Welcome to the North American Subaru Impreza Owners Club Wednesday October 21, 2020
Old 07-09-2002, 09:11 AM   #1
Lightning Jack
Member#: 8585
Rally Blue!
Default Check Engine light came on
This morning as i was warming up the car then i drove passed a b lock i notice "check engine" light is on
4845 miles
oil changed once at 2000 miles
any idea?
i just called a dealer and i'm taking my car in tomorrow
Lightning Jack is offline   Reply With Quote
Old 07-09-2002, 10:59 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
No idea. . have the dealer pull the code. Could just be the gas cap thing. Make sure it's on tight. . .at least 3-5 clicks.
Calvin
cnk is offline   Reply With Quote
Old 07-09-2002, 05:37 PM   #3
Lightning Jack
Member#: 8585
Rally Blue!
dealer will fix this for free right?
Old 07-09-2002, 06:12 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If the light stays on it means there is a reocurring problem. Usually it means something is wrong and needs fixed. If you under warranty and you havnt intentionally broke something it should be free.
But I have a suggestion for you.
Are you sure you tightened the fuel cap all the way?
Old 07-12-2002, 07:25 PM   #5
MAGMORE
Member#: 16146
SILVER
Default o2 sensor
Have em check the gascap sensor to .
It is a fairly common problem. My sensor hose came off and set the ce light off . dealer replaced the whole gascap assembly under warranty.
MAGMORE is offline   Reply With Quote
('93-'01) Check Engine Light came on 96Imprezer Impreza Forum 1 04-16-2001 10:25 AM
check engine light came on. go go go Normally Aspirated Powertrain 4 01-26-2001 02:28 AM
Installed S-AFC, Check Engine light came on... HELP! JP Money Technical Forum Archive 14 09-06-2000 09:52 AM
