Welcome to the North American Subaru Impreza Owners Club Tuesday December 10, 2019
Old 05-17-2002, 03:15 AM   #1
V6
Member#: 2703
Y2K GC8
Silver forever
Default Anyone running Cobb's power package stage 2 or stage 3 with no CEL problem?
Anyone?
V6 is offline   Reply With Quote
Old 05-17-2002, 04:34 AM   #2
PPTough
Member#: 6031
2001 Impreza RS 2.5
Sliver
Default No
Stage 2:
I'm going to say no for the most part.
Because if you change out your headers or the cat your looking at getting a P0420 error code saying that your cat isn't working up to effciency.
You can fix this by spoofing the O2 with a resistor.
The cat is working correctly but because there is less backpresser the ECU will freak out for some reason.
Stage 3:
Well your really getting into some heavy mods here!
You may want to post your question at
http://www.wrxform.com
Tray and Josh from Cobb run this board and can give you options about what you can do.
PPTough is offline   Reply With Quote
Old 05-17-2002, 05:50 PM   #3
quicksilver
Member#: 2538
I'm running Stage 2, minus headers, and Stage 3 mild cams. I've got a MY01 and it has never flashed the CEL. I used the resistor from Pony Express Performance. It's really easy to install and works great!
-Mike
quicksilver is offline   Reply With Quote
Old 05-17-2002, 06:14 PM   #4
jeffg
Member#: 2958
2001 6.0?RS
According to Borla Direct, You can remove the Cat efficiency CEL by wrapping the last part of the header. This keeps the exhaust gases from cooling too much, which causes the CEL.
Jeff
jeffg is offline   Reply With Quote
Old 05-17-2002, 07:24 PM   #5
V6
Member#: 2703
Y2K GC8
Silver forever
So anyone running the Boral headers and the Random Tech high flow cat without any CEL problems?
Thanks
Old 05-17-2002, 07:38 PM   #6
inpreza kid
Member#: 3334
cobb stage 2 and 3 cams may cause a CEL. i remember reading something about that. the subaru ecu is very sensitive so i wouldn't be surprised if you get a CEL with cams. i get a constant CEL with my apex itc. doesn't really bother me. a CEL really isn't that big of a deal.
inpreza kid is offline   Reply With Quote
Old 05-18-2002, 01:30 AM   #7
11SECROO
Member#: 18139
2001 Impreza 2.5RS
Question Resistors?
Where can I get this Resistor. I have no catalytics and a stock exhaust manifold. This is the weird part, the CEL is on and right at 77-79mph in 5th gear the CEL flashes. Any help, please e-mail me. [email protected]
Thanx Travis
11SECROO is offline   Reply With Quote
Old 05-18-2002, 02:42 PM   #8
daves rs01
Member#: 4455
2001 impreza rs
COBB stage 3
I'm running the COBB stage 3 package and have had only 1 cel about the cat, I wrapped the header and no problems since! I alsh have JUN flywheel and ACT clutch. I love it all
daves rs01 is offline   Reply With Quote
Old 05-18-2002, 05:25 PM   #9
V6
Member#: 2703
Y2K GC8
Silver forever
So even you have the Boral headers and the Random Tech high flow cat, then by warpping the headers will eliminate the CEL problem?
Thanks.
Old 05-18-2002, 11:52 PM   #10
Brood
Member#: 3886
2011 STi Sedan
Mancream White
daves rs01,
I was wondering if you have run into any problems with having both an underdrive pulley and a lightened flywheel?
Brood is offline   Reply With Quote
What is a Stage 2 or Stage whatever package? Unabomber Newbies & FAQs 73 02-22-2018 06:32 PM
protuned stage 2 or stage 2.5 wrx? adWRXi AccessPort 5 03-05-2008 08:21 PM
stage 2 or stage 3 ? thesandwichking Proven Power Bragging 3 03-17-2007 05:52 PM
Question for Cobb's stage 2 or stage 3 power package users. V6 Normally Aspirated Powertrain 1 09-12-2002 03:53 PM
Stage 2 or Stage 0? flat4life Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-04-2002 09:16 PM
