Welcome to the North American Subaru Impreza Owners Club Thursday September 16, 2021
Old 09-14-2021, 08:11 PM   #1
josh13wrx
Member#: 370711
Default 2020 STI inly 13lbs of boost
Hey everyone,
So I've searched and searched through numerous threads and websites but can't get to the bottom of why i can't get past 13lbs of boost. This issue began after tuning for the following mods.
- Delicious tuning Flex fuel kit Mk2 with Fuel Pressure sensor kit
- Delicious tuning GR Stumble fix kit
- Cobb 1050x
- Cobb AP V3
- Cobb EBCS
- AEM fuel pump
- AEM Inline wideband
- Cobb SF intake
- 3in catted Dp
- Perrin Catback
Tune is being done by Eric at torqued performance. He mentioned the logs show a possible boost leak. I've searched all boost/ vacuum lines and haven't found any issues. I even did a boost leak test at 20psi and no boost leaks. I've been at it for a week now and am completely stumped. Any help is appreciated. Thanks in advance!
josh13wrx is offline   Reply With Quote
Old 09-14-2021, 08:15 PM   #2
djoye
Member#: 50072
2017 STI
Checked and re-checked that the EBCS is plumbed correctly and connected to the correct ports and removed the restrictor pill from the stock boost lines if still using those?
djoye is offline   Reply With Quote
Old 09-14-2021, 08:19 PM   #3
josh13wrx
Member#: 370711
Yes tripled checked EBCS lines and restrictor pill is also removed
Old 09-14-2021, 08:25 PM   #4
josh13wrx
Member#: 370711
Old 09-14-2021, 09:41 PM   #5
K3rm1tth3fr0g
Member#: 508105
2002 Black WRX Wagon
VF39 + 4.44 5MT
Perhaps a bad map sensor...
K3rm1tth3fr0g is online now   Reply With Quote
Old 09-14-2021, 09:56 PM   #6
josh13wrx
Member#: 370711
Wouldn稚 the drivability of the car be affected more than just the lack of boost? The car drives fine just doesn稚 get past 13lbs of boost.
Old Yesterday, 08:26 AM   #7
SuperPete
Member#: 517987
I had issue when my inlet pipe was collapsing right before the turbo inlet, been tracking that for weeks until I put go pro in the engine bay and saw it myself, so try quizzing that hose by hand closest to the turbo, if you can move that, its your problem.
Also, make sure your EBC connected correct.
SuperPete is offline   Reply With Quote
Old Yesterday, 10:13 AM   #8
josh13wrx
Member#: 370711
I値l look into the turbo inlet issue. Boost controller is plumbed properly so I can rule that out
Old Yesterday, 10:45 AM   #9
horsePOOGAS
Member#: 450712
04 STi
Eric is a great tuner and was the tuner of my car. I had an issue that turned out to be a boost leak. I could only find it by using a smoke tester. For me it was my intake runners on the driver side.
But a smoke tester is a really helpful tool and can come in handy down the road if any other problems arise. I bought mine off of Amazon. If you do get one - spend the coin on a decent one with an inline fuse.
horsePOOGAS is offline   Reply With Quote
Old Yesterday, 11:01 AM   #10
K3rm1tth3fr0g
Member#: 508105
VF39 + 4.44 5MT
He already boost leak tested - he said that in the first post
Old Yesterday, 11:15 AM   #11
josh13wrx
Member#: 370711
Eric is great. This is the second Subaru he tunes for me. So I知 not second guessing his knowledge or tuning abilities. Thanks for the advice tho. Keep the ideas coming. I知 hoping someone can take a look at the log I posted and help me rule out a couple things.
Old Yesterday, 12:18 PM   #12
benflynn
Member#: 515308
Unhook the wastegate hose and see where she ends up, hopefully oberboost will catch it.
benflynn is offline   Reply With Quote
Old Yesterday, 12:19 PM   #13
benflynn
Member#: 515308
If it was a boost leak then the turbo is living way outside its flowmap
Old Yesterday, 12:40 PM   #14
Stretch18
Member#: 239822
2010 WRX
pandiculation
Do you know what your target boost levels are? You actually do get up to 16 psi, but not until close to 5,000 rpms. You can monitor TD Boost Error on the AP to see if you are off target.
Are you at elevation? Your boost pressure - absolute pressure is in the 13s. At sea level, 0 psi of boost is 14.7 psi absolute pressure. If that's not accounted for, that could be your issue...
Stretch18 is offline   Reply With Quote
Old Yesterday, 01:27 PM   #15
josh13wrx
Member#: 370711
Target boost is about 20psi. I知 at 2,655 feet above sea level. I値l monitor boost error. The 16 pounds I get seems like creep but I知 not 100% sure.
