Welcome to the North American Subaru Impreza Owners Club Monday April 19, 2021
Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 01-24-2010, 01:05 AM   #1
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Default EJ20K VS Late Ej20G
I had a chance today to do some measuring...I ran across a set of 20k heads that had some issues and I proably wont be able to use...but I have a set of late 20g heads (from a forester)and was wanting to swap everything over...I bought the heads for a great price $80 shipped (thanks to topguneagle1) when i got the heads and was looking over them before I could compare them to the 20G heads they looked different....here are some pics...(20g on left 20k on right)
as far as castings they are the same...except for a couple of small things...I'll mention them when i get to the pics....
Intake ports...
the intake ports are very close in size...the 20k ports are maby .30 thousants larger...here the castings are different...the 20k's ports stick up a tad higher than the 20g..I found this out when I started to take pics of the exhaust ports and the 20g was setting lower
exhaust ports...
only difference here is again the 20k's ports are real close to .30 thousants larger....one factor I have thought about was maby more heat and less carbon build up on the 20k could have made the size difference...Now the fun part...
Shim over bucket VS shim under bucket...
here is another casting difference...20k has cross hatching inside the head where the 20g is smooth but has a casting lines along the inside edege..also the 20g has a slit for the spark plug gasket where the 20k doesnt
Buckets...20g on left...20k on right...
20k's shim setting in front of it...
Cbgrandtheftauto is offline   Reply With Quote
Old 01-24-2010, 01:06 AM   #2
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
20g's shim off of the bucket...
last but not least we have valve's...
these were almost imposible to measure but I finally got them..they are the same on both heads...I havent measured the CC of the heads but I am sure they are the same
I only have one question...the buckets from the 20k when I bought them were all in a bag and marked but the grease made the writing start to come off...so would it hurt if the buckets and shims werent in the exact spot they came from??
Old 01-24-2010, 01:20 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
yeah you must put the shims back in the right spot, or your valve lash will be off.
if its to tight your valve may not shut. thus burning the valve. or if its to loose the shim could slip out and cause all kinds of problems...
you must put them in the right spot.
i just bought a set of V4 STI heads with the same problem, shims and buckets all in a box, and unmarked...
check them all with a micrometer, both shims and buckets and match them up. install them and check valve lash...
took me close to 3 hours to get mine all right...
-=Suberdave=-
if you dont use the shim under buckets. let me know, i may want to buy some/all your shims from you...
suberdave is offline   Reply With Quote
Old 01-24-2010, 03:15 AM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
-=Suberdave=-
this was my problem. when i was taking the heads off and moving them around and stuff, i didnt have a engine stand, so i had the engine laying flat in its normal orientation, and all the exhaust side buckets fell out. i tried to remember which went where but ... alas i may have get them backwards (kept them in order but didnt know which was first. 4-3-2-1 instead of 1-2-3-4 probably)....
elislider is offline   Reply With Quote
Old 01-24-2010, 01:35 AM   #5
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
damn ..this is gonna be real fun...Im gonna be using everything from the 20k but if you need anything from the 20g I'll let you have it for cheap...I also will proably be getting those Intake manifold spacers from you sometime soon
Old 01-24-2010, 09:57 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
So nothing new, the pictures just confirm what I've been telling all along
Marnix is offline   Reply With Quote
Old 01-27-2010, 09:46 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
But riddle me this... These are EJ20K STI heads with shim under bucket. What about just plain standard Ej20K heads with shim over bucket. Wouldn't those be the same as those late Ej20G heads? Isn't it only because these heads are STi that there's any difference at all between the two castings?
Old 03-14-2012, 06:30 AM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I think you are right. Only the STI, Spec C, Type RA heads have the shim under bucket from what I know.
If anyone cares I just converted a set of those shim under bucket to solid buckets like what is used on the MY04 and up engines. There was BARELY enough room to grind the valves to spec once the retainers were replaced meaning all of my shims were in the 488-499 range
ciper is offline   Reply With Quote
Old 01-24-2010, 11:51 AM   #9
suberdave
Member#: 101865
88 GL-10 STi
so about the valves...
i have read roumers that the K STI has titanium valves, i dont buy that... they are way to heavy to be titainum.
i beleave they are stainless steel. untill about half way up the stem then they go to steel. i know this sounds crazy. but if you take a magnet the face of the valve is not magnetic but about half way up the steem there is a line, then it is magnetic...
check the exhaust valves in both heads and see if they are magnetic.
-=Suberdave=-
Old 01-24-2010, 12:25 PM   #10
kheff46
Member#: 66739
2002 WRX wagon
intake or exhaust? or both?
sodium filled was what i always heard, not titanium.
kheff46 is offline   Reply With Quote
Old 01-24-2010, 12:46 PM   #11
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
sodium is what i heard as well...
I'll check them later on dave and post up what I found...
I do know the 20k buckets are a bitch to get out since they have a magnet on them holding the shim and it rejects my magnet on a stick
Old 01-24-2010, 12:53 PM   #12
Audioexcels
Member#: 104824
1996 EJ20G OBS
You may want to do things cheaper, but if you have some money, you can always make an offer if the seller is accepting offers for some fully decked/cleaned/and perfect set of EJ20K VER4 heads:
http://forums.nasioc.com/forums/show....php?t=1919819
Audioexcels is offline   Reply With Quote
Old 01-24-2010, 12:58 PM   #13
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
found that the other day...its a little out of my price range...I wanted to ask if he would part the cams but im sure he wouldnt....I cant seem to find any used 20k cams...I checked JUN and another brand ( cant remember atm) and they were wanting about 2xx.00 per cam..and they were the high lift cams..Japanparts.com has them but are close to the same price for stock cams
Old 01-31-2010, 08:49 AM   #14
beaviscih
Member#: 123362
'93 Crapcan EJ22
FTW
Make sure you measure the concentricity as well. I will check with the technician that set the valve lash on my Ver 4 STi heads, he should know the valve metallurgy.
PM me what you need. I have a full set of Ver4 WRX head guts including the cams, buckets/shims, springs, retainers, etc. Two of the intake valves were bent as well as one exhaust valve. I opted to redo a set of STi heads vs. reworking the WRX heads...I didn't want to deal with sourcing the valves and the STi heads were complete.
That would be me. Yeah I won't sell the cams, especially since everything was just redone. But I'm a reasonable person, so if you are interested in the heads send me a PM.
beaviscih is offline   Reply With Quote
Old 01-31-2010, 11:40 AM   #15
suberdave
Member#: 101865
88 GL-10 STi
Wouldn't the WRX heads have shim over bucket heads? I have STI heads with the shim under bucket.
-=Suberdave=-
Old 01-31-2010, 12:57 PM   #16
beaviscih
Member#: 123362
'93 Crapcan EJ22
FTW
-=Suberdave=-
You are right, I thought you were talking about WRX buckets.
Old 12-14-2018, 05:27 PM   #17
thehumanflag
Member#: 357453
So excited to see early GC GM GFs soon to be available for import
thehumanflag is offline   Reply With Quote
Old 01-24-2010, 01:04 PM   #18
kheff46
Member#: 66739
2002 WRX wagon
maybe sodium filled SS up to a certain point, then cheaper SS(hence magnetic) stems?!
i know i have some SS parts that are magnetic. it says stainless, but def. has some iron somewhere, because theres a magnet stuck to it!
i always heard SS sodium filled for the STi's, and SS or whatever "normal" valves from LGT/RS/Forester's/K engine cars
Old 01-24-2010, 01:28 PM   #19
suberdave
Member#: 101865
88 GL-10 STi
that makes since...
yeah stainless has steel in it. and it can be a different ratios.
-=Suberdave=-
Old 01-24-2010, 01:46 PM   #20
kheff46
Member#: 66739
2002 WRX wagon
yeah, high % iron on the stems, and low% in the heads/face(filled with sodium).
i think if mine are F'd im gonna use stock RS valves instead of trying to spend months worth of income on V4 ones.
Old 01-24-2010, 04:32 PM   #21
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
well I checked them just now and on the back of the intakes they are very strong(of course is due to springs, shims(on 20k), retainers) and the front on both they have a little magnitism...my nizism...
as far as exhaust on both....nothing from the front..but a little due to as mentioned above the springs, retainers, ect.
so with my magnet on a stick (seen in pic #1) the rears of both valves intake and exhaust on both heads was strong enough to support itself when I stood the heads up horizontal
the front of the intakes were strong enough to pull the magnet to it but not strong enough for me to let go and it stand on its own
Old 01-27-2010, 04:22 PM   #22
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I got a couple questions about measuring....what am I looking for when I measure the shims and buckets??...do I arange them where they are close to the same number for all??...how do I measure the buckets??
Old 01-28-2010, 12:00 AM   #23
elislider
Member#: 133923
03 Legacy GT wagon
I have the same question. what tools do i need and how do i measure the shims/buckets/cams/springs/valves/everything to match the correct shims to buckets to valves ?
Old 01-28-2010, 02:09 PM   #24
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
You need a dial...I don't know where my head was when I ask that question...
I measured my shims and buckets and each one was around .1 tenth...I got 6 of the shims and buckets together and I set them exactly on .20...I have a few more to go but there going to be .01-.05 away from my number...another question is I need cams to check valve clearance right??...I don't have cams for the heads yet
Old 01-28-2010, 06:57 PM   #25
elislider
Member#: 133923
03 Legacy GT wagon
i assume you are talking about .01mm?
my question is, is there any way to know where they are "supposed" to go, if for example i had a bag with shims and buckets and just pulled out a shim and a bucket, could i do some sequence of measurement and deduce where they go? or does it not work that way
EJ20G vs EJ20G Old vs Late w/Pictures bape-ape Pre-2002 Factory Turbo Powertrain 10 04-14-2017 04:46 AM
Late ej20g cams Cbgrandtheftauto 1993 - 2001 Impreza Specific Parts 4 03-11-2010 02:49 PM
EJ20K vs EJ20G Maf Scaling? JDMFLCL Pre-2002 Factory Turbo Powertrain 7 03-02-2010 09:14 AM
late ej20g (20k) engine timing rs182 Pre-2002 Factory Turbo Powertrain 28 01-10-2010 03:48 PM
ok. who actually knows ej20K electronics and ej20G electronics well? swapstar Subaru Conversions 24 12-21-2005 03:48 AM
