Welcome to the North American Subaru Impreza Owners Club Wednesday December 11, 2019
Old 07-27-2013, 04:42 PM   #226
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
The diode is to help protect the SSR gate from reverse current. And unless you're planning on running something that draws more than 50ish amps DCCD pro offers a product that will run them for a comparable price. Jockeygolfs has one, you could ask him about it.
dstroy is offline   Reply With Quote
Old 07-27-2013, 05:36 PM   #227
jockeygolfs
Member#: 260868
2011 STI
I have two for future expansion. Working so far. Customer support is top notch too.
jockeygolfs is offline   Reply With Quote
Old 09-11-2013, 02:08 PM   #228
brazzl61
Member#: 242752
2011 Impreza WRX STI
If I may, I am actually in Subaru school right now (on lunch currently) and we were JUST talking about the 3 speed fuel pump circuit and how it works. Now I haven't read the whole thread so if I am repeating anything -Disregard. If not, hope this helps.
It seems that it is controlling Pump duty cycle via ground.
The circuit goes like this:
and then to modify it and have it work like factory it will go like this:
**I forgot to draw something on there... where the ground is coming out of the FPC, I would add a thicker ground to chassis to support the higher Voltage being transmitted.
Hope this helps!
brazzl61 is offline   Reply With Quote
Old 09-11-2013, 06:29 PM   #229
brazzl61
Member#: 242752
Also, that scribble mark in the middle of the fuel pump line isn't a loop, it's just a scribble to break the contact (i didn't redraw, just modified my first drawing)
Old 09-12-2013, 02:16 PM   #230
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Trying to wire up my rats nest of my full blown setup.
medamullet is offline   Reply With Quote
Old 09-12-2013, 02:45 PM   #231
brazzl61
Member#: 242752
Here i redrew it a little maybe it's more clear here
Old 09-12-2013, 06:22 PM   #232
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I am lost now. I have read and reread this thread 10 times. I was sold on the relay idea and grounding back through the stock FCU.
Now I am wondering why the Fuelpro unit? why both??? Is it necessary?
Also since I am using 2 dw200 pumps in the full blown hanger hobbs switch for the second pump? wire them both together like a single pump?
like this:
Old 09-12-2013, 06:30 PM   #233
jockeygolfs
Member#: 260868
2011 STI
It is all how you use your car. If it is a daily you may want the Fuelpro or some sort of way to run your pump at different loads. If it is dedicated race car then 100% flow might be good enough and you may swap the pump regularly. These pumps are not really meant to run 100% all the time. The Fuelpro will act similar to the stock FPC. The issue with the stock FPC is that it is assumed it cannot handle the amps required by a walbro 465. At about 80 psi the pump draws about 20 amps. The Fuelpro can run up to 50 amps I believe. A stock pump only draws about 13.5 amps. These are all ballpark figures. I don't think you want to ground back to the stock FPC if you plan to run this pump. You will not get the flow that is needed by this pump.
Old 09-12-2013, 07:29 PM   #234
erok81
Member#: 300717
2004 WRX
JBP
I like the method brazzl posted. I've read most of the thread so far. I really don't want to run my pump 100% so that method using the factory controller looks good. Is that how most people are running their setups with not doing 100%?
erok81 is offline   Reply With Quote
Old 09-12-2013, 07:32 PM   #235
jockeygolfs
Member#: 260868
2011 STI
Problem with factory FPC is that it cannot handle the additional amps required to run the walbro 465 correctly.
Old 09-12-2013, 08:26 PM   #236
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I'm not running a walbro 465 I am running 2 dw200 pumps. Wired directly to the battery like my 2nd drawing shows using the stock controller.
Old 09-12-2013, 08:31 PM   #237
jockeygolfs
Member#: 260868
2011 STI
I'm no electrical engineer so I'm not sure what two DW's would need. Check the amp requirements at the fuel pressure you are desiring. The stock FPC will limit what the pump/pumps can draw.
Old 09-12-2013, 08:43 PM   #238
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Dw website says the dw200 only draws 12.7 amps at 100 psi. (25.4 for 2 pumps) so probably 22 amps total for 2 pumps realistic for my setup. With the hobbs switch only switching on at 15psi so 99% of the time only 1 pump will be running.
I'm not arguing against the fuelpro I am more than willing to buy it if its for me. I just like to "talk it out"
My car is definately a dd from now on. I can't afford to wreck it or fix it any more from track use.
Old 09-12-2013, 08:45 PM   #239
jockeygolfs
Member#: 260868
2011 STI
Yeah I know. I'm not arguing. I like to see people experiment etc. if it works great. We all learn from it.
Old 09-12-2013, 08:50 PM   #240
jockeygolfs
Member#: 260868
2011 STI
Even if you need 22 amps for only a small period of time the stock FPC might not be able to give it to you. Give it a try though I may be wrong. Chassis ground and or aftermarket FPC seem to be the only way it works for me.
Old 09-12-2013, 09:07 PM   #241
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Hmmm ok. Maybe I will just pull the whole stock unit out and replace it. Well I'm going to wire it up and get my car started and running the way i drew the picture. Then worry about it if I run out of fuel. It's been a long 2 years. I'm tired of working on this car.
Old 09-12-2013, 10:00 PM   #242
brazzl61
Member#: 242752
The setup I posted addresses this issue. The FPC is still able to modulate duty cycles via ground. The extra amperage is sent right to the pump, not the FPC.
Old 09-12-2013, 10:01 PM   #243
jockeygolfs
Member#: 260868
2011 STI
I'll have to study that some.
Old 09-12-2013, 10:01 PM   #244
brazzl61
Member#: 242752
So basically, you wont have a code, you wont burn the FPC, and you will retain the three speed cycles of the pump. and also the priming feature.
Old 09-12-2013, 10:04 PM   #245
jockeygolfs
Member#: 260868
2011 STI
Please test this and report back.
Old 09-12-2013, 10:10 PM   #246
brazzl61
Member#: 242752
I have other things to take care of on my car before I get to this particular part (just put a motor i built in and finishing up on it to get it started and broken in, so the pump wont be going in right away). Like I said, we were just going through all of this while I was up at the Subaru training center for my Fuel/Emissions class. The problem with the NF image that was just posted a couple posts ago is that the FPC PWM is now modulating the relay and not the pump. The relay is only an "on/off" deal... so it isn't actually changing duty cycles. ALSO I believe with this setup since the duty ratios will be adjusted it will also assist in not over running the stock FPR
Old 09-12-2013, 10:13 PM   #247
jockeygolfs
Member#: 260868
2011 STI
Right. Cool. But until you actually try it we don't know. It will be awesome if you are right though.
Old 09-12-2013, 10:14 PM   #248
brazzl61
Member#: 242752
I hear you. I encourage someone to give this a shot so results/reports can be had sooner than I will be able to provide a real result.
Old 09-12-2013, 10:17 PM   #249
brazzl61
Member#: 242752
As far as applying my method to the double pumper.... Medamullet, just off the top of my head I dont see why it wouldn't work to just apply the method to the primary pump and then hard wire the second pump with a separate relay and hobbs switch directly from the battery. completely seprate from the primary--when the second pump is kicking in it's for high demand so it will be full duty anyway.
Old 09-12-2013, 10:18 PM   #250
brazzl61
Member#: 242752
I imagine you will want to come up with some sort of failsafe routing though incase the one pump fails it will kill the other pump so your car just dies off rather than leaning out.
