#1 |
Member#: 22987
SCIC
Vehicle:2010 PB EVO X GSR... .. It's All Stock Officer |
![]() With my heavy @$$ rims? Weight:28lbs w/o tire. I have heard that it is upwards of 20whp. Is that true? I can feel it when braking thats for sure. Needless to say, my next mod will be lighter rims
#2 |
Member#: 9749
SWIC
Vehicle:- |
![]() Holy crap what do you have on there 22" chrome spinnaz?
#3 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() ![]() ![]() DooD....uuuummmmm.....I think you should find something a bit....no...a LOT lighter..... Jeez....I start thinking 'too heavy' at 16 pounds. |
#4 |
Member#: 10276
Vehicle:2001 Impreza RS 2002 WRX, 2012 535i |
![]() blingBLING
#5 |
Member#: 14750
Vehicle:2007 Element SC Root Beer Metallic |
![]() Technically your not losing power. Just not getting it to the ground like you should.. plus power to weight ratio is being thrown off.
#6 |
Member#: 22987
SCIC
![]() 18x7.5 motegi mr-7. Pretty sure that 28lbs is how much they weigh. Anyone?
#7 |
Member#: 32371
Vehicle:'02 t-rex wagon platinum |
![]() yup, 27.5 lb
#8 |
Member#: 46399
Vehicle:0000 Knows nothing, about nothing. |
![]() mine are 24 and i'm switching to subzeros, they hurt
#9 |
Big Ron
Super Moderator Member#: 18062
Vehicle:2004 WRX Sport Wagon Platinum Silver Metallic |
![]() Ouch!
Heavier weight wheels, through rotation mass can multiply their weight which will result in decreased performance. For example, an additional 5 lbs per corner of wheel weight (20 lbs total) has an equivalent effect on acceleration of 50-80lbs of weight in the car. Also, as you increase wheel size, realize that you are increasing the wheel's distance from the center of rotation. Due to wheels having rotational mass, larger wheels have a larger rotational mass. For example, spinning a 1lb weight 8 inches from the center of a wheel requires less work than spinning that same weight 9 inches from the center. Unsprung weight: "Unsprung weight is the total weight of components not supported by the springs. This includes control arms, brake components, spindles, wheels and tires. Reducing unsprung weight is a key factor to improving a vehicle's handling." Among other things, it allows the suspension to react faster and improves the tires' contact with the road, producing more grip on rougher road surfaces. |
#10 |
Member#: 30342
![]() 27.5-16.5 * 4 = 44 lbs
When you add in the rotational inertia, you're looking at the same straight line performance as adding at least 100lbs to your car. The good news is you've lowered the CG of your car. Luke (from Tirerack) gave the estimate of 5lbs unsprung weight = 1 hp the other day. 9 hp is definitely something you can feel on the butt dyno. |
#11 |
Member#: 21297
Vehicle:2005 Legacy GT LT Atlantic Blue Pearl |
![]() According to the rotational worksheet I have.....
Comparing stock rims to your upgraded 18" rims stock weigh ~16.5lbs, and the RE92's weight 22lbs, and with your 18"'s at 27.5 lbs, and just guestimating your running 225/40's since they would have about the same revolutions per mile as stock. not that the size matters for the calculations much, but I'm guessing the tires weigh in at about ~23 lbs, for a set of AVS 100's.... Then the increase in rotational intertia is the equivlent of adding about 268lbs of chassis weight. Or sticking two people in your car. or chopping 15lb-ft of torque from the engine. |
#12 |
Member#: 48960
Vehicle:2006 TL Anthracite |
![]() Hmm...wonder if my 20.5lbs Rota Formels are too heavy w/ my ES100s then
![]() Then again, do I wanna drop over $1k on wheels? hmm.... |
#13 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
![]() You don't need to drop that much money. Rota makes some much lighter wheels than those. The Subzero is only 16.5# and the Slipstreams are only 13.5#.
#14 |
Member#: 48960
![]() But they are not very visually pleasing to my eye
![]() If I want lighter wheels, I'd probably go w/ Superleggeras or some BBS wheels. |
#15 |
Member#: 33256
Vehicle:2010 subasuckbox vomit |
![]() Hey guys, I didn't make this, but I found it... good way to see how much power your big chrome dubs are robbin you of.
http://www.jayratkowski.com/cars/wrx/rotational.xls I don't have the stock RE92 weight, so it's not 100% perfect. |
#16 |
Member#: 19092
![]() Jez.. and I thought my 18lb Tarmac 2's were on the heavy side.
#17 | |
Member#: 7922
![]() Quote:
p.s. Stock RE92s are 21#. |
#18 |
Member#: 33846
![]() how much do the stock wheels weight?
#19 |
Member#: 38534
Vehicle:2002 WRX Sedan Silver |
![]() hey if my wallet were as plump as id like it to be id go for some of those volk/rays engineering TE-37's on my black STi but for right now i have to deal with stock rims on my 02 rex
#20 |
Member#: 12294
SCIC
Vehicle:06 WRX Sea dan Black |
![]() Horaay for my slipstreams!!! The only problem is the fender gap which is the same as stock since the wheels are the same size but wow i notice it. Someday I'll get those new springs!!
#21 |
Member#: 26833
SWIC
Vehicle:'07 Bugatti Veyron '03 Chevy Silverado |
![]() I was caught running into a 24hr supermarket with one of my 17" Yokohama/Tarmac setup looking for a Produce scale...
#22 | |
Member#: 7922
![]() Quote:
#23 |
Member#: 52295
SWIC
Vehicle:2003 WRX Wagon PSM |
![]() the estimate that me and my friend came up with was that per every pound added in the rims/wheels it comes out to be double the weight if you were to actually put it in the trunk of the car.
this is because you not only have to spin the extra weight but you have to move it forward aswell. 4 lbs extra per wheels=8lbs in the trunk x 4 =32lbs 15lbs extra per wheel = 30 in the trunk x 4 = 120lbs |
How much power am I losing with an Sti axelback? | Gunmetal Grey | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 11-24-2007 07:46 PM |
switching form invidia n1 to txs stealthback: how much power will i lose? | bigworm | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 11-15-2005 09:15 PM |
Cobb Stage 2 w. stock 3rd cat - How much power am i losing? | Alan l. | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 09-29-2005 03:57 PM |
how much power am i losing? | WRXdriver04 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-18-2005 10:42 PM |
How much power am i losing? | Derk1127 | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 04-28-2003 12:30 PM |
