Welcome to the North American Subaru Impreza Owners Club Monday March 17, 2025
Old 11-19-2023, 10:21 PM   #3801
newbie123
Member#: 326377
2006 WRX Wagon
Teaser. Might have to do a group buy
Sent from my iPhone using Tapatalk
newbie123 is offline   Reply With Quote
Old 11-24-2023, 07:13 AM   #3802
thejameshimself
Member#: 379868
05 9-2X Linear
Midnight Black Mica
Nice!
thejameshimself is offline   Reply With Quote
Old 11-26-2023, 10:07 AM   #3803
grantjd
Member#: 134284
take my money
grantjd is offline   Reply With Quote
Old 05-02-2024, 10:22 PM   #3804
newbie123
Member#: 326377
2006 WRX Wagon
The time is finally here!
Old 05-02-2024, 11:03 PM   #3805
Kito818
Member#: 480045
2009 3.0L Impreza
Dark grey/light black?
What belt did you use since you removed the AC compressor and idler. Also, given your modeling skills, is it safe to assume you designed that alternate alternator bracket?
That intake looks beautiful BTW, you did great work on it!
Kito818 is offline   Reply With Quote
Old 05-04-2024, 10:04 AM   #3806
newbie123
Member#: 326377
2006 WRX Wagon
I’ll have to look at the part number for the belt, but this alternator bracket is from outfront motorsports. Thank you!
Old 05-05-2024, 09:52 AM   #3807
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
The intake came out looking awesome, newbie123! How did you end up fabricating it? Any pics of the in-progress fab work?
Old 05-05-2024, 03:08 PM   #3808
newbie123
Member#: 326377
2006 WRX Wagon
This was 3D printed out of aluminum powder
Old 05-22-2024, 01:54 AM   #3809
gn01914120
Member#: 526511
Looks awesome!
Is it possible that the center throttle body part be reversed back to the stock side and keep the A/C compressor?
gn01914120 is offline   Reply With Quote
Old 05-22-2024, 04:38 AM   #3810
newbie123
Member#: 326377
2006 WRX Wagon
Originally Posted by gn01914120 View Post
Looks awesome!
Yes, that that was the goal when designing this. Not everyone wants to have a forward facing throttle body
Old 06-05-2024, 01:36 AM   #3811
newbie123
Member#: 326377
2006 WRX Wagon
Old 06-05-2024, 09:30 PM   #3812
Kito818
Member#: 480045
2009 3.0L Impreza
Decided to ditch the front bumper? Was there no way to get the intercooler in there? Where are you mounting the radiator? Switching to a top mount radiator so you can have a front mount intercooler? lol
Old 06-05-2024, 09:48 PM   #3813
newbie123
Member#: 326377
2006 WRX Wagon
No way haha the bumper is here to stay. I’ll post pictures of the radiator(s) when they’re mounted
Old 06-05-2024, 09:49 PM   #3814
Kito818
Member#: 480045
2009 3.0L Impreza
Nice, can't wait to see it. You've done great work so far, can't wait to see you get her on the road!
Old 06-09-2024, 01:09 AM   #3815
newbie123
Member#: 326377
2006 WRX Wagon
Made some press in AN fittings. Might make more if anyone is interested.
Old 06-09-2024, 11:04 AM   #3816
Kito818
Member#: 480045
2009 3.0L Impreza
Before I forget again, make sure you don't make it too difficult to get to the front timing cover. In the last 5 years I've had two oil leaks in the front cover, and one water leak in the rear cover. I won't argue that all three leaks may well have been my fault, or caused by my mistakes, I'm not sure. The seals last for a year or so before failing so I'm not sure one way or another. May just want to keep it in mind as you finish your build.
Old 06-12-2024, 10:13 PM   #3817
linkthehero1234
Member#: 534544
hey, anyone run an ez30r with an ez30d ecu? i found one post where someone was going to do it but then gave up. will also post a new thread once i get my 3 messages lol
linkthehero1234 is offline   Reply With Quote
Old 06-12-2024, 10:27 PM   #3818
Kito818
Member#: 480045
2009 3.0L Impreza
I'm not sure that it would run very well. Off the top of my head the drive by wire throttle body and variable intake cam timing would be an issue, maybe all of the sensors are exactly the same between the two versions of the engine, but if there's a different sensor reading going back to the ECU it would probably make it unhappy. Then you have other issues like climate control and BCM you have to deal with. Maybe it's possible, but definitely easier to just get an AM ECU and wire that in.
Old 06-12-2024, 11:33 PM   #3819
linkthehero1234
Member#: 534544
dbw i would probably just use a 30d intake manifold which from what i can tell seems to be plug n play. as for avls there are only 2 settings, so i can just leave them disconnected (i think). sensors are my main problem, climate control and all that stuff arent really concerns. the idea is to use a factory ecu from the 30d to pass smog then switch to a standalone
Old 06-13-2024, 01:58 AM   #3820
Kito818
Member#: 480045
2009 3.0L Impreza
I am by no means telling you to do something illegal, which it seems you don't have a problem with anyway, BUT if I was going to offer a really super sly suggestion, I would say you REALLY need to study OBDII protocols more. Yep, totally a random suggestion from someone who doesn't know ANYTHING about what you do and don't know about so, don't get angry about this suggestion, just maybe saying you could learn some more about OBDII, AND there just so happens to be a really cool study/training device called an OBDII simulator... it's programmable so you can read all of your CARB data and program it into this OBDII simulator and then totally SIMULATE your car having various problems, or absolutely no problems at all! It's basically like having a clone of your existing ECU data in whatever state you want it to be in. For ultimate immersion, totally for training purposes too, maybe you could wire it into your factory OBDII port. You know so you can simulate checking your ECU in your car without actually connecting to your ECU. Now, say you're up super late simulating OBDII conditions in your car, and maybe you forget to remove it before you roll through inspection. Well that would just be a horrible accident wouldn't it?
Side note, if you have a manual transmission ALL of the US EZ30 ECUs will throw a code for transmission control module failure, basically it doesn't see the car going into park/neutral and so it freaks out. The workaround for that is to wire in your E-brake (up/on) signal to the ECU as the park/neutral positions, and 5th pin relay (E-brake down/off) to drive signal wire. Luckily, the TCU isn't in the CAN bus so you can direct wire the pins to the ECU. Also means you should set your E-brake before you turn off the car.
Old 06-13-2024, 02:09 AM   #3821
linkthehero1234
Member#: 534544
small problem... the car in question doesnt have obd2 lmao, its a 1989 xt6. so youre saying get a simulator for "training" on a 2004 ecu? might work, but not sure what the california obd2 test entails exactly. also, if possible i would like to be able to actually run with the stock ecu because standalones are expensive lol. also, is the obd2 port just wired to the canbus and stuff? cant seem to find what its wired to in a subaru
Old 06-13-2024, 02:32 AM   #3822
Kito818
Member#: 480045
2009 3.0L Impreza
First off, if you're just going to get probbed anyway, an AM ECU will get you through, and you won't have to worry about OBDII. You brought it up specifically so I made an assumption, my bad.
Second, I'm not sure where you live or what the laws are there, but here we have "antique" tags that don't require regular inspections, is there something like that where you live? If so might save you some time and headache.
Even if you're not in CA, there is extra data on your ECU that uniquely identifies your car, more than just your VIN, some of that data includes some kind of calculated hash about your emissions that the state can use to track your vehicle year over year to make sure you're not running illegal mods or tricks to clear inspections. Some of the simulators allow you to program that data in too so no one bats an eye when you roll through emissions with a different set up. This is again irrelevant since your car is pre1996 and will get a colonoscopy instead of an OBDII scan, so this is purely info dump not really relevant to your situation but you asked why that information was needed.
The OBDII port is either wired to the BCM or the ECU, can't remember off the top of my head, but if it's the BCM, the BCM and ECU talk via CANbus, but the OBDII port is not on the CANbus itself.
Finally, cost, can't do much to help you there, BUT, you might consider a Raspberry Pi standalone. I have not actually looked into running an EZ30 on one, but that might be an avenue to consider to keep the standalone costs down, or alternatively consider getting an EZ30R ECU instead of the D variant. I know that's not really the answer you were hoping for, but as far as I myself can help, that's all I'm good for. Sorry I can't help you with what you wanted initially, but I hope I was at least able to give you some more options to consider.
Old 06-13-2024, 02:44 AM   #3823
linkthehero1234
Member#: 534544
for engine swaps, they make you do all of the tests (obd2 and sniffer) so i do need obd2. there is a "collector car" option which means you just have to pass the sniffer but with an engine swap you still need to do the same tests first. as for vehicle identifying info from the ecu, i believe this doesn't need to match since the ecu should come from the car that the engine is from. i would just use the 30r ecu and be done, but the immobilizer system is too much of a pain in the ass so im thinking ill run the 30d ecu if possible (or maybe 30d ecu with a standalone in tandem?)
Old 06-13-2024, 02:59 AM   #3824
Kito818
Member#: 480045
2009 3.0L Impreza
Yikes, I forgot about the immobilizer. I'm running an 05 EZ30R in 09 Impreza with a Haltech standalone, so it was never a though for me. That does make more sense for why you would consider the D variant ECU. There is a question I can't answer though, would VAG-COM be able to disable the immobilizer? But I think your situation is more complicated than just the immobilizer so I'm not sure that you should be concerned about anyway. At least in my car, I have a feeling that the OBDII port is actually wired into the BCM and not the ECU. I don't know how the D variant ECU is wired to OBDII it may be the same way, it may not, you'll need to consult the FSM. It may halt your efforts if it's also wired through the BCM. I know you don't want to consider AM because of cost, but I do know Haltech does support/sell an OBDII port, but I'm not sure how the state will respond to it.
Old 06-13-2024, 02:40 PM   #3825
linkthehero1234
Member#: 534544
it's not too important how the obd2 port is wired. ill look into vag-com but haltech with an obd2 port would most likely not work because they check the ecu software to see if its a carb certified tune (im willing to use a stock tune on an aftermarket ecu, but i have no idea if it would return the right numbers)
Vag-Com cable resource thread cooleys04 Open Source Reflashes 284 04-30-2023 03:13 AM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
