#101 | |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd |
![]() Quote:
#102 | |
Member#: 262719
NESIC
Vehicle:02 WRX PSM with rust accents |
![]() Quote:
And Fuji, thank you SO much for this thread and similar ones elsewhere... monumentally helpful and answers a ton of questions about things I can't afford ![]() |
#103 | |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
![]() Quote:
#104 | |
Member#: 262719
NESIC
![]() Quote:
#105 |
Member#: 104098
NWIC
Vehicle:97' LGT 2.3 Dstroke Rotated BW S256 6speed |
![]() SO after reading this and thinking about all the combinations, could a guy build a 2.0L and use the +2mm rods commonly used for de-stroking a 2.5L, and just use like Mahle stroker pistons made for a 79mm stroke? So I guess it would be a longer rod 2.0L. Would that make it more reliable and have less side loading of the piston, or would it not even be worth doing. I'm really curious?
Although I'm seriously considering a budget 2.35 de-stroker, +2 rods, 9.0:1 CP shelf pistons with 08' wrx D25 heads, Crower 272 cams, BC springs and retainers, with like a BW turbo 35R size or a hair smaller. I wonder what the CR would be with the CP psitons, 50cc wrx heads and de-stroked with +2? Just a smooth revving street car with higher compression to help with mileage and a little better off boost power. Great thread! |
#106 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
![]() you could do that 2.0L but you'd have really low compression ratio.
Run your numbers for CR. It isn't hard. |
#107 |
Member#: 3687
![]() a couple 2.1's coming
#108 |
Member#: 230144
![]() Wow lots of words, good little hand book for beginner builders
#109 |
Member#: 299625
International
Vehicle:2006 STi Black |
![]() Great info!
I think of doing this; EJ16 Crank (65.8 stroke) Steel sleeved closed deck 103mm CP-pistons with EJ257 pin location 9:1 CR Custom long rod 2.2L (2193.3cc) Twin-Scroll GT3076 12000rpm safe ![]() ![]() Do or don't? (Just finished a 103mm bore 2 cyl engine with equal stroke, produces 150hp at the drive wheel as N/A..) |
#110 |
Member#: 81102
South East
![]() a twinscroll turbo the size of a 30r won't make power at 12000rpm...
#111 | |
Member#: 33782
![]() Quote:
#112 |
Member#: 3687
![]() fast input shaft speed and everything connected to it in the tranny!!!
#113 |
Member#: 299625
International
![]() Gotit.
Will keep the 75mm crank instead then. 102mm bore will give a good 2450cc (sorry 'bout the misprint, there was supposed to be a 2x in front of the turbo charger.) |
#114 |
Member#: 239233
Vehicle:1998 LGT White |
![]() Has anyone used these Wiseco pistons in a EJ22T with 08+ STi crank (79mm stroke) and STi stock rods (130.5mm). I am doing the #5 thrust conversion, boring it 0.20 over and running EJ205 heads.
http://www.wiseco.com/Catalogs/Sport...baruToyota.pdf K602M975 If I am correct this piston would give me around a 8.2:1 compression ratio with EJ22E thickness headgaskets. |
#115 |
Member#: 3687
That should be right. |
#116 |
Member#: 182375
SWIC
Vehicle:2013 Sti World Rally Blue |
![]() Whats the EJ22E gasket thickness? I must be doing something wrong because I get that it's under 8:1 unless you use the .5-.6mm gaskets. I'm not sure which is the right thickness either. A lot of people said .6mm but Wiseco says the sti thickness is .5mm.
#117 |
Member#: 194452
Vehicle:The Mr. Wizard |
![]() EJ22e should be .051" IIRC
#118 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
![]() I love this thread. Great job Fuji. All the numbers in my head are on internet paper, subscribe.
~Josh~ |
#119 | |
Member#: 3687
![]() Quote:
Check out the PDF file in your post again. You can see the different rod lengths, and compression heights. But hey, my car drove fine with the stock EJ22T piston and WRX 50cc heads. Those pistons have DEEP dishes to get the 8.0:1 with the 40cc EJ22T chambers. |
#120 | |
Member#: 239233
![]() I found this yeasterday, now I am confused lol Quote:
#121 |
Member#: 182375
SWIC
![]() Your second quote is what I found to be correct. Around 7.6-7.7:1 with the pistons you mentioned, phase 2 79mm stroke crank with matching 130.5mm length rods, 1.37mm headgasket that I assumed is 98mm diameter, ej20 48-49cc heads. If you went with a .6mm gasket thickness still at 98mm diameter you'd get ~8.1:1 cr. If you used the phase 1 79mm crank and rods you'd have different numbers but you said you're doing the newer crank out of an sti which is phase 2.
#122 | |
Member#: 182375
SWIC
![]() Quote:
#123 |
Member#: 205134
![]() Fuji K. May I ask you a few questions for enlightenment.
1. If you change the engine CC ( 2.0 - 2.2) the bore size increases what else? Does the piston height, rod length, crankshaft remain the same? 2. How do you change the compression of the motor? By the piston dishes, rod length, piston height or crankshaft? P.S : I'm a newbie here still quite not into the engine stuff. Sorry bout that and thank you |
#124 | ||
Member#: 3687
![]() Quote:
2. If you plan to change just the compression ratio of the engine from what it currently is, it's best to do that by changing the piston's dish. |
#125 | |
Member#: 194151
Vehicle:2008 WRX RED |
![]() Quote:
im sure Fuji will chime back in and im no exert on subaru builds but everything you listed will change your compression ration. the more area you add to the combustion chamber the more you will raise you final displacement but in turn will affect your compression ratio. you cant mess with one without effecting the other. its all a balancing game their are so many factors that effect final displacement and final compression ratio. piston diameter, piston dish/crown, distance from piston top to pin center,rod length, crank diameter, head gasket thickness, head CC's, deck height & prolly more that i cant remember off the top of my head. |
nj building n00b wants to build his own gaming desktop | NJSwamplands | Off-Topic | 11 | 01-29-2010 03:50 PM |
I want to build my engine... HELP! | usmc 04sti | Built Motor Discussion | 1 | 08-30-2008 01:04 PM |
to build up my 2.0 or to build a 2.5 | pulser9 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 05-19-2007 08:13 PM |
Wanting To Build Engine But Have Questions | wrxxer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 10-04-2003 12:15 PM |
I want to build a rally car... but I don't know where to start. | majglow | Motorsports | 25 | 04-24-2002 12:55 PM |
