08-28-2006, 12:06 PM | #1 |
Member#: 58329
Vehicle:2005 Baja Turbo 5mt Garnet Red Pearl |
Are stupid SUBARU AXLES retarded?
just got my driver side done about a year ago. the stupid thing is that the axle won't budge at all near the hub? so we replaced the whole spindle and axle NOW THE PROBLEM, my passenger side has a torn cv boot now...so is there any way to get the axle out? i tried using MAP gas and that hasn't worked yet. HIT the crap out of it but doesn't work(same thing as driver side which made mushroom on axle). SO all the subaru guru's out there...HELP
08-28-2006, 12:17 PM | #2 |
Member#: 10471
TXIC
Vehicle:2000 BMW Z3 sold Outback & ForesterXT |
My axles aren't "retarted", nor are they retarded. Though, they MAY be retarted, seeing as how they are always whoring themselves out for a nice set of wheels. Those skanky tarts...
08-28-2006, 12:52 PM | #3 |
Member#: 60224
You have to take the axle nut off first silly...
Seriously though, I've never had a one of my axles stick at the hub. Usually the slightest tap with a hammer on the end and they pop right out. I have noticed however they have a guide hole in the middle of the stub which intends to be there so you can use a puller on it. I would throw a 2/3 jaw puller on the hub with the piston on the end of the axle stub and start cranking. Tap with a hammer along the way once you get a ton of force on there and eventually something will POP! With luck it will be the axle... |
08-28-2006, 03:27 PM | #4 |
Member#: 58329
yes the NUT is off..lolz
btw, where can i find those puller and how much they run? thanks |
08-28-2006, 04:46 PM | #5 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I've replaced both front axles and one rear axle and have never had any issues at all. I don't even think I needed to tap on 'em with a hammer, I just unbolted everything and pulled the knuckle out and the axle fell right out of the hub.
08-28-2006, 05:53 PM | #6 |
Member#: 30695
Vehicle:BOOM , Get her to sew THAT! |
Oh, I know all too well the stubborn nature of some Subaru axles.
I beat the crap out of that puller. Clean the splines really well and.. Anti-sieze Anti-seize Anti-sieze, my only advice on not having to repeat. |
08-28-2006, 08:17 PM | #7 |
Member#: 58329
where can i get that puller? ^ thanks alot for pictures....all the FWD i did on axle jobs poped out except AWD so far including a 1g eclipse
08-28-2006, 10:14 PM | #8 |
Member#: 60224
08-28-2006, 11:00 PM | #9 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
I've done both the front axles on my '91, and they just came out with a little BFH lovin'.......
Oh, yeah. Overgeneralization, FTL. |
08-28-2006, 11:04 PM | #10 |
Member#: 10471
TXIC
I'm done with this post for two reasons...
1. Mr. Illegal has too many spelling/grammar/punctuation errors for me to read through his posts without hurting my head. 2. I've only done this kind of work once or twice and it was YEARS ago. Way too long for me to give hints and tips that would be worth anything. |
08-28-2006, 11:14 PM | #11 |
Member#: 25952
NWIC
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
An airhammer works really well if you've got one also.
Hammer on the center of the axle until it starts to move a little... Then tighten the axle nut back down to pull it back in... Remove the axle nut, and hit the axle with the air hammer again... Keep repeating until the axle comes off. Then take the end of the axle to a wire wheel and clean all of the crud off... Get a wire brush and clean the hub out, and then antisieze the **** out of everything when putting it back together. |
08-29-2006, 01:05 PM | #12 | |
Member#: 58329
08-29-2006, 01:19 PM | #13 |
Member#: 108557
NWIC
Vehicle:2003 PSM WRXWgn STG2 05 OBM LEGACY SDN |
Pretty much looks like maybe a harmonic balancer puller/steering wheel puller for a US car might work. You can usually rent such stuff @ PepBoys/Schucks/Autozone on the cheap!
08-29-2006, 08:00 PM | #14 |
Member#: 30695
Yeah, I like getting tools like this at Autozone, cause if I break them it's a free replacement. I have broken three, and needed to swap for a small one once. All I have ever done is bought one puller and the rest have been free.
Oh, and it's hard to tell from the pic, but as well as completely destroying the end, there is also a bow to the threaded rod now, and I had to switch jaw ends when one of the teeth let go. That axle was a champ. |
08-30-2006, 04:34 AM | #15 | |
Member#: 10471
TXIC
I know, we shhouldn't be so hard on everyone, but someone has to be... Just be glad that I'm the only one complaining this time. Sometimes a bunch of us will just highjack a thread if the errors are bad enough! Now, back to the topic of axles: |
08-30-2006, 08:21 AM | #16 |
Member#: 60224
What's wrong with OP's opening post? You say proper English should be used yet every word is spelled correctly and he did a fine job capturing his frustration through the use of sarcasm and capitalized letters. If anything, the grammar is a bit off with improperly formatted sentence structure, but the English is fine...
Then again what do I know, I've only been here since 2004 too... |
08-30-2006, 11:20 AM | #17 | |
Member#: 16653
NESIC
Vehicle:2017 Mazda 6 2013 Toyota Vanling |
As janik pointed out- the more readable a question is, the more willing we'll be to answer it. There's no reason to dumb down a technical question, or the forum in general, by shouting, posting a bunch of angry faces & poor spelling.
Subaru axles are not "retarted" in any way, and the post sounds like it was written by an angry middle-school kid. How about this? Quote:
08-30-2006, 11:39 AM | #18 | |
Member#: 94945
Vehicle:2015 Dodge Charger AWD |
Not to say that he doesn't speak it well in person |
08-30-2006, 02:01 PM | #19 |
Member#: 60224
09-03-2006, 11:21 PM | #20 |
Member#: 67814
Vehicle:1995 legacy L white |
I had a double cheese burger from mcdonalds today
09-03-2006, 11:38 PM | #21 |
Member#: 94945
09-04-2006, 12:51 AM | #22 |
Member#: 10471
TXIC
Actually, that is perfect. It is VERY CLEAR what you need help with and there is no silly spelling error to make fun of...
09-04-2006, 08:10 AM | #23 |
Member#: 38222
Vehicle:'10 &'12 Foresters another Miata convert |
[/bickering]
Nobody needs their thread filled with junk. Yes, the English was rough. Yes, the OP's needs were clear, regardless of that fact. Relax, guys. |
09-08-2006, 08:27 PM | #24 |
Member#: 45218
illegal2.2 - one more thing, don't forget about the roll pin on the transmission end of the cv axles, well at least there were one on each axle on my impreza. It is a small pin that is inserted through the center of the joint. You can find it by rotating your cv axle. The pin is tapered so that means it can easily be removed in one direction...but you could be like me and can spend an hour trying remove it from the opposite end. I literally used every tool i had, and finally rigged up my own punch and air-hammer combo. I realized it was tapered when i removed the other side...which took less than a minute. good luck.
09-08-2006, 09:38 PM | #25 |
Member#: 60224
Axle pin... And they're not tapered new, likely take the form from being pounded in...
A good rule of thumb is to flatten the teeth a bit (equally) across the pin before inserting. Makes them go in easier so you don't have to beat the crap out of them... |
Stupid people are stupid. | Cole | Off-Topic | 14 | 08-28-2009 02:01 PM |
are there any other retarded mods besides Jgard | Georgethefierce | Off-Topic | 20 | 04-03-2006 01:27 PM |
are srt4 owners this retarded? | sc00by4life | Off-Topic | 8 | 10-11-2005 11:21 PM |
Are there any other retarded people here besides GTF? | JGard | Off-Topic | 10 | 10-05-2005 02:15 PM |
Women are stupid, men are jerks. | Projekt | Off-Topic | 14 | 10-23-2003 12:25 PM |
