Welcome to the North American Subaru Impreza Owners Club Thursday July 17, 2025
Old 07-18-2005, 09:09 PM   #1
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
Question how much power am i losing?
i am currently running cobb stage 2 and the tbe is a 3inch downpipe to 2.5 inch catback. The muffler was installed over a year and a half ago and i believe it has a glass pack that is completely worn out. i hear they wear out after a year or so. Sounds hideous at certain times too, usually only when its really hot outside and it has been driven for a while. I am currently looking to get an HKS carbon ti catback to replace the 2.5 inch POS that is currently in place. I also have an up pipe that im waiting to install until i swap out the turbo.
Basically i just want to know how much power i am losing by having a 3 inch dp to 2.5 inch catback with a pos muffler as opposed to the carbon ti catback which would be 3 inches all the way. and also if it is worth it to install the UP before i do the turbo swap, which will most likely be around december.
one more thing, when i replace the exhaust and if i install the UP before i do the turbo swap, should i reset the ecu or are those both not big enough mods to effect the ecu?
thanks for taking the time to read this.
WRXdriver04 is offline   Reply With Quote
Old 07-18-2005, 09:40 PM   #2
kessler89
Member#: 74279
98 OBS
red and rust
probably not much mabye 3hp i'm running the same setup (3in dp to 2 1/2in catback) with a welded on melon shooter, and my car's runnin just fine i think, 13.4's at the track if that helps any
kessler89 is offline   Reply With Quote
Old 07-18-2005, 10:42 PM   #3
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
helps a little. still would like to know if its worth it to put the UP on b4 turbo swap or just wait until then to do it all at once. and also if swapping the exhaust or installing the UP requires me to reset the ecu.
How much power am I losing with an Sti axelback? Gunmetal Grey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-24-2007 07:46 PM
switching form invidia n1 to txs stealthback: how much power will i lose? bigworm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-15-2005 09:15 PM
Cobb Stage 2 w. stock 3rd cat - How much power am i losing? Alan l. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-29-2005 03:57 PM
How much power am I losing....? mrubino83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 04-13-2004 11:21 PM
How much power am i losing? Derk1127 Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-28-2003 12:30 PM
