's just dirt. Sprayed it heavily the first time hoping for some miracle just to realize I still had to wash it off with soap and wipe it down with a towel to remove what I was actually bothered by.
carsebuco is online now   Reply With Quote
Old 03-06-2019, 05:09 PM   #41
whiteWRXKnight
Member#: 498676
Cool Best Wheel Cleaner for my 2017 WRX STI
I use Adam's Wheel Cleaner, Tire & rubber Cleaner and tire shine to finish things off. I also use a pressure washer to really get into my dirty wheels.
whiteWRXKnight is offline   Reply With Quote
Old 03-07-2019, 09:25 AM   #42
mamock116
Member#: 497678
Black Magic No Scrub works fantastic.
mamock116 is offline   Reply With Quote
Old 03-08-2019, 01:14 AM   #43
Dillonbugeye420
Member#: 426102
2002 Wrx hybrid.
Psm
Adams wheel cleaner. Smells terrible. But works on the dirtiest wheels. Turns red when ready to rinse.
Dillonbugeye420 is offline   Reply With Quote
Old 03-08-2019, 11:24 AM   #44
Panacea
Member#: 349037
2019 STi Limited
How safe is the Adam's stuff, really? I don't use wheel cleaner because it can be acidic. I use car wash soap because there's no risk of it being caustic. It's just that the STi's brakes are so dusty and that the ***8216;19's wheels are so complex that I'd like a little help from chemistry, if I can.
Panacea is offline   Reply With Quote
Old 03-10-2019, 01:52 AM   #45
Superchargedk20
Member#: 466477
What type of wheels are u trying to clean. Cant believe this wasnt asked anywhere. Are they stock wheels? Alot of wheel cleaners have acidic particles that can damage depending on your wheels. Your not gona use the same wheel cleaner on chrome wheels that you would on let's say some forged volks.
Superchargedk20 is offline   Reply With Quote
Old 03-26-2019, 07:53 AM   #46
hangloose
Member#: 499587
Sonax Wheel Cleaner in my opinion.
hangloose is offline   Reply With Quote
Old 03-26-2019, 01:14 PM   #47
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
What would you use on forged Volks (with a ****ty respray by the P.O.)?
car_freak85 is offline   Reply With Quote
Old 03-26-2019, 04:45 PM   #48
mvadenais
Member#: 472751
2018 WRX
Originally Posted by Slim_Jim View Post
I've been using Chemical Guys Diablo gel wheel cleaner and a soft bristle brush. I think it works very well and doesn't leave any residue that I've seen some in the past do. And, it doesn't have a strong chemical smell.
Used this for the first time the other day. Impressed with it.
mvadenais is offline   Reply With Quote
Old 03-27-2019, 02:13 PM   #49
Flemmy
Member#: 499645
Either Sonax or CarGuys super cleaner have worked super well.
Flemmy is offline   Reply With Quote
Old 03-27-2019, 11:32 PM   #50
Saab2Sub
Member#: 474630
2018 WRX
CWP
another vote here for simple green. works great and is cheap as hell. i also have some adams wheel cleaner, but simple green is my go to.
Saab2Sub is offline   Reply With Quote
