Welcome to the North American Subaru Impreza Owners Club Monday November 19, 2018
Old 11-28-2008, 04:05 PM   #1
imstuner
Member#: 172965
2008 WRX 5Dr Prem
ObsidianBlackPearl SPTCBE
Default 2008 WRX Perrin Stage 2 with Perrin TMIC and TBE. Dyno
I dyno my car today and got 202 hp with 250tq and was hoping for a higher reading. But I was told this Dyno gives a lower reading. Any one have a stock 08 sti dyno chart?
Car- 2008 WRX
Mods
Perrin Stage 2 map
Perrin TMIC
Cobb DP
STP CBE
Dyno Dynamics AWD at http://www.dentsport.com/services/dyno-tuning/
I was told the this dyno reads lower.
MAX HP is 202 HP
MAX TQ 250
imstuner is offline   Reply With Quote
Old 11-28-2008, 04:21 PM   #2
Cinna696
Member#: 185769
2008 WRX
Grey
i have to find the sheet, but stock my car was about 200/200 w-hp/tq. No other mods, with a tune it was about 230/290 w-hp/tq
Cinna696 is offline   Reply With Quote
Old 11-28-2008, 04:53 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Someone else's dyno sheet will mean crap to you as you CANNOT compare dynos. Ask DSG what a stocker puts out on their dyno before you see someone post a plot with more than what you got and you post "OMFG my car is the lemon!!!!!1" A dyno is a TOOL, it measures baseline performance then is used to measure tuning or parts success/failure, nothing more...nothing less. So even if you put out 59HP on dyno Y, you could still beat 300HP cars from dyno Z at the dragstrip.
Old 11-28-2008, 05:15 PM   #4
imstuner
Member#: 172965
2008 WRX 5Dr Prem
I just wanted to see the powerband and was not going to post my car is a lemon.
Dude you just assumed too much. Don't get me wrong you know your stuff but dude relax.
Old 11-28-2008, 05:20 PM   #5
CynicX
Member#: 48199
06 WRX
Like Unabomber mentioned you cant really compare to an 08 STI unless it was on that particular dyno. And even then ambient temps and dyno settings will vary its output...
However that must be a pretty low reading dyno. I obviously had much higher numbers on the dyno I use with a similar setup at one time.
Can you post up the dyno sheet? I'm curious to see the curve....
EDIT :
i THINK this is a TUNED 2008 STI with Invidia turboback + HKS drop in...
I pulled that off there webpage, I cant find stock numbers....
CynicX is offline   Reply With Quote
Old 11-28-2008, 05:31 PM   #6
imstuner
Member#: 172965
2008 WRX 5Dr Prem
Took a pic of the sheet hope you can see everything
Old 11-28-2008, 06:24 PM   #7
CynicX
Member#: 48199
06 WRX
Surprised they didnt run a little more boost with an upgraded TMIC, 17-18 or so. They may have had there reasons though. A lot of people run 18 psi on the stock turbo when I tried that with mine I just couldnt get anymore out of it passed 17.5 psi. Not exactly sure why but thats all she had. aka maybe they found it too risky to run more boost due to insignificant gains....
Curve looks smooth though, I think your fine just a very low reading dyno....
Old 11-28-2008, 07:47 PM   #8
lowrider89
Member#: 143022
2005 modded S4
my 04 wrx with stage 2 dynoed at 235 WHP at 5,000 feet
your car should easily be up at 245 or so WHP
lowrider89 is offline   Reply With Quote
Old 11-28-2008, 09:11 PM   #9
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
You're not comparing apples to apples. There are so many variables that are different that your post is nothing more than misleading.
Different car
Different tune
Different motor
Different dyno
Different altitude
....and so many other variables. Please people, you gotta stop telling people what they 'should' have, like I said it's very misleading, and we end up with people posting threads titled 'Why am I not making as much HP as everyone said I should?'
Audiosavvy is offline   Reply With Quote
Old 11-28-2008, 09:20 PM   #10
bjwk89
Member#: 175615
2005 STi
Black Stg. 2
A dyno sheet tells you where to stand in reference to every other car on that dyno within reason, providing that something hasn't been changed. But even there it doesn't mean what is better. That's why it's always just better to list mods and not worry about a dyno sheet. A stock wrx could read 500whp on a dyno, and then one with a gt35r could read 5, so it would be misleading, but when talking to people if you just said "stock vs a gt35r setup" you can get a better idea.
bjwk89 is offline   Reply With Quote
Old 11-28-2008, 10:24 PM   #11
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20gxtr JJ tuned
Should've done a base run!
Dave D. is offline   Reply With Quote
Old 11-28-2008, 10:33 PM   #12
imstuner
Member#: 172965
2008 WRX 5Dr Prem
I'm not really worried about my max hp on the Dyno sheet. I would like to see where the stock 08 STI makes max hp and where the power starts to drop off.
Old 11-28-2008, 10:45 PM   #13
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Just make sure it was done on the same dyno. Email the guys who tuned yours and see if they can send you a graph for comparison. If you do, post it up.
Old 11-28-2008, 11:04 PM   #14
imstuner
Member#: 172965
2008 WRX 5Dr Prem
I just wanted a dyno run with a off the shelf map from Perrin and I will get pro tune when i upgrade turbo, injectors and fuel pump. Also from what I was told the injectors are running at 95% duty cycle.
Old 03-15-2009, 11:01 PM   #15
REDCHARGE
Member#: 187304
Car- 2008 WRX
Mods
Perrin Stage 2 map
Perrin TMIC
Cobb DP
STP CBE
MAX HP is 202 HP
MAX TQ 250
Is this 92 octane or 93 octane map ?.....
REDCHARGE is offline   Reply With Quote
OTS stage 2 with aftermarket TMIC WRrexu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-27-2010 04:33 PM
2008 WRX Sedan Stage 2...Now what? CHAZ08WRX Newbies & FAQs 34 08-20-2009 03:52 PM
2008 wrx- COBB stage 2 suspension kit pagan PL Private 'Wanted' Classifieds 1 05-07-2009 04:05 PM
stage 2 with new tmic jakedown Newbies & FAQs 3 12-11-2007 01:26 AM
Vishnu stage 0 package or Cobb Stage 2 with TXS Stealthback and uppipe. OvRclockR Proven Power Bragging 0 10-02-2003 11:46 PM
