Welcome to the North American Subaru Impreza Owners Club Saturday December 14, 2019
Old 07-01-2019, 01:47 PM   #8176
RutRut1124
Member#: 352605
2017 STI
Had the car clean so decided to snag some pictures.
20x9 +35 Vossen CVT, 255/30 Michelin Pilot Sport 4 S
RutRut1124 is offline   Reply With Quote
Old 07-01-2019, 03:21 PM   #8177
rymaggi
Member#: 253442
Originally Posted by kaeknows View Post
what if the enkei inner bore doesnt have space for the oe studs with hubcentric spacers attached? Also, he won't be able to tighten the nuts 7 full turns with the 5mm spacers, he'll get 6 full turns, hence why he needs the arp studs and 10mm. My previous volks had space for the oe studs inside the inner barrel with the kics hubcentrics spacers attached, with my advans now, there's no space for the oe studs in the inner barrel. cant speak much on it, unless you've experienced it, just my 2 cents.
kevin
The spacers don't come with studs. I'll be replacing my stock studs with ARP studs.
rymaggi is offline   Reply With Quote
Old 07-01-2019, 04:15 PM   #8178
kaeknows
Member#: 357191
2016 WRX
ISM
did you read what i just said? "hence why he needs arp studs" pertaining to you, you can buy it from fastwrx.com, mach v 10mm spacers with arp studs
kaeknows is offline   Reply With Quote
Old 07-01-2019, 04:40 PM   #8179
rymaggi
Member#: 253442
It's a bit confusing, not gonna lie. Maybe today is just not my day.
Old 07-01-2019, 05:58 PM   #8180
kaeknows
Member#: 357191
2016 WRX
ISM
pictures for example
certain wheels doesn't have much clearance for oe studs when you attach a hubcentric spacer.
Old 07-02-2019, 12:41 AM   #8181
dpetro1
Member#: 487500
2018 WRX
I follow what you are saying about the space behind the wheels but not all hubcentric spacers have the embedded studs especially the smaller spacers so I don't think that is a concern in this case. He was getting 10mm spacers with extended arp studs so he should be all set.
dpetro1 is offline   Reply With Quote
Old 07-02-2019, 08:41 AM   #8182
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
'08 Mustang GT (the toy)
You weren't the only one.
The embedded-stud kind, which I'm familiar with as bolt circle adapters and wasn't even thinking of here, bring with them the disadvantage of making it impossible to check hub side lugnut torque without removing the wheel. Then you get to going through the "torque the wheel side nuts, drive it a bit, and retorque those" drill. Doesn't seem worth the hassle for anything other than a trailered show car, given that lug nuts can and will loosen in service.
Should be a hard no for any car that gets driven hard.
Norm
Norm Peterson is offline   Reply With Quote
Old 07-02-2019, 06:17 PM   #8183
rymaggi
Member#: 253442
Norm
Okay good lol
Yea these spacers won't have studs. I currently have 20mm spacers with the studs on there and they're torqued very well and checked before every track event i do.
When i get my RPF1's i'll be using the ARP extended studs.
Old 07-03-2019, 08:45 AM   #8184
vlad11591
Member#: 295970
2019 STI
CWP
anyone run 255/35/18 on 19 STI?
I know stock is 245/35/19, and with the wider wheel, but smaller rims, not sure if it will look like a lifted truck on stock suspension. I'm trying to use the same set up on my old WRX on the STI.
18x9.5 +38 with 255/35/18 indy hawks (wheels clear brembos)
vlad11591 is offline   Reply With Quote
Old 07-03-2019, 10:41 AM   #8185
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
I think 255/40/18 is a closer fit. It is about 1% larger than stock. The 255/35/18 is almost 3% smaller.
I am curious about this as well. I am considering 255/35/19 for my 19 STI. The diameter is slightly larger than stock, but I am hoping not too much. There are more tire options in this size.
MountainMan10 is offline   Reply With Quote
Old 07-03-2019, 11:28 AM   #8186
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
MM10 - only about 7 mm larger on the diameter.
About half of that shows up as reduced tire to fender gap. The other half ends up being about 1/8" worth of greater ride height (think sill to ground here).
Norm
Old 07-03-2019, 11:42 AM   #8187
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
I totally missed that. Been almost 20 years since I worked with BMW measuring rideheight. The wider slightly larger wheel could help me as I barely have clearance to get into my drive way. A few mm would help a lot.
Old 07-03-2019, 03:53 PM   #8188
dpetro1
Member#: 487500
2018 WRX
Agreed on the 255/40. If you want a 35 series then do a 265/35/18. Pretty popular size on this chassis.
Old 07-03-2019, 04:05 PM   #8189
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Those 255-18's will be about 0.8" shorter than the OE 245-19's (per specs page for Michelin PS4S tires over on Tire Rack, other tire models would be similar).
0.4" more tire to fender gap, 0.4" less ground clearance.
Norm
Old 07-03-2019, 06:32 PM   #8190
FA20DIT.NI
Member#: 503051
I created my own thread for this question but how badly does a +38 offset on a '15+ car as in stress on wheel bearings and affect the handling for dailyish driving? I'm not tracking and only occasionally throw it around in the corners but don't want to void my CPO warranty and don't want it to be less reliable.
FA20DIT.NI is offline   Reply With Quote
Old 07-03-2019, 11:37 PM   #8191
james-30
Member#: 430450
2019 STI
Lapis Blue
Just bought new wheels for my 19 sti. Wedsport 18x9.5 +38. I'm starting to wonder if they are going to fit without rolling finders. 265/35/18 tires. Im lowered on FA 500's 9k swift springs. -2.5 front camber -1.8 in the rear
Im currently on 18x9.5 +42, 265 35 tires and do not rub anywhere. Just not flush enough for me witch is why I bought the new +38 wheels. Fingers crossed everything fits
james-30 is offline   Reply With Quote
Old 07-04-2019, 01:13 AM   #8192
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
^^^Itís most likely going to rub, at least on big bumps.
skeeter281 is offline   Reply With Quote
Old 07-04-2019, 10:59 AM   #8193
jcb-memphis
Member#: 461117
2019 STI
Lapis
Default Report of a nice fit
Installed 4 MachV Crucial rims (gloss black) on my 2019. Stock suspension.
Tires : Michelin Pilot Sport A/S 3+ in 265/35-18 from Tire Rack. OEM TPMS units.
Done at Mach V motorsports in Sterling VA.
Flawless install. Not a mark. Perfect stance.
Car feels a LOT nicer at 18"...same feel but no harshness, so only better. Tires turn in better than the V105 yokoham oem tires. Noise is less (those had 1500 miles only). Looks of the set up: awesome.
Net loss per corner: 5.5 pounds.
Highly recommended. Great shop. Great wheel. And the tires are awesome. Note, have had a lot of time on track in a prior high HP car and can say that the car now feels like a 996 with custom kw3 corner balancing and hollow bbs wheels with top tier rubber. Could not say a nicer thing about the car's handling. Subaru got this car right. They should sell these wheels and these tires with the car stock. (that would kill the aftermarket though).
jcb-memphis is online now   Reply With Quote
Old 07-04-2019, 12:23 PM   #8194
dpetro1
Member#: 487500
2018 WRX
Post up some pictures!
Old 07-04-2019, 02:04 PM   #8195
james-30
Member#: 430450
2019 STI
Lapis Blue
Originally Posted by skeeter281 View Post
^^^It’s most likely going to rub, at least on big bumps.
Yea, figuring Im probably not going to get away without rolling finders. Have a friend with very similar setup but running a 275 tire. He has rear finder rolled completely flat. no rub
Current set up: FYI these wheels/tires are for sale. Practically brand new, 300 miles at the most. Not a mark on them. Forged monoblock 19lbs each 18x9.5
https://i.imgur.com/ctzYcYs.jpg
https://i.imgur.com/EYYdFUJ.jpg
New Wedsport wheels:
https://i.imgur.com/NTZHjl5.jpg
Old 07-04-2019, 02:30 PM   #8196
jcb-memphis
Member#: 461117
2019 STI
Lapis
Default Mach V Crucial wheels with 265/35/18 Mich PS A/S3+ on 2019 Lapis STI Stock Height
Stock suspension on 2019 STI, Michelin Pilot Sport A/S 3+ from Tire Rack in 265-35-18 on Mach V Motorsports (fastwrx.com) Crucial Wheels in gloss black. Wheels are +42mm offset, 18 x 9.5.
Lost of 5.5 pounds per corner. Drives amazingly well. No rub. Smoother ride with better turn in.... amazing shop too (Mach V). I was very impressed by the staff and Dan the owner was superb. My first time there after some mail order things and it was a great experience. He has a lot of subaru wheels in the store to look at too as hands on is important.
jb
https://imgur.com/RjVfVW5
https://imgur.com/aOlb11R
https://imgur.com/bRTKBGa
https://imgur.com/paZRUSQ
https://imgur.com/rtTKE0V
Old 07-15-2019, 10:51 AM   #8197
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
I am looking at the O.Z. Racing Alleggerita HLT 18x8.5et55 wheels. Tire rack says they fit my 2019 WRX STI. I have found a few posts about these wheels, but non specific about the 2019. I am about 99% sure they fit. Looking for confirmation from someone who has them.
Can't find many vendors for O.Z. Racing. I am trying to get them in Matt Graphite or the Titanium Tech. Tire Rack has a lot of the colors but not these.
Old 07-15-2019, 11:11 AM   #8198
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
ZE40 18x9 +35, 265/35
Old 07-18-2019, 12:54 AM   #8199
96JZA
Member#: 463078
2018 WRX Limited
Crystal White Pearl
Need to add a Barber track outline to that gurney flap my guy
jb
96JZA is offline   Reply With Quote
Old 07-18-2019, 08:56 AM   #8200
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Or either of the NJMP outlines . . .
Norm
