Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Old 11-06-2019, 05:31 PM   #1
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
Default Inconsistent Aggressive Vibration at high speed
Hi,
I had been having what sounded like power steering issues, and this just started happening with the cold weather. I was thinking that it maybe was a bad hose.
Then all of a sudden I was driving around 70 on the highway and the steering wheel starting vibrating like crazy, and I let off the gas and it seemingly went away. It happened again randomly around highway speed. I remember reading that it could be power steering related, but I'm not sure how that would work
I ended up bringing it in and the mechanic said that It seems as if the passenger CV boot split again, which was replaced about a year ago. I'm wondering if this is because of my wastegate exhaust or perhaps the axle had enough debris from before to damage it again?
The mechanic said he gets vibration under heavy loading, is this normal for an axle issue? It's a 2007 wrx with ~70k miles.
Imprezaspeed07 is offline   Reply With Quote
Old 11-07-2019, 03:04 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Having such a pronounced vibration be intermittent is definitely unusual. I guess I would start with a new axle (to fix the CV boot issue), perhaps some heat shielding (if you think heat from the WG may be causing the CV boots to fail), and see how things go from there.
Old 11-14-2019, 04:49 PM   #3
BDZ
Member#: 246673
Usually here in the northeast we look to see if we have the back side of the wheel full of snow, ice, mud, dirt when it does that.
Not sure if you've been anywhere to get anything on the back side of the wheel to create that much of a balance issue where you're located but it happens here every winter.
BDZ is offline   Reply With Quote
Old 11-20-2019, 09:22 PM   #4
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
So they replaced the axles, then bled air from the power steering system, replaced the gasket at the power steering bolt, and rotated the tires. They said that rotating the tires seemed to help the most.
It is better but I still had a bit of vibration driving it home. Only at 75ish on the highway in a corner. They said it would be good to rebalance the wheels as the next option. I think I may try that but I think it may be the power steering due to the fact it happens when turning. If balancing the wheels doesn't help I'll probably try to replace the reservoir hose and washer... Thoughts?
Thanks in advance
Old 11-21-2019, 02:33 AM   #5
fuelMuncher
Member#: 301554
2002 WRX Wagon PSM
2002 WRX Sedan JBP
My guess is the heat from the wastegate is warping some component
fuelMuncher is offline   Reply With Quote
Old 11-22-2019, 12:00 PM   #6
BDZ
Member#: 246673
Do you by any chance have a bent wheel?
Old 01-21-2020, 10:16 PM   #7
Imprezaspeed07
Member#: 154863
2007 Impreza WRX
World Rally Blue
Interesting comment about the waste gate, the wastegate, when installed originally was bent around the axle, but to get it to fit the guy ground the interior of the bend, which left an open hole dumping exhaust gas onto the axle. They ended up replacing the axles and rotating tires and that seemed to fix it. The wastegate exhaust tube was fixed sometime ago however, but this must’ve caused enough damage to trash the grease and cause it to fail now. Is it common that wastegate exhaust damages parts?
And the wheels should be good to go.
Only option was to rebalance the tires but I haven’t had an issue since the repair.
Old 01-27-2020, 04:20 PM   #8
gard
Member#: 511121
2014 WRX
I had a similar issue last week, turned out to be snow/mud in the wheel, went away when it warmed up
gard is offline   Reply With Quote
