Welcome to the North American Subaru Impreza Owners Club Wednesday February 20, 2019
Old 01-20-2019, 01:09 AM   #1
scwwrx
Member#: 486548
Default Squeaking noise.
Alright guys so I've began to hear a noise from my 13 WRX hatch. It sounds like a squeaking/squeal coming from the front of my vehicle. Doesn't happen with my breaks and have a ton of life left in the pads and rotors so I don't believe that is the issue. Have also tried to pay attention to if it may possibly be coming from the suspension or a component of my suspension, and don't believe that to be the issue either.
I've noticed the squeaking is most prominent when my clutch is engaged or when my car is in gear. I have cruised down the road in neutral and don't hear a thing and have pushed in the clutch while driving and had the sound completely stop. I know my explanation of my issue is vague but I wanted to ask if anyone else has had this issue and what the solution may be!
Thank you!
scwwrx is offline   Reply With Quote
Old 01-20-2019, 08:57 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Since it changes with the clutch pedal, likely a noisy ToB (throw out bearing). Many threads about newer Subaru with this.
Old 01-20-2019, 09:47 AM   #3
rtv900
Member#: 428511
2016 STI
I have the same issue with a utility vehicle of mine.
when the 4 wheel drive is engaged it squeels like all hell, but when I'm in 2 wheel drive it stops.
Sounds like your situation, as if engaging the drivetrain creates it.
If it is a constant sound I'd say maybe CV joints?
Before somebody jumps me and points out the CV joints rotate whether you are in gear or not, yes I know, but having them engaged through the drivetrain will put loads on the balls inside rather than them simply 'following' around in neutral.
total shot in the dark as I'm sure you know these issues are ultra difficult to help with online
rtv900 is offline   Reply With Quote
Old 01-20-2019, 04:37 PM   #4
scwwrx
Member#: 486548
I might look into that. My clutch isn't slipping or anything but it does have 72,000 miles on it so I could see a few thing being warn out.
Old 02-12-2019, 11:53 PM   #5
Alittlewhitewagon
Member#: 497709
Default Most likely the clutch
I have a similar noise to what i think you are describing. for me if the car is in neutral you hear the noise, but if you push in the clutch, the noise goes away.
Alittlewhitewagon is offline   Reply With Quote
