07-15-2012, 04:16 PM | #226 |
Member#: 206851
Vehicle:56 Belair Pro Street |
I've got a 1994 Ej20g head I'd like to let you use to test
10-05-2012, 02:24 PM | #227 |
Member#: 45715
Vehicle:1995 2.?L miami vice Heavy Metal |
selling a EJ25 SOHC Big Plenum Short Runner manifold:
http://forums.nasioc.com/forums/show....php?t=2415525 |
10-05-2012, 02:38 PM | #228 |
Member#: 114101
SCIC
Vehicle:93 Impreza L Swap |
Any thoughts on the v5/v6 JDM manifold? Looks a lot different from most other subaru manifolds. Plenum looks significantly larger than the stock GD manifolds, but what disturbs me is the runners look the driver's side look longer than the passenger's... doesn't look like it'd flow evenly to me:
10-07-2012, 01:08 PM | #229 | |
Member#: 333285
10-09-2012, 04:55 PM | #230 |
Member#: 225851
South East
Vehicle:07 Spec Wannabe Limited in San Remo Red |
Might be the space for inlet pipe!
11-02-2012, 01:57 PM | #231 |
Member#: 200436
Vehicle:2004 Forester XT Black |
I'd really like to know how the Grimmspeed ported intake manifold flows. I have TGV deletes, ported throttle body and a bowl blend/minor port on my heads. Need to keep TMIC
11-02-2012, 06:23 PM | #232 | |
Member#: 217563
South East
Vehicle:2006 Sti 12.68 @ 108 321WHP 422WTQ dynojet SAE |
To close to build time now for me to offer again |
11-20-2012, 08:29 AM | #233 |
Member#: 200436
That's a good enough answer for me. If it's not worth testing I think I'll pass and spend my money on something more worth while.
11-20-2012, 12:33 PM | #234 | |
Member#: 217563
South East
11-24-2012, 03:15 PM | #235 |
Member#: 220906
hoping to get flow and dyno results from this shortly
11-25-2012, 11:21 PM | #236 |
Member#: 182375
SWIC
Vehicle:2013 Sti World Rally Blue |
11-26-2012, 05:23 AM | #237 |
Member#: 220906
Back to back...car just went to the track and broke the trans and diff, so I am putting this on and another tune to see what the results are
02-21-2013, 11:12 PM | #238 |
Member#: 236349
Vehicle:1993 Impreza OD Green |
Intake manifold test-dyno version is coming!
Stay tuned. |
02-22-2013, 12:00 AM | #239 |
Member#: 182375
SWIC
How high will the test car rev? What sort of mod list? Just guessing from your work before it will be built heads ported, cams springs, etc and a 75 lb/min or more turbo
02-22-2013, 12:27 AM | #240 |
Member#: 333602
W. Canada
Vehicle:2012 STi DGM |
02-22-2013, 01:55 PM | #241 |
Member#: 103631
Vehicle:2004 STI Gray |
I know that all testing is complete, but if you ever have time, like you don't work hard or anything jk, do you think you could flow test any of the manifolds with the throttle plate horizontal like most reverse manifold setups? It would be interesting to see and have actual data to see delta between cylinders other than to tell people "my car runs fine"
Just a shot in the dark |
03-12-2013, 09:16 PM | #242 |
Member#: 284392
South East
Vehicle:2011 STI Limited Plasma Blue Pearl |
Corsa Veloce just got bought by Process West and put out a new manifold. Any data?
03-19-2013, 05:26 AM | #243 |
Member#: 187834
Vehicle:06 2.5i impreza Red |
So in conclusion our 2.5i manifolds not only can hold boost but flow great, which is why I'll stay Supercharged and enjoy all my intake manifold has too offer.
03-19-2013, 06:08 AM | #244 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
04-12-2013, 06:48 PM | #245 |
Member#: 211974
SWIC
Vehicle:2004 WRX STi PTE6466 2002 Sentra SE-R Spec V |
I just sent ASF Machine an email about trying to get hold of one of these ported 2.5i intake manifolds for my build. I have been wanting to avoid the Cosworth manifold; $1100 for a chunk of cast aluminum that doesn't flow as well as I would think it should. I was told about the 2.5i IM by my tuner and it sounded like a pretty good option. It keeps sounding better and better now that I have learned of ASF Machine's porting work and testing. I figure with the flow numbers they are showing I should be able to put it to good use. We are expecting my setup to run 35+ psi on e85.
Engine: Sleeved EJ257 done by LA Sleeve Cosworth pistons Cosworth rods Cosworth oil pump 08+ nitrided crank ACL bearings MAPerformance H11 head studs Hand ported/polished heads Ferrea stock size valves SuperTech 82lb springs/titanium retainers GSC S3 282 cams AMR UEL big tube header AMS 900x V-band rotated kit Precision PTE6466 Tial MV-R 44mm EWG Tial Q 50mm BOV APS DR525 FMIC Boomba Racing top feed fuel rails TiC composite TGV housings FIC 2150cc injectors -8 feed fuel line Aeromotive FPR Walbro 460lph fuel pump hardwired Megan Racing catback exhaust Cusco catch can |
04-16-2013, 03:25 PM | #246 |
Member#: 140832
Just received mine last week!!!! When I opened the box I was speechless! Can't wait to see how it performs!
04-16-2013, 05:04 PM | #247 |
Member#: 134764
RMIC
Vehicle:04 sti java black pearl |
Where is that from? ASF?
04-16-2013, 05:15 PM | #248 |
Member#: 199536
Vehicle:2018 WRX Silver |
^this x2
04-16-2013, 05:18 PM | #249 |
Member#: 140832
Yes, this intake manifold is from ASF
04-16-2013, 05:19 PM | #250 |
Member#: 260314
Vehicle:2007 STI silver gray metallic |
What the hell is that?
Looks like it is based on a NA intake. Who's throttle body? |
Similar Threads | ||||
Subaru Cylinder Head Flow Database | ASF Machine | Built Motor Discussion | 57 | 02-22-2021 08:55 PM |
best flowing OEM intake manifold | Gamble_WRX | Built Motor Discussion | 20 | 05-25-2010 09:52 AM |
WTB high flow intake manifold and internals | modusvivendi | Private 'Wanted' Classifieds | 2 | 08-06-2009 11:25 PM |
'04 Plastic Intake Manifold Flow Numbers | SOLUTION | Normally Aspirated Powertrain | 1 | 03-14-2006 08:03 PM |
AVO high flow intake manifold | aspera | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 09-10-2002 09:58 AM |
