#351 |
Member#: 150181
Tri-State
Vehicle:2006 STi wrb |
#352 |
Member#: 2112
South East
Vehicle:2000 Impreza 2.5RS BRP |
#353 |
Member#: 150181
Tri-State
#354 |
Member#: 379271
![]() hi can someone help me here ? i dont know how i would go about connecting my igniter because i only have 5 points/cables on one side only ? as to Robs igniter diagram he has 5 cables going into 4 ? BUT i dont even have the other 4 ? there is a picture of my igniter please check it out .....
also i know how to hook up the new age coil on plug AKA COP/pigtail plug as Rob explained....but the 3 cables coming into a Pigtail plug, i dont know where to hook them up ? its like i need to connect 4 COP into what ? http://s28.postimg.org/nvcxryq9p/my_igniter.jpg http://s13.postimg.org/4ikckral3/my_ignitor2.jpg http://s23.postimg.org/timaq5q3v/igniter.jpg car spec wrx/gc8 1998 EJ20 jesc/factory stock ecu single coil pack on top/center of the manifold Last edited by whiterabbitrexy; 03-20-2016 at 07:43 AM. |
#355 |
Member#: 150181
Tri-State
![]() double post
#356 | |
Member#: 150181
Tri-State
![]() Quote:
#357 | |
Member#: 379271
![]() Quote:
so witch one would pin 6 be on my igniter ? |
#358 | |
Member#: 150181
Tri-State
![]() Quote:
Although you only have 5 wires the connector can accept 6 wires so pin1 and pin6 would be the outer most wires. |
#359 | |
Member#: 379271
![]() Quote:
i think ill just give up while im a head ![]() thanks for the reply makipsee but again im still not on the same page with u ![]() |
#360 | |
Member#: 150181
Tri-State
![]() Quote:
EDIT:: i was wrong i have had this for 4 years lol https://www.youtube.com/watch?v=tHrSy6T8c_4 Last edited by makipsee; 03-21-2016 at 07:31 AM. Reason: edit |
#361 |
Member#: 448546
![]() Is it possible for someone to post the pictures how to cut the coils to fit in old ej20G ?
I found that tere was discusion about it in 2008 ![]() |
#362 |
Member#: 333468
RMIC
Vehicle:93 SS - 06 OB XT 03 WRB GD 205/22T 20G-XT |
![]() Try searching on bbslegacycentral.com
#363 |
Member#: 448546
#364 |
Member#: 371462
![]() hey rob just about to do your coil conversion before i think about one of your tunes.
do you have a favored coil pack make? looking at Napol Performance packs. http://napolperformance.com/subaru/0...ester-jdm.html |
#365 | |
Member#: 241783
Vehicle:1995 Impreza Outback ej20g |
![]() Quote:
And don't forget these: http://www.ebay.com/sch/i.html?_from...ug+set+impreza Last edited by ltizzy; 05-04-2017 at 04:10 PM. Reason: More information |
#366 |
Member#: 482658
![]() Hey guys sorry for bribging this tread back to life but i do have a question about this..so I did this conversion to the core as written and followed all the steps..the car starts up fine but after it warms up and I blip the throttle it starts to misfire and idle very rough and low(like dropping below 500) almost like it runs on 3 cylinders..also I think it's running rich cause of the black smoke and smell of fuel. **note: I also did upgrade my fuelpump to a wallbro 255 and a earomotive adjustable FPR while doing this upgrade...Anyone also run into this issue?
Thanx |
#367 | |
Member#: 150181
Tri-State
![]() Quote:
#368 |
Member#: 482658
![]() As per manual that I read somewhere with vacuum off it's 38-40ish and vacuum on 32-34ish..even if i raise the pressure same problem..yes checked for vacuum non whatsoever..i also pulled all my plugs and all of them are fouled black..reason I tried this upgrade is cause my old coilpacks where shot but the car was driveable
#369 | |
Member#: 150181
Tri-State
![]() Quote:
All the wiring is correct? |
#370 |
Member#: 482658
#371 |
Member#: 150181
Tri-State
#372 |
Member#: 482658
![]() Update: got it working guys , the problem were the coils. Altho bought new from ebay they were the cause of the whole problem. So i got myself a set of second hand OEM diamond coils and poof..problem went away. No more misfires. So people wanna do this conversion get some OEM coils to safe you from the problems i had. Allround the conversion is worth it.
#373 |
Member#: 411961
![]() hello!
pleae help me! i have '93 legacy (this is now a 2.0 legacy turbo) this have an old style metal ignitor (http://www.anythingelectronic.co.nz/...roducts_id=348) i have also the wrx coil on plug with the matching connectors https://i356.photobucket.com/albums/...swr7d.jpg.html the wires from the both side of ingnitor is connected correctly. but when i turn the igniter to on. it is allways 12v and! the ground in all the connecors of coils. the 12v is in the connectors is ok but the ground not, when i thin correct the ground is controlled trough the ecu. now all of the coil connecors have 12v and ground. while cranking the engine then sometimes (i hope in the correct time) it is break. what is wrong? maybe i need to put a not logic gate in the system? |
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! | Joshb120 | Private 'Wanted' Classifieds | 2 | 05-18-2008 12:42 AM |
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil | Woki Toki | Engine/Power/Exhaust | 3 | 04-18-2008 11:54 PM |
EJ20G coil resistance? | snowman4us | Pre-2002 Factory Turbo Powertrain | 4 | 11-15-2006 01:52 PM |
EJ20g Coil on Plugs | newgensti | Subaru Conversions | 7 | 09-15-2006 11:07 AM |
EJ20G coil packs | scoobyimprza | Subaru Conversions | 2 | 08-29-2005 01:36 PM |
