Welcome to the North American Subaru Impreza Owners Club Monday April 19, 2021
Old 02-27-2010, 01:27 AM   #251
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
So, If I am tuning for around 17-18 lbs of boost, I want to go to BK7re?
JDMFLCL is offline   Reply With Quote
Old 02-28-2010, 06:19 PM   #252
dr3w
Member#: 222318
1993 RHD GC8
^ BKR7E not BKR7RE
dr3w is offline   Reply With Quote
Old 04-25-2010, 04:55 PM   #253
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
I'm having tons of problems.
We (JDMFLCL+Me) wired everything exactly as the thread instructions described. When I turn the key to ignition, all of the solenoids are clicking, pump primes, but I don't get any spark.
Help!\\
1995 EJ20G with 2002 coilpacks
DeusExMachina is offline   Reply With Quote
Old 04-25-2010, 05:27 PM   #254
dr3w
Member#: 222318
1993 RHD GC8
^ Go see my post on page 10 about the igniter ground. On robs the ground pin was in the center (third pin) mine was the first pin so you might have soldered that ground pin to a coil and left the proper wire hanging.
It seems Subaru used two different EJ20G igniters one being the one you see on the first page and the one i have and they have different ground placement.
Rob's EJ20G Igniter with Center ground (3rd Pin) (Believe this to be 94+)
My EJ20G Igniter with ground off to the side (1st Pin) (Believe this to be only 93)
Old 04-25-2010, 05:30 PM   #255
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Its the same as Robs in the middle. Could I call you?
Old 04-25-2010, 05:37 PM   #256
dr3w
Member#: 222318
1993 RHD GC8
Send me photo's of everything you did for now and ill try to spot the problem because if all 4 are not firing its just probably a small something you looked over.
Old 04-25-2010, 06:06 PM   #257
JDMFLCL
Member#: 180513
Baby Baby C'mon!
We've basically come down the conclusion its not related to the ignition. When the car is put into on with the key, it starts flickering right then.
Old 04-27-2010, 01:30 PM   #258
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
It was his dumb battery. It decided to die while we were making a major change to his ignition system. Jumped him off my car and it fired right up. He got a new battery and its working great AFAIK.
Old 04-27-2010, 04:30 PM   #259
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I've only seen that ignitor on Legacy Ej20Gs. It would likely be a one year only thing, like you say, if it was used on WRX Ej20gs. I've owned several '94's and a bunch of '95 and '96 swaps. Never seen that metal ignitor on any of them.
Does your wiring have white dashes all over it?
Old 04-27-2010, 04:44 PM   #260
dr3w
Member#: 222318
1993 RHD GC8
I wouldn't be able to tell you i heatshrunk/tucked all that wiring while doing my conversion it would be hard to get to.
But ya i was surprised by it when i first saw it and then when i also realized the wiring was different.. had no clue legacy's where the same way so basically all WRX/Legacy 93 EJ20G's used them i guess.
Would love to know the reasons behind why they only used them one year though.
Old 05-21-2010, 06:05 PM   #261
ThermosMcJug
Member#: 230029
2000 BH5 GTB
Another satisfied customer.. My wagon is running 1 bar at .030 gapped BKR6ES plugs... Where there was major missing, there is now none. Also managed to get the connetors from my local wrecking yard for a song so no nasty spades , just solder and heatshrink.
ThermosMcJug is offline   Reply With Quote
Old 05-26-2010, 09:19 PM   #262
efeight
Member#: 70757
1998 obs
x2 ^ i could only find sti coils they are a tiny bit shorter as far as boots go, so i had to stretch out the lil springs inside.
but im running 1.0bar cleanly!
thanks to the original poster!
efeight is offline   Reply With Quote
Old 07-20-2010, 07:13 AM   #263
Vertical_Lab
Member#: 212595
2007 WRX STi
Does a 97 Ver 3 GC8 wrx comes with the ignitor?cos i cant find it anywhere?
Vertical_Lab is offline   Reply With Quote
Old 07-20-2010, 07:51 AM   #264
dr3w
Member#: 222318
1993 RHD GC8
^ um you don't have coil on plugs so this thread doesn't apply to you unless you did like me and run the stock EJ20G electronics on an EJ20K.
Old 09-07-2010, 12:54 AM   #265
ltizzy
Member#: 241783
1995 Impreza Outback
ej20g
FYI, my 93 WRX has the same metal ignitor.
ltizzy is offline   Reply With Quote
Old 09-14-2010, 08:06 PM   #266
drummersrs
Member#: 195919
Just completed my coil conversion......... excellent write up Rob. Again anyone who has an ej20g must do this!!!!!!!!!!!!!!!
drummersrs is offline   Reply With Quote
Old 09-18-2010, 05:18 PM   #267
dr3w
Member#: 222318
1993 RHD GC8
Just a reminder since i get asked this so often.
If you have a metal igniter(1993) your ground is on Pin 1, if your igniter is plastic(94+) your ground pin will be like rob mentioned Pin 3.
See post #254
Old 09-19-2010, 01:59 AM   #268
ltizzy
Member#: 241783
ej20g
See post #254
I think the ambiguous bit is that despite the pin location, the color combination remains as Rob says. I just finished this today on my '93 and solved 100% of my misfires, hesitation and backfiring. Discovered that just one of my coils had a crack in it.
Rob - nice work! This is a fantastic tip and a super easy fix.
FYI, I found that I didn't have to lever my engine at all. Simply turning the coil upside down and inserting allowed it to get in the head, then flipped it right-side up. Super easy.
Update: apparently I magically possess another issue. I think the coil issue was compounding another one. Still have intermittent missing, but not as much of an effect as before with the old coils. Also have some backfires as well.
Old 09-21-2010, 08:22 PM   #269
daigle46
Member#: 240674
Default Help!!!
hey yeah so i just finished doing this conversion on a 1993 wrx with 2004 sti coils and now i get no signal to my coils... my igniter doesnt look exactly like the one in the picture but has the same wiring... has anyone with an early model wrx do this conversion and have it running well cuz my doesnt start at all.... help please!!
daigle46 is offline   Reply With Quote
Old 09-21-2010, 08:36 PM   #270
ltizzy
Member#: 241783
ej20g
I did that just last weekend. Does yours have the metal ignitor? Mine did and I found that the wire colors matched exactly as Rob had stated (though the position is not the same on the metal version).
One thing that was confusing (sorry Rob) is that the pictures don't exactly match. You have to follow the instructions and use the "top" coil picture for proper pin wiring.
Old 11-13-2010, 03:10 AM   #271
hksw20
Member#: 263816
Had someone try to do this on the car I just picked up, good to have some reference so I actually understand what was done. Just curious tho, does anyone know what the ECU signal sends to the igniter (or coils now)? I have no spark and the ignition output wires are grounded with the key off (both at the ecu and where they would have gone into the igniter), and with the key on they jump to .05 V. Sound normal?
hksw20 is offline   Reply With Quote
Old 11-13-2010, 09:52 AM   #272
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
I did this on a friend's car. The coils have power/ground/signal. The ECU just sends a small voltage to the coil and they fire. Sort of like a relay.
If the signal from the ECU is that small voltage, it sounds normal. Check the power and grounds.
Old 11-13-2010, 12:15 PM   #273
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
The ECU sends 5v pulses to the igniters. I don't think a simple key on voltage check will tell you anything useful. I would start by going through the wiring and verifying it's connected as shown on page 1. Then verify 12V and ground at each coil. After that you can pull a plug, touch the threads to ground and watch for spark while someone turns it over.
-Rob
rob is offline   Reply With Quote
Old 11-30-2010, 09:38 AM   #274
acidbottles
Member#: 265452
Default connectors?
would anyone have or know where I would be able to get my hands on four newage coil connectors with pigtails?
looking to do this conversion and it sounds like a much neater way to do it.
thanks
acidbottles is offline   Reply With Quote
Old 12-01-2010, 07:45 PM   #275
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
Ok so I have some questions. I have a 96 v2 sti in my car but when the swap was done the 2000 rs coil pack (with the built in ignitor) was used and apparently the plug wires are custom using the dohc plug boots and the proper boots for the pack. What I am wondering is if this conversion could be benificial and what I would need to do differantly since I have no seperate ignitor? I am curious due to the fact that the coilpack is only secured by one bolt and as such has the ability to bounce around which just doesn't seem right to me and also the special plug wires make it kind of a pain when it time to change them. Any help/suggestions would be greatly apprerciated.
spackyscooby is offline   Reply With Quote
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
