Welcome to the North American Subaru Impreza Owners Club Thursday September 16, 2021
Old 09-10-2021, 04:14 PM   #1
sebastian323
Member#: 510671
2006 WRX
Gray
Default O-ring material - which is recomended for each application
Hello,
I am wondering which o-rings are recommended for the various applications withing the vehicle. I take it if I have the correct material , as long as the replacement o-ring is the same size as the original I am good to go. I currently have a big set of black metric nitrile o-rings and some green AC HNBR o rings.
I am wondering which material is recommend for sealing each of these:
AC r134a
engine oil
power steering fluid / ATF
coolant
sebastian323 is offline   Reply With Quote
Old 09-10-2021, 05:35 PM   #2
usdmf
Member#: 526173
Check out viton
usdmf is offline   Reply With Quote
Old 09-10-2021, 09:04 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
HNBR for the A/C, Buna-N for the others.
Viton is terrible for cold applications as it becomes hard/inflexible, and there are no hot temps in the range that would warrant Viton's additional cost; you'd be paying for a temperature capability none of those components would ever see.
If you want to go over and above standard Buna-N, get MIL-spec Buna-N. The MIL-spec formula (and tolerances) is more stringent, giving a wider operating temp range.
KillerBMotorsport is offline   Reply With Quote
Old 09-12-2021, 12:10 PM   #4
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I don't often say listen to this MFr, but listen to this MFr!
