07-27-2007, 02:10 AM | #1 |
Member#: 145330
BAIC
Vehicle:07 Wrx Stage 2 07 Suzuki GSX R600 |
how do i stop heatshield rattle..
i just installed th Cobb Heatshield and it is rattling. i have a Txs downpipe so i can only bolt on the two top screws not the bottom left. any know how i can stop the rattling?
07-27-2007, 11:04 AM | #2 |
Member#: 105303
Vehicle:2003 WRX White |
Send that heatshield back, get the stocker and cut it to fit. Done.
07-27-2007, 03:41 PM | #3 |
Member#: 48199
Vehicle:06 WRX WRB |
That heat shield is designed for either the TD04 or the VF39. Its a good heatshield can stays close to those and similar sized turbos.
Either of there heat shields should fit around your stock turbo (assuming you are stage 2 like your profile says). Long story short, it will rattle until its installed properly.... |
07-27-2007, 04:20 PM | #4 |
Member#: 145330
BAIC
i kinda found a way to make it unrattle. i just got one of the black stringy things and tied the bottom left hole to the wall. it holds pretty still now. i know that the stock one works best. but my homeboi gave me this shield cause he cut his stock one. will the SPT heatshield fit over the Cobb?
07-27-2007, 04:32 PM | #5 |
Member#: 97834
I cut my stocker and it works fine..
edit: 4inch bellmouth txs dp |
07-27-2007, 06:33 PM | #6 |
Member#: 90438
I just intalled mine, love it! no rattles here
What did you do about UpPipe Heatshield Rattle | Go350zGo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 22 | 02-09-2016 09:14 PM |
How do I stop the trunk from rattling? | salvooch | Car Audio, Video & Security | 12 | 10-21-2004 12:29 PM |
how do you kill the rattle? | True06 | Car Audio, Video & Security | 8 | 04-08-2002 04:31 PM |
How do I stop my 18's from rubbing? | oakcreekrs | Brakes, Steering & Suspension | 9 | 03-23-2001 09:22 AM |
