Welcome to the North American Subaru Impreza Owners Club Thursday December 5, 2019
Old 07-08-2012, 09:36 AM   #11
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Did you see the question I was asking about the injectors and rails? When I first installed the rails I didnt put an insulator on the upper part of the injector. When I went to plug the wire harnesses into the injectors (after installing the entire manifold assembly on the engine) I noticed that the injectors could be moved around 1/4 inch up and down. There's no way that the bottoms would hold pressure so something was obviously wrong.
I had a set of injectors out of an 2002 wrx so I compared the two to see that the stock injectors had an insulator at the top seat where they mate to the fuel rail. I pulled the insulators off the wrx injectors and put them on the ID2000s to see if that made a difference. That made them fit much better but I am worried because the body on the ID2000s is not squared off like the stock injectors. I could easily see the ID2000s sliding around when the rubber insulators get hot.
No insulators (look at the contour of the injector bodies):
With insulator installed:
dexterous is offline   Reply With Quote
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 02:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 09:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 02:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 11:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 06:06 PM
