Welcome to the North American Subaru Impreza Owners Club Thursday September 16, 2021
Old 06-05-2021, 09:09 AM   #26
heiche
Member#: 400179
2009 wrx
good advice. also, remove the oil cap while testing. that way you can tell if air is coming from the crankcase (and prevent blowing an oil seal)
heiche is online now   Reply With Quote
Old 09-10-2021, 02:22 PM   #27
cproo12
Member#: 520219
2006 Forester XT 5mt
Crystal Grey Metallic
Hey everybody, I know it's been a while, but I bit the bullet.
Pulled my engine, took the heads off, found the culprit to be exactly what I thought it was- ****ed exhaust valve on cylinder 3.
Here is the valve!:
https://i.imgur.com/1fXDvWL.jpg
Rebuilding the engine in my frat house dining room:
https://i.imgur.com/R4YxSva.jpg
Cam journals aren't that bad for original heads 190k miles... Previous owner probably starved em of oil because I have been ON THE DOT with maintaining this this.
https://i.imgur.com/jhDxhbQ.jpg
cproo12 is offline   Reply With Quote
Old 09-10-2021, 02:41 PM   #28
heiche
Member#: 400179
2009 wrx
Ugly valve - there's your problem! Nice workshop though.
Old 09-10-2021, 02:42 PM   #29
enduroxt
Member#: 310796
05 obxt
Huh. I can't see the picture.
enduroxt is offline   Reply With Quote
Old 09-10-2021, 02:48 PM   #30
heiche
Member#: 400179
2009 wrx
I had the same issue, but had to remove this from the start of the url:
"dereferer.org/?"
Old 09-10-2021, 02:55 PM   #31
enduroxt
Member#: 310796
05 obxt
Yeah. I was able to view the images.
Well, yeah that valve looks destroyed. Looks like you may have been driving on a tight valve for a while.
I'd set the exhaust valve clearance a little looser than target, but still within specs. IIRC, for the LGT/OBXT EJ255 platform, our official target is 0.35mm +/-5mm. I targeted 0.37mm.
Old 09-10-2021, 02:57 PM   #32
cproo12
Member#: 520219
Yeah the dereferer this forum uses can break imgur links sometimes.
If you are having trouble viewing them, type this link or copy paste manually:
imgur . com/a/GSiGLyf
Valve is CHOPPED up... But so glad it is this and nothing worse. Very easy fix (relatively lol, still had to pull the engine)
