Welcome to the North American Subaru Impreza Owners Club Thursday December 12, 2019
Old 11-07-2016, 09:43 PM   #5726
Rowrx11
Member#: 338312
Originally Posted by mgpmadmike View Post
Hello everyone I had a 2014 Subaru sti. I know that the stock wheels are 18x8.5 with a +55 offset well I was looking at a set of wheels 18x8 +35 offset would these wheels fit and clear the brakes without any problems I'd hate to buy them and them not fit right or rub don't really want to roll or pull fenders either just bolt them on would there be any problems I'm new to this website so if someone could just message me on here or something I would really appreciate it thank you!!
Oz ultralleggera 18x8 +35 and 235/40/18 rce yellows. No problem at all. This is my old setup.
Rowrx11 is offline   Reply With Quote
Old 11-10-2016, 04:48 AM   #5727
cKgelo01
Member#: 457932
2015 WRX Premium
Crystal Pearl White
Originally Posted by qnzfinestflip View Post
Work Emotion XD9 18x10 +38, 245/40, fenders rolled and rear slightly pulled.
what suspensions setup? coilvoers? how many inches drop? camber?
cKgelo01 is offline   Reply With Quote
Old 11-10-2016, 05:02 AM   #5728
cKgelo01
Member#: 457932
2015 WRX Premium
Crystal Pearl White
Originally Posted by AzNStiImpreza View Post
18x9.5 + 38 Enkei Rpf1
255/35/18 Tires
Lowered with RCE Yellow. Natural rear camber and -1.4 in front.
fender roll?
Old 11-11-2016, 03:47 PM   #5729
tawheed
Member#: 124413
2006 Impreza WRX
Would 18x9 +45 clear STI brakes?
tawheed is offline   Reply With Quote
Old 11-11-2016, 04:42 PM   #5730
fredrik94087
Member#: 337075
2015 WRX Stg3 SOLD
Are you asking about rpf1s?
fredrik94087 is offline   Reply With Quote
Old 11-11-2016, 06:30 PM   #5731
jbatarseh11
Member#: 445220
2016 WRX
Default 2015 WRX/STi Aftermarket wheel and tire fitment
Will 245/45/18 tires fit on the stock limited WRX wheels, stock suspension?
jbatarseh11 is offline   Reply With Quote
Old 11-11-2016, 06:45 PM   #5732
VanWo
Member#: 447721
2017 WRX Limited
Yes. 245/40R18 is factory size so your tire will just have a little taller sidewall.
VanWo is offline   Reply With Quote
Old 11-11-2016, 10:53 PM   #5733
jbatarseh11
Member#: 445220
2016 WRX
Would that taller side wall fit under the fenders though?
Old 11-12-2016, 01:21 AM   #5734
tawheed
Member#: 124413
2006 Impreza WRX
Advan RS
Old 11-12-2016, 12:24 PM   #5735
wv2.5i
Member#: 325693
2015 WRX SOLD
Used to be a common wheel fitment for sti, you'll find plenty of google images of stis running them. So all good.
wv2.5i is offline   Reply With Quote
Old 11-12-2016, 02:45 PM   #5736
VanWo
Member#: 447721
2017 WRX Limited
Short answer yes.
Your tire would be about 12mm taller, almost half an inch. But with stock wheels your inset in plenty far enough I wouldn't worry about contacting the outer lip of the fender. If anything you may rub on the inside of the wheel well/fender liner if the susp compresses enough (hard bumps etc).
Old 11-12-2016, 08:30 PM   #5737
ZerolFaithl
Member#: 448133
2016 WRX Base
Grey
I've always liked these wheels and I belive they're in spec to fit a 2016wrx, anybody done it?
ZerolFaithl is offline   Reply With Quote
Old 11-12-2016, 09:04 PM   #5738
jbatarseh11
Member#: 445220
2016 WRX
Short answer yes.
Thank you!
Old 11-13-2016, 02:17 PM   #5739
imacrayon
Member#: 427072
WedsSports just came in 18x9.5 +38 with 255/35
Haven't had any rubbing yet on stock suspension.
http://i.imgur.com/pfSd6PU.jpg
http://i.imgur.com/hhL1Sxl.jpg
http://i.imgur.com/PpOaVLa.jpg
http://i.imgur.com/apCsriq.jpg
imacrayon is offline   Reply With Quote
Old 11-13-2016, 02:22 PM   #5740
ZerolFaithl
Member#: 448133
2016 WRX Base
Grey
Very nice!
Old 11-14-2016, 02:31 AM   #5741
dinhzel
Member#: 458121
Default gramlights 18x10.5 +12
Sorry I hate to ask but does anyone know if gramlights 18x10.5 +12 will fit on my 2017 subaru wrx? If they do fit, what are good size tires for them ? I will be buying them soon if they fit! Thanks guys!
dinhzel is offline   Reply With Quote
Old 11-14-2016, 02:43 AM   #5742
VanWo
Member#: 447721
2017 WRX Limited
Basically no, those will stick out about an inch and half more than can be fit without fender mods. I'm sure it could be done but you would be looking at rolled AND pulled fenders and good amount of negative camber with stretched tires. If your ok with that then maybe something like 245/45 on the 10.5" width wheel would offer pretty decent stretch. If they make them in a 18x10 +40 that would be a better option. Would still need to roll fenders for sure in rear but would otherwise be pretty decent fit and could run a wider tire like a 265/35.
Old 11-14-2016, 04:15 AM   #5743
aniltip
Member#: 394300
2015 WRX Limited
Dark Gray Metallic
Approximate fitment: http://www.allfordmustangs.com/forum...ive-camber.jpg
aniltip is offline   Reply With Quote
Old 11-14-2016, 10:48 PM   #5744
Rowrx11
Member#: 338312
Someone with enkei ts10 18x8.5 black ?
Old 11-16-2016, 12:10 PM   #5745
RCouchh
Member#: 427164
2016 WRX Premium
Purp
Getting gramlights 57c6 18x9.5 +38 with 265/35/18 tires. Going to be installing RCE yellows.
Expected to rub? Should I roll fenders?
RCouchh is offline   Reply With Quote
Old 11-16-2016, 12:58 PM   #5746
RCouchh
Member#: 427164
2016 WRX Premium
Purp
heres in a 9.5
Originally Posted by ABishop View Post
Enkei TS10 18x9.5 +35 Gloss Black (Stock Setup on Suspension)
Old 11-16-2016, 12:59 PM   #5747
HyRoad
Member#: 416559
2016 WRX DGM
Based off previous comments, I think the rears will rub slightly on larger dips with 265/35 on stock springs. With the Yellows, I'd roll the rears to be safe.
HyRoad is offline   Reply With Quote
Old 11-16-2016, 04:52 PM   #5748
Chanceyj12
Member#: 456930
Originally Posted by Apox View Post
Rays Gramlights 57xtreme 18x9.5 +40 Matte Graphite
MPSS 255/35/18
Still have to add the RCE Yellows to the mix. Have the box in hand but it might be another couple months before the install..
Do/did you have any rubbing or turning issues with this setup?
Chanceyj12 is offline   Reply With Quote
Old 11-16-2016, 05:29 PM   #5749
HyRoad
Member#: 416559
2016 WRX DGM
You won't rub at stock height or lowered on RCE's/similar spring. 265/35 seems to be the tire size where people are having to roll the rears.
Old 11-16-2016, 07:24 PM   #5750
Xensity
Member#: 418718
2015 '15 WRX Stage 2
Crystal White Pearl
AV-20 18x9.5 with a 255/35 tire - On RCE yellows
They also have em in 18x8.5 but I have no idea what tire i would get with those. Basically I just want a set I can bolt up that sits flush with no rubbing or turning issues at all. I have looked through literally every single page in this thread and all I have now is a headache lol.
Will that set up top fit without any issue at all, if not what is a good tire size to go with those. If 9.5 is to wide then what size tire would you guys rec for the 8.5in wheel.
Thanks in advance and sorry for being THAT guy
Xensity is offline   Reply With Quote
