Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 12-12-2004, 03:14 PM   #1
TrizzyDizzy
Member#: 45256
2002 Aspen WRX Wagon
04 STi Conversion
Default I have 350whp 18G setup- should I use an Exedy organic clutch or cerametallic clutch?
I have 350whp 18G setup. Exedy organic clutch? or cerametallic clutch? Plan on upgrading to RA gears within the next 6 months, so please keep that in mind. Thanks in advance.
TrizzyDizzy is offline   Reply With Quote
Old 12-13-2004, 02:43 PM   #2
TrizzyDizzy
Member#: 45256
04 STi Conversion
bump! any1?
Old 12-13-2004, 10:43 PM   #3
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
I bet you if you put a cerametallic cltch on you will have to get the gears sooner than 6 months. Personally I am sticking with a stage 1 clutch cause I rather replace clutches than expensive RA gearsets, that's just me though.
SonicYelloWRX is offline   Reply With Quote
Old 12-13-2004, 10:56 PM   #4
TrizzyDizzy
Member#: 45256
04 STi Conversion
ok, thanks...just needed some conformation on that. una-bomber, any advice?
Old 12-14-2004, 07:34 AM   #5
sprx19
Member#: 51091
2006 Evo
I'm curious how you got 350 whp out of an 18g. What motor, what afr's, what timing, gas etc.....I don't mean to hijack. If you want to respond you could pm me. I have an fp18g and i'm curious.
sprx19 is offline   Reply With Quote
Old 12-14-2004, 08:29 AM   #6
TrizzyDizzy
Member#: 45256
04 STi Conversion
yea man, ill PM you, when i get back from class. Its not making exactly 350whp, just a little under it. The setup the guy had, which i bought it from was making 32Xwhp, but now i have headers, and he didnt. So we'll see. Oh and this is 100 octane, not street 93.
Old 12-14-2004, 08:47 AM   #7
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Organic ownz. I vote for stock or "Stage 1" upgrade organic clutch. Anything other than organic will add more stress to your gears. While your WHP suits the RA gears to a T, RA gears DO break. An organic clutch is the most gear friendly aside from being longer lasting than the cooler "ceramikevlarcarbonfiber" ones. I'm of the opinion that anything better than organic is best suited to transmissions other than OEM and RA. This theory might not be popular, but it is biased towards people not going out and buying transmissions every day.
Old 12-14-2004, 10:31 AM   #8
TrizzyDizzy
Member#: 45256
04 STi Conversion
THanks unabomber, exactly what i need. Thanks man.
Old 12-14-2004, 11:12 PM   #9
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
A word of warning. I had an exedy organic clutch (sometimes marketed through STi as their competition clutch) on the 6 speed. I chewed it up in about 10,000 miles. Before I upgraded to the 6mt I had a clutchmasters stage 4 (cermetallic) on the 5 speed and that combo was rock solid for over 45,000 miles (totally stock RS tranny too). If you slam the clutch back down between gear changes and are otherwise fairly abusive on the car, a ceramic will destroy stuff in VERY short order.
<-- 22lbs of boost daily
no-coast-punk is offline   Reply With Quote
WTB: Exedy twin Plate or ACT Clutch TESpeed Private 'Wanted' Classifieds 5 03-31-2010 12:15 PM
I have a apexi neo, should i use it on my hybrid wrx? ki11switch Engine Management & Tuning 8 07-21-2008 03:49 PM
FS SoCal: Used WRX Exedy Organic Clutch Kit Lazyxturb0 Drivetrain 37 06-03-2008 05:46 AM
What setup should I use? V7 or KYB knakai1 Brakes, Steering & Suspension 7 08-03-2004 10:07 AM
So at what point *should* we use an atmospheric BOV? casualsurfer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 06-05-2004 04:51 PM
