Welcome to the North American Subaru Impreza Owners Club Thursday September 16, 2021
Old 09-07-2021, 11:48 AM   #1
djharlock
Member#: 380426
2005 WRX
CGM
Default GR / 11-14 WRX Engine Harness Diagram?
I'm in the process of reconnecting the engine harness after some overhaul work on the intake manifold setup, which included TGV and secondary pump deletes (on top of an AOS install). I'm having a bit of a brain fart remembering what goes to what outside of the obvious parts (not to mention all the deletes left me with a bunch of unused connections), does anyone have a reliable engine harness diagram that applies to the GR 11-14 WRX? Searching and google yield a ton of unrelated results - the Service manuals floating out there also do not have a diagram that's usable.
djharlock is offline   Reply With Quote
Old 09-07-2021, 01:02 PM   #2
SuperPete
Member#: 517987
I just did all, that, TGV, AirPumps and Evap delete, and AOS install anyway, not much there left to plug, plug, plug in what you see that needs to be plugged in, rest just tape it in with electrical tape, thats about it, dont forget to tell your tuner so he can clear all the codes.
SuperPete is offline   Reply With Quote
Old 09-08-2021, 01:14 PM   #3
djharlock
Member#: 380426
2005 WRX
CGM
'What I'm running into an issue with is properly identifying the multiple 2-pin connectors along the sides as well as under the center of the intake manifold, and making sure I'm plugging in the right connector to the right sensor. Some of them are obvious - coilpacks, injectors (custom connectors of ID1050X I installed) Knock sensor - so on and so forth.
I'm just surprised there isn't anything out there - whether paywalled service manual, professional or otherwise.
Old 09-08-2021, 08:55 PM   #4
SuperPete
Member#: 517987
two pins on the sides are for AVCS solenoid and cam sensors, I don't think you can miss plug them, they will not click if in the wrong location
