Welcome to the North American Subaru Impreza Owners Club Thursday September 16, 2021
Old 08-22-2021, 02:47 AM   #26
usdmf
Member#: 526173
nice piece. Have any alternator clearance pics?
usdmf is offline   Reply With Quote
Old 08-22-2021, 08:47 AM   #27
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Did you mean power steering pump?
KillerBMotorsport is offline   Reply With Quote
Old 08-22-2021, 10:05 AM   #28
SuperPete
Member#: 517987
Is it possible to install it without taking manifold off or you need to lift the manifold to fit it in?
thanks
SuperPete is offline   Reply With Quote
Old 08-22-2021, 10:42 AM   #29
Marvick08GT
Member#: 469091
The whole purpose of this inlet is to allow installation with the manifold in place. The video shows it is fairly simple. I am using one on my Legacy because: Killer B! Enjoy!
Marvick08GT is offline   Reply With Quote
Old 08-22-2021, 11:31 AM   #30
Killfire
Member#: 420364
2013 STI Hatchback
I can get some if you want. I just have to pull off my alternator cover for a better angle. It is close but I don't see it touching.
Killfire is offline   Reply With Quote
Old 08-24-2021, 03:25 PM   #31
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
thanks
^ this
Old 08-24-2021, 03:29 PM   #32
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
And here are a couple pics on some shop cars...
2007 SG9 Forester STi:
2019 STi:
Old 08-24-2021, 03:30 PM   #33
benflynn
Member#: 515308
Originally Posted by KillerBMotorsport View Post
^ this
And with side feed fuel rails in place? Or the lines really?
benflynn is offline   Reply With Quote
Old 08-24-2021, 04:24 PM   #34
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We did an install on a 02 WRX. I believe those are side feeds. Intake manifold stayed on. Same with the VA chassis and stock fuel system.
Old 08-24-2021, 05:22 PM   #35
K3rm1tth3fr0g
Member#: 508105
2002 Black WRX Wagon
VF39 + 4.44 5MT
The 02 is sidefeed? The 2002 stock setup is topfeed
K3rm1tth3fr0g is online now   Reply With Quote
Old 08-24-2021, 05:40 PM   #36
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Maybe I'm remembering a GD STi. I know those are side feeds for sure. I'll check our tester list when I'm back in the office tomorrow. Pretty sure there was a GD in the mix.
Old 08-24-2021, 05:53 PM   #37
K3rm1tth3fr0g
Member#: 508105
VF39 + 4.44 5MT
2004-2006 STi is sidefeed.
All USDM EJ WRXs are topfeed.
Old 08-24-2021, 06:29 PM   #38
benflynn
Member#: 515308
05 forester def sidefeed
Old 08-25-2021, 07:16 AM   #39
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We're going to search for a local GD STi. My tech says the side feed fuel lines in the areas around the turbo inlet shouldn't be different enough to matter, but we're going to try and get a car here to confirm. The GDs we have installed test parts on have all been WRXs. If anyone has any visual aids showing the difference in the turbo inlet area, feel free to post or DM them to me.
Old 09-09-2021, 10:52 AM   #40
djoye
Member#: 50072
2017 STI
Finally installed mine, wasn't bad, but I did discover the world of AN fittings, so it took me like 8 hours just to decide what fittings I was going to use. Things to note: 2017 STI with a Blouch 1.5XT-R 10cm, Cobb fuel lines, BPV, Crawford AOS, and OEM/JDM STI TGV housings. Replaced a Perrin inlet.
The Killer B instructions have good information, but one thing that I'd emphasize for easy installation is to consider how the coupler is clocked in relation to where the turbo sits. I clamped the coupler to the pipe, then had some difficulty getting it to seat on the turbo, then took more care in clocking the coupler and was able to easily get the coupler onto the turbo with about as much resistance as you would expect from a tight coupler. Once I had the coupler in a good position, I used a paint pen to mark several areas on the coupler and tube so I could line it up again as needed.
More notes:
- Get the coupler properly clocked toward the turbo to ease installation, otherwise the coupler will bind and fight as you try to push it onto the turbo
- I did have to bend the PCV hard pipe for clearance (per instructions)
- Absolutely consider installing fittings before installation (per instructions), fittings closest to the intake manifold might not screw in with the IM in the way. You can install the inlet with the plug installed into the far hole near the turbo, if you need to put a fitting in there, that'll probably need to be done after installation.
- Removal of the alternator and setting aside the PS pump is a must (per instructions)
- I trimmed 1/2" from the Killer B inlet side of the coupler
- I trimmed 1/4" from the turbo side of the coupler and then some for minor adjustments
- I should have trimmed the ~3/4" from the BPV return hose because the area is cramped due to Cobb fuel lines and the BPV hose can become kinked
Finished product (the white on the coolant hoses is from Subaru coolant conditioner, think I'll pass on that next time):
PS pump clearance, etc., doesn't even touch:
My first coupler trim on the turbo side was straight, I clamped the coupler to a 2" pipe and used the clamp as a guide for a clean cut with a blade, but something prevents that straight cut from allowing the coupler to sit straight on the turbo (intake manifold bulge + turbo position?), so I then had to trim at an angle. Had this same problem when trimming the Cobb inlet, my Perrin inlet fit perfectly on its own. My cuts came out OK and with enough to clamp the coupler. The coupler is tight enough that it's not going anywhere, but I'm going to keep an eye on it. I should've installed the pipe without the coupler to see where it sits in relation to the turbo like killfire's picture.
BPV hose is awkward because of the Cobb fuel lines consuming space under the throttle body that the BPV hose would typically occupy and was an issue with my past Cobb and Perrin inlets; the width of the aftermarket inlets may also contribute, so next time I have the TMIC off, I'm going to consider trimming at least 3/4" off of that BPV hose @ inlet. Fortunately the hose isn't crushed. When the BPV hose is crushed, you hear a ~250Hz descending "BOOooo" sound when the BPV opens, kinda like how turbo cars sounded in some older racing games.
The inlet feels sturdy installed and consumes less space than a silicone inlet. I can't yet objectively say anything about performance because I had disconnected the battery for a couple days so the car is now relearning. I do believe I feel an improvement all around, but I think that's either the ECU relearning or ~10F cooler weather. I'll have to see how it feels in the long term.
djoye is offline   Reply With Quote
