Welcome to the North American Subaru Impreza Owners Club Friday February 22, 2019
Old 12-26-2018, 09:29 AM   #101
mavizao
Member#: 488216
Originally Posted by bp05obxt View Post
What are the head studs torqued to?
Its a five step process, with the last step being a 150 ft-lb (35, 70, 105, 150 and 150 again).
We have followed these:
https://www.iagperformance.com/v/vspfiles/downloadables/instructions/IAG/CLOSED-DECK/IAG-Closed-Deck-Install-Guide-14-v.14.pdf
Shortblock was brand new IAG Stage 4, heads were resurfaced/machined.
mavizao is offline   Reply With Quote
Old 12-26-2018, 12:57 PM   #102
TurboJJ10
Member#: 119768
Originally Posted by mavizao View Post
Hello JJ,
Are you able to help me as well?
I have the IAG Extreme short block with all the options, and also a built head with +1 intake/exhaust Ferrea valves and BC Stage 3...
By IAG suggestion i used the Cooper fire version with the 14mm IAG studs torqued to the spec described in the manual.
I run a GTX3582R and i feed the car E100 using 8x 1700 ID injectors.
All fine and good, except the gasket hasnt lasted one lap on the Interlagos circuit (Brazil) at 2 bar. It even started leaking at 1.7 bar.
Water did not get past 100c...oil did
not go past 110c. All logged and checked using Motec.
Then the car spit water in the windshield and started spittinf liters.
This is my second gasked attemp, first was a Cosworth gasket on the Cosworth shortblock.
I contacted IAG and they said my current shortblock would not work with the new fire lock because of distortions when it is torqued for the gaskest.
Adam is helping me with information, but i think it is a bit confusing. Could you explain better here?
Can i use the current shortblock to install this new gasket? Is it expected to be much better than cooper version? Or even double oringing?
Im trying to build a race STI, got everything else working (sequential gearbox, dry sump etc)...but cant get an engine to run a full hot lap at 600 whp! Please advice on the gasket situation!
The only way to use the new Fire-lock version is to have machining done to your block. If the block was 14mm from the start AND was shipped after 4/19/2018, then we can machine the groove for you to accept the Fire-lock ring. If this is a block that was shipped before that date, it will require honing to the next size piston. I hope that helps.
TurboJJ10 is offline   Reply With Quote
Old 12-26-2018, 02:10 PM   #103
mavizao
Member#: 488216
Makes more sense now, understood.
Block was 14mm from the start, but shipped november/17.
I dont want to do this honing and replacing pistons, therefore i think i will proceed to JE proseal + double oring.
Is that something that can be safely raced up to how much boost/hp?
By raced i dont mean just a hot lap, but many laps in sequence!
Old 12-27-2018, 12:26 AM   #104
stu
Member#: 25768
2003 GEN 2 GTX35R
OFCD Bugeye Slowbaru
You should easily be able to run 40 psi on a gen 1 gtx with proseals. not sure how your lifting the heads on 30 psi
stu is offline   Reply With Quote
Old 12-27-2018, 06:49 AM   #105
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
its is my understanding that JE MLS don't work nicely with o-rings, I brought this question up earlier in this thread
Hyper is offline   Reply With Quote
Old 12-27-2018, 07:22 AM   #106
mavizao
Member#: 488216
That is weird.
IAG considers these options as the best:
#1 IAG Fire Lock
#2 JE + double oring
#3 IAG Cooper Fire
I got that on an email from them. It was not specified which JE, though i only see one model for sale.
About the gaskets vs 2 bar, i find it very odd too, however i am not the only one.
I was fine with 2 bar on the dyno runs (some 6 runs, generating 600 whp)...but on the track, real test, hasnt lasted ONE lap...thats why im questionong racing. Many proven setups here or everywhere do not last a single lap when the car is really demanded. I need something to last dozens of laps, so i have no problem lowering to some 430whp, i just need something reliable and i am finding out 600whp at the track on the 2.5 is anything but reliable!
Old 12-27-2018, 12:47 PM   #107
TurboJJ10
Member#: 119768
That is weird.
#1 IAG Fire Lock
#3 IAG Cooper Fire
If you are intending on double o-rings, I strongly suggest stainless wire not copper. If you have any additional questions, shoot me an email.
Old 12-29-2018, 01:46 PM   #108
delim
Member#: 252448
2011 JDM GRB Spec C
Sunrise Yellow
Thank you JJ for providing to me instructions on how to install fire-lock gaskets 👍🏼
delim is offline   Reply With Quote
Old 12-30-2018, 11:51 AM   #109
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Not too go off topic. Are you sure your not cramming too much ignition timing
in it? The excessive cylinder pressure spikes "could", will deff
lift heads. Im not saying that is your sole issue is that, but its something to just look into imo. Your deff not running big boost, some something else is up.
Had 625+ on Cosworth. Leaked with 1.7.
Have IAG 14mm torqued to the specs described on the manual with the cooper fire. Leaked at 2 bar with less than 100km.
Now spitting about 3 liters of water per lap on the interlagos circuit. 2 laps, 7 liters, plus overheating from the gases going to the radiator/temp sensor.
Old 12-30-2018, 12:14 PM   #110
mavizao
Member#: 488216
I think 22 degrees at most! Other engines will usually see up to 26 in same conditions, so i wouldnt consider it too much!
Old 12-30-2018, 12:33 PM   #111
rexworx
Member#: 103232
GTX 3071R'd 11WRX
22* where? 22* at peak load in mid rpm. Say 4krpm. Quite different then 22* at wot in the up top rpm, say 7000+rpm. So that info is sort of useless for us to be helpful.
Not to come off like a dick...
Old 01-08-2019, 05:59 PM   #112
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Hello JJ,
Sorry for off topic
mavizao what are you using to run 8 injectors ?
I am looking for solution to run stock injectors and 4 ID1700CC
Bariga is offline   Reply With Quote
Old 01-14-2019, 01:27 PM   #113
stu
Member#: 25768
2003 GEN 2 GTX35R
Originally Posted by Bariga View Post
Sorry for off topic
Any standalone worth a damn should be able to run 8 inj
Old 01-14-2019, 02:37 PM   #114
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Link G4 or G4+ will run 8 injectors. I'm surprised adaptronic will not.
Old 01-16-2019, 01:48 PM   #115
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
no shiiiiit
My question is where the **** do you put the 2nd stage at ?
Only setup i saw and know is APS and i dont think u can get that anymore
My Adaptronic can run 12 injectors
Goal is to run Stock injectors + ID1700X
Old 01-16-2019, 01:55 PM   #116
subbi7
Member#: 241967
02 wrx
Look at ebay.
subbi7 is offline   Reply With Quote
Old 01-16-2019, 04:05 PM   #117
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Found an outfit called CDF racing selling them for arms and legs.
Old 01-20-2019, 03:34 PM   #118
stevieturbo
Member#: 20366
If you buy the right Adaptronic...it could run more injectors than any Subaru would ever need.
As with most brands of ecu, they sell different models with different abilities.
stevieturbo is offline   Reply With Quote
Old 01-20-2019, 03:38 PM   #119
stevieturbo
Member#: 20366
no shiiiiit
What do you mean "where do you put the 2nd stage at ?"
Do you mean where do you install the other injectors ? Wherever you want to install them.
Adapt and overcome...it isnt that difficult.
Old 01-20-2019, 03:43 PM   #120
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
8 injectors? Pfft:
https://www.ebay.com/itm/Haltech-Eli...QSP2:rk:2:pf:0
Maybe check with Aluminati for multiple injector setups:
https://forums.nasioc.com/forums/sho...ight=aluminati
Old 01-22-2019, 12:24 AM   #121
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Oh **** thank you so much finally some one made dual stage tgv
Originally Posted by 2slofouru View Post
8 injectors? Pfft:
