Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 05-05-2008, 03:20 PM   #1
AWDDownShift
Member#: 175205
2007 Impreza 2.5i
Default Delta Cam Regrind on the 2.5i
I've been reading up on the pre 06 cam regrinds with the boost in whp by 10-20 depending on currents mods and tune. There must be a difference in our cars because of the i-AVLS ... has anyone 06+ tried the regrinds? What are the effects ?
AWDDownShift is offline   Reply With Quote
Old 05-05-2008, 04:37 PM   #2
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
I would like to know the same.
Jerry Xu is offline   Reply With Quote
Old 05-05-2008, 06:07 PM   #3
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Call Delta.
Gr3en is offline   Reply With Quote
Old 05-05-2008, 08:09 PM   #4
GrundleJuice
Member#: 165749
can the 06/07's even use the 05 and previous cams? I imagine they physically fit the heads (maybe not?) but with the active valve copntrol there must be something else that plays into the controlling of the valves (maybe just cam pos. sensor?) I am also interested in cams but was told by someone (i think Cobb, maybe TWE, cant remember anymore) that there wasnt a cam for 06/07's yet.
GrundleJuice is online now   Reply With Quote
Old 05-05-2008, 08:20 PM   #5
AWDDownShift
Member#: 175205
2007 Impreza 2.5i
Well it must be different and i think more beneficial because of the i-AVLS?
I dont know im going to look up the number and give them a call.
BTW Gr3en thanks for stating the obvious
Old 05-05-2008, 09:26 PM   #6
GrundleJuice
Member#: 165749
cool.. cant wait to see what they say about the 06/07/08 cam options.
Old 05-05-2008, 10:56 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
The intake cams are completely different, as the i-AVLS uses dual cam lobes and different lifter buckets.
The exhaust cams may be compatible.
If someone downloaded the camshaft specs from the FSMs on the Subaru Techinfo site you would be able to see the lifter bores in each head, the cam journal sizes, and the cam lobe sizes, which would give you an idea of what is or is not compatible.
Pat Olsen
Old 05-05-2008, 11:22 PM   #8
zavier
Member#: 141189
2007 2.5i (NBP)
2018 STI Limited (ISM)
i've been talking to Delta for some time now and they said they are working on cams for the 06+ heads along with fully built heads...but unfortunately the site they gave me to check up on when they'd be available is still listed as "under construction"...
zavier is offline   Reply With Quote
Old 05-06-2008, 03:15 AM   #9
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Unfortunately, they're still all on one shaft.
Counterfit is online now   Reply With Quote
Old 05-06-2008, 09:54 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Oh yeah. I was thinking they had gone back to DOHC to do the i-AVLS.
Old 05-06-2008, 10:44 AM   #11
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
OMGHi2U
What you should have done in the first place.
Old 05-07-2008, 03:52 AM   #12
Counterfit
Member#: 124254
"The Scoobinator"
I wish they had.
Old 05-07-2008, 07:37 AM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
There is quite a bit of direct posting from Delta cam over on rs25.com.... Screen name is "subaru rally guy".
What's the widest tire that can be put on the 2.5i? SubieSubie Impreza Forum 21 07-25-2017 09:51 AM
Will the STi Front and Rear Bumper will fit on the 2.5i? GD6Noob Interior & Exterior Modification 7 04-30-2012 09:33 PM
Delta cams for the 2.5i (06-07) $600 Jerry Xu Normally Aspirated Powertrain 244 06-30-2009 01:07 AM
FS: SOHC Delta Cams Regrind maximumyin Engine/Power/Exhaust 10 12-05-2007 11:08 AM
Anyone running Delta Cam regrinds in the 2.0l wrx heads? LiquidForce Built Motor Discussion 3 05-30-2007 09:37 PM
