Welcome to the North American Subaru Impreza Owners Club Thursday September 16, 2021
Old 08-30-2021, 03:04 PM   #1
mava1395
Member#: 523966
Default Misfire at idle, have done some things but still at a loss
I have a 2007 STI and I have been having an issue of misfiring at idle. I cant seem to pinpoint the problem. I am getting a p0304 or a misfire in cylinder 4. The car is only misfiring lower than about 1000 rpm and does it intermittently. So it will misfire for a few seconds then clear up for another few. Then misfire for a few more then clear up again. I checked the injector on cylinder 4 and even replaced it with another brand new stock injector and the issue is still there. I changed coils around and the misfire is still on cylinder 4. I even changed out the plugs and it's still having the same issue. I checked for vacuum leaks, fuel leaks, anything leaking but everything checks out. My fuel pump when priming is very loud. It's a walbro 255. I wanted to see if a bad fuel pump could possibly cause a misfire in cylinder 4 because I know it already runs lean as it is. Please help!!!
mava1395 is offline   Reply With Quote
Old 08-30-2021, 03:25 PM   #2
JSR84
Member#: 469585
2009 STi
Compression and leak down test.
JSR84 is offline   Reply With Quote
Old 08-30-2021, 06:35 PM   #3
mava1395
Member#: 523966
Should I get all 4 checked? Or just the one?
Old 09-04-2021, 01:17 PM   #4
13WRXGrey
Member#: 523309
2nd this
Might as well do all 4. I would for peace of mind.
13WRXGrey is offline   Reply With Quote
Old 09-04-2021, 03:54 PM   #5
JSR84
Member#: 469585
2009 STi
Might as well, but do 1 first, if it shows a bad result, itíll save you from having to do the rest
Old 09-05-2021, 08:46 AM   #6
Jp925
Member#: 510046
Howís your oil consumption? How many miles on the motor?
For what itís worth I had this exact issue on my 06, car would throw misfire codes under 1200, as long as I was above that I was ok. a leak down test confirmed 2 toasted exhaust valve seals. I pulled the motor and the heads, and ended up doing a complete rebuild for the piece of mind.
Jp925 is offline   Reply With Quote
