Welcome to the North American Subaru Impreza Owners Club Wednesday December 13, 2017
Old 11-15-2017, 10:40 AM   #4526
Mach V Dan
Member#: 12029
Originally Posted by Wisco_WRX_22 View Post
I have a 2013 WRX Limited Sedan in white pearl...
Choice 1: 18x8" +48mm Sparco Assetto Gara with 235/40 18 OR 245/40 18
245 is too wide for an 8" wheel. I would run the 235 on the 8" wheel, if anything, but I'd prefer to just skip to the 8.5" wide wheel and the wider tire size below.
Choice 2: 18x8.5" +45mm Enkei TS-10 with 255/35 18 OR 245/40 18
255 is again 10mm too wide. I'd just run the 245/40R18. That's the stock STI tire size, and it fits an 8.5" wheel perfectly. At +45 you'll not have any rubbing.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 11-22-2017, 03:14 PM   #4527
teewrxx
Member#: 455777
2013 WRX Hatch
Plasma Blue Pearl
Enkei T6s
Hey y'all,
Tirerack.com doesn't list an 18x9.5 for my car, the 2013 wrx hatch. But if i set a brz as my car, it has an option of the rear wheels being 18x9.5 with an offset of 45. My question is, will I run into fitment problems with that wheel and an 265/35 18 tire? The bolt pattern matches at 5-100 but i'm not sure what the bore diameter of the wheels are. Will I have problems when driving the car with full capacity, 4-5 passengers? Thanks y'all!
The car is on stock suspension.
teewrxx is offline   Reply With Quote
Old 11-22-2017, 03:41 PM   #4528
rich260z
Member#: 348236
2012 WRX Hatch
DMG
Are they the Enkei Raijin? They should fit on stock suspension, hub bore is the same, but the type of tire you get might force you to roll the rear fenders.
rich260z is offline   Reply With Quote
Old 11-22-2017, 05:13 PM   #4529
teewrxx
Member#: 455777
2013 WRX Hatch
Plasma Blue Pearl
Sorry, I failed to put the wheel. Its the T6s. Should I stick with the stock size tire?
Old 11-22-2017, 05:16 PM   #4530
Obviously Tyler
Member#: 395955
2016 WRX Premium
Rock Chip Metallic
Originally Posted by teewrxx View Post
Enkei T6s
Hey y'all,
I'm running exactly that on my 2016 WRX. 18x9.5 +45 with 265/35 tires. No rubbing issues. I'm lowered on RCE yellows and -1.5* of camber all around. But I'm fairly confident they'll be fine on stock suspension as well.
I'm also pretty sure that the 11-14 and 15+ cars share almost identical fender space and offsets. But I'm not sure if there's any variances from sedan to hatchback.
Obviously Tyler is offline   Reply With Quote
Old 11-22-2017, 06:28 PM   #4531
Mach V Dan
Member#: 12029
Originally Posted by Obviously Tyler View Post
I'm running exactly that on my 2016 WRX...
They are different cars with totally different sheet metal, and they have different clearances. Your experience with a 2016 is not helpful for someone with a pre-2015 car.
--Dan
Mach V
FastWRX.com
Old 11-22-2017, 06:30 PM   #4532
Mach V Dan
Member#: 12029
...18x9.5 with an offset of 45. My question is, will I run into fitment problems with that wheel and an 265/35 18 tire?
You will have to roll the rear fenders.
If you don't roll the rear fenders, definitely Yes. If you do, maybe still Yes.
--Dan
Mach V
FastWRX.com
Old 11-22-2017, 08:14 PM   #4533
Obviously Tyler
Member#: 395955
2016 WRX Premium
Rock Chip Metallic
--Dan
Mach V
FastWRX.com
I know. But stock offset is the same on both cars and fender clearance is very very close even with the difference in bodies. 18x9.5 +38 (common) fits about the same on both generations. At least the sedans.
Old 11-23-2017, 09:51 AM   #4534
curren2007
Member#: 478112
Default I need help
Dear friends!!! I plan to install the Advan RZ2 r18 9.5jj +45 offset wheel disks with the tire Advan Neova AD08 245/40 r18 on the Impreza WRX STI 2010. Would they rub against the rear fenders? Will they stand on Brembo in front?
Thanks for any answers !!!
If you have a photo with such parameters of the disks on the car, I will be grateful !!!
curren2007 is offline   Reply With Quote
Old 11-28-2017, 05:33 PM   #4535
teewrxx
Member#: 455777
2013 WRX Hatch
Plasma Blue Pearl
--Dan
Mach V
FastWRX.com
--Dan
Mach V
FastWRX.com
Thank you Tyler and Mach V!
What if I run the 245 on the wheel? will it fit? Also am I to expect a "harsher" ride on 18's versus the 17? will I also "lose performance" as other people say?
Old 11-29-2017, 01:51 PM   #4536
Mach V Dan
Member#: 12029
Yes.
Yes, a little.
What other people say what exactly? Generally speaking, the 17" wheel/tire setup will probably be lighter, so maybe there's some difference there. Could you perceive it? Probably not.
--Dan
Mach V
FastWRX.com
Old 11-29-2017, 03:55 PM   #4537
teewrxx
Member#: 455777
2013 WRX Hatch
Plasma Blue Pearl
Yes.
Yes, a little.
--Dan
Mach V
FastWRX.com
Thank you Dan. Ok so running 235/45R17 on 17x9's will i experience any rubbing with a loaded car on stock suspension?
Old 11-30-2017, 11:32 AM   #4538
Mach V Dan
Member#: 12029
That depends entirely on the wheel offset.
--Dan
Mach V
FastWRX.com
Old 11-30-2017, 07:17 PM   #4539
teewrxx
Member#: 455777
2013 WRX Hatch
Plasma Blue Pearl
--Dan
Mach V
FastWRX.com
+45 offset.
Old 12-04-2017, 03:41 PM   #4540
Hondabaru
Member#: 460590
+45 offset.
At +45 you should be fine, especially with a 235. I run a 17x9 +38 Rota Titan and a 255/40r17 RT615k+ (Which runs really wide) on stock suspension and I get minor rubbing in the rear over significant bumps. I hear them scrub a few times a week tops. Lowering soon and adding camber which I'm hoping will alleviate the rubbing.
Hondabaru is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
