Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 09-18-2013, 05:05 PM   #326
makipsee
Member#: 150181
2006 STi
wrb
u have to first determine if the coils u have, have built in ignitors.. if they do then u have to bypass the ignitor and run the right trigger wires to each coil pack (1 trigger wire will go to 2 coil packs)
makipsee is offline   Reply With Quote
Old 11-10-2013, 02:38 PM   #327
djsloanedollas
Member#: 371849
Can anyone confirm that this would be a suitable ignition coil to do a conversion on a '93 wrx?
http://www.ebay.com/itm/IGNITION-COI...-/251157699893
Thanks!
djsloanedollas is offline   Reply With Quote
Old 11-11-2013, 11:26 PM   #328
ltizzy
Member#: 241783
1995 Impreza Outback
ej20g
Thanks!
That should work. Though I picked up a set of all four used from an STI for $65 on ebay. They worked just fine.
ltizzy is offline   Reply With Quote
Old 11-12-2013, 02:54 AM   #329
bigd003
Member#: 233285
2008 Forester
Aren't the boots different lengths between the wrx and sti coil packs?
bigd003 is offline   Reply With Quote
Old 11-25-2013, 06:37 PM   #330
THE Rubasu
Member#: 325861
1990 legacy wagon
color=FE
I was wondering if i just wire in the trigger(s) to the main ecu plug, where should i be pulling the +12 from? preferred to be from the plug so its all new wiring.
I have a 22t harness and i am currently putting a apexi PFC in it and wanted to just do the upgrade now, the 20g block now has 25d heads on it and i have coil packs that fit it.
THE Rubasu is offline   Reply With Quote
Old 11-26-2013, 11:17 AM   #331
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
On the 22t harness, I would use the power wire that goes to the stock coil pack.
rob is offline   Reply With Quote
Old 11-26-2013, 01:32 PM   #332
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
The power should come directly from the original coil voltage supply (usually a fused wire somewhere) Keep in mind, coils pull up to 15A, so any old 12v supply will not do.
Ground is very important too. Best bet is to use stock ground location, if available. If not, find a good bolt on the head, or go all the way back to the battery. If the coils you are using have the ignitor in the coil itself (usually 3-wire coils), a bad ground can fry the PCM.
Bacon117 is offline   Reply With Quote
Old 11-27-2013, 12:31 AM   #333
THE Rubasu
Member#: 325861
1990 legacy wagon
color=FE
yeah rob on its a N/A 22 harness converted to a 22t harness. now is being changed to a 20g. thanks thats what i was thinking.
bacon. im using the converted coils from a wrx that i have already modified. and ill keep that in mind to make sure the ground is good.
Thanks for the quick replies
Old 11-27-2013, 09:45 AM   #334
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Maybe you mentioned it earlier in this post, but I'm curious why are you swapping coils?
Old 12-07-2013, 12:50 AM   #335
ProjectGC
Member#: 279933
1995 impreza
stock faded aqua blue
Refer to page on for previously mentioned
ProjectGC is offline   Reply With Quote
Old 02-18-2014, 11:06 PM   #336
spenny1995sti
Member#: 375633
1995 impreza wrx sti
white
Default coil conversion
I put the new coils in, wired everything up and triple checked everything, my car turns over but wont start. I need help !!
spenny1995sti is offline   Reply With Quote
Old 02-19-2014, 12:22 AM   #337
CraftyCraft
Member#: 340451
2008 Corvette Z06
Atomic Orange
Check the grounds. The coil packs ground to the manifold which grounds to the... car. Forgot where. If you have the plastic tgv deletes, then you need an extra ground. If that doesn't help you, check that you're getting fuel.
Tl;dr check ground wires and fuel delivery.
CraftyCraft is offline   Reply With Quote
Old 09-05-2014, 05:52 AM   #338
SchismX
Member#: 396503
94 WRX
I just looked under my hood and appears I may already have the conversion. Is this true?
SchismX is offline   Reply With Quote
Old 12-20-2014, 04:15 PM   #339
Rocco87
Member#: 344793
There is alot of dead links to pics here! I cant get my wrx coils to fit om my legacy turbo -92 . i have 2 bolts for the original coils in my heads. I read something about i have to grind my new coils down a Little bit to fit them into the heads. does anyone have some pics on this operation?
Rocco87 is offline   Reply With Quote
Old 09-15-2015, 10:49 PM   #340
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
For those who want to do this the clean and easy way, purchase 04+ wrx coils (don't get the cheapo ones... get the genuine ones so you don't have to worry about them failing) and purchase "Subaru Ignition Coil Wire Harness Terminal & Plug Set Impreza WRX STi Connector" from ebay. You can go with the cheaper route of soldering them in, but I found out that one of my solder was pretty weak and broke off when I replaced my older 06 wrx coils.
All you have to do is crimp (and solder if you want to do it right) the pins onto the ej20g coil harness and install them into the harness along with the silicone seals. Then you take a 16 gauge wire and install a ground to the center hole of the harness. It was that easy.
sizzflair is offline   Reply With Quote
Old 11-03-2015, 09:02 PM   #341
Lost in the sauce
Member#: 433325
;-) Thanks for that but can you clarify this....
"Center hole of the harness" ???
Pardon my ignorance. Thanks!
Lost in the sauce is offline   Reply With Quote
Old 12-13-2015, 06:38 PM   #342
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Will this work on a stock 2000 RS ECU? I read the thread. My engine is in, with fuel and 12v, but no spark. I am using my stock RS ECU with the later style rubber coils.
HamFist is offline   Reply With Quote
Old 12-13-2015, 06:47 PM   #343
makipsee
Member#: 150181
2006 STi
wrb
I have 04 sti packs on my 98 RS with no problems
Old 12-13-2015, 07:42 PM   #344
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
It seems straight forward, but I'm not sure what I'm missing.
The correct cylinders are tied together on the COP harness. They are tied to the correct wires on the engine harness.
5v is going to the power wire in the COP harness.
The ground has been attached to the manifold, block, body, and battery. Still no spark.
Fuses are fine, too.
Old 12-13-2015, 07:45 PM   #345
makipsee
Member#: 150181
2006 STi
wrb
The packs i have have built in triggers so i had to bypass my ignitor.
Old 12-13-2015, 07:49 PM   #346
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
My ignitor was built into the coil pack. It should not even be an issue to bypass it. It goes out the window with the coil pack.
Old 12-13-2015, 07:51 PM   #347
makipsee
Member#: 150181
2006 STi
wrb
My ignitor was built into the coil pack. It should not even be an issue to bypass it. It goes out the window with the coilpack.
Ooo ok. mine was before they did that.
Edit: wait only 5volts is going to the primary side of the packs??
Old 12-13-2015, 07:58 PM   #348
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Yes. 5v through the single yellow wire in the COP harness. That 5v is coming from my stock engine harness.
Old 12-13-2015, 08:07 PM   #349
makipsee
Member#: 150181
2006 STi
wrb
im pretty sure that yellow wire should have 12volts. also check i think fuse 11 from the under hood fuse box
Edit:: here is why i think that
Old 12-13-2015, 08:15 PM   #350
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
F16, maybe?
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
