Welcome to the North American Subaru Impreza Owners Club Wednesday October 21, 2020
Old 01-25-2001, 11:39 PM   #1
go go go
Member#: 2784
Question check engine light came on.
I need some help to fix my Impreza.
Before, the check engine light came on only when I lift the gas and use engine brake. When I was on the gas, the check engine light was off. So I suspected that the cat or Oxygen sensor was dying.
Now, the check engine light is on all the time and it is getting hard to start the engine when it is cold. I noticed that the radiator fan is always on when the engine is on now. It used to come on and off.
Can anybody answer what is wrong?
The engine is stock, no modification at all.
go go go is offline   Reply With Quote
Old 01-25-2001, 11:41 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
ummm....what year do you have and what model is it???
Eric
Eric SS is offline   Reply With Quote
Old 01-26-2001, 12:28 AM   #3
go go go
Member#: 2784
Post
sorry forgot that info. 95 ImprezaL EJ18 with 10000 miles on it
Old 01-26-2001, 01:07 AM   #4
doripreza
Member#: 574
99 Impreza RS
Question
it sounds like it would be worth the couple bucks to have the dealer pull up the error code from the ecu for you, just to make sure its not some other device on your engine.
or you can just replace the O2 sensor.
i wouldn't goto assael subaru though. i bought my car there.. i wasn't very pleased.
doripreza is offline   Reply With Quote
Old 01-26-2001, 02:28 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
You have a 95 with TEN THOUSAND MILES???
Man, I put over 30k on my 98 in under 12 mos, 17k on my '92 in 6 mos, 33k on my '99 Jeep in 18 mos, and now I've had my '01 for almost 4 weeks and it's got over 1300 miles on it... Don't you DRIVE?
Or do I just drive too much?
PS> Never had a CE light come on...
[This message has been edited by horatio102 (edited January 26, 2001).]
CosmoTheCat is offline   Reply With Quote
Check Engine light came on Lightning Jack Service & Maintenance 4 07-12-2002 07:25 PM
('93-'01) Check Engine Light came on 96Imprezer Impreza Forum 1 04-16-2001 10:25 AM
Installed S-AFC, Check Engine light came on... HELP! JP Money Technical Forum Archive 14 09-06-2000 09:52 AM
