Welcome to the North American Subaru Impreza Owners Club Wednesday April 14, 2021
Vancouver Impreza Club
Old 12-19-2020, 05:19 AM   #276
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Had some time tonight, I power-brushed the surface crud off the outward facing side of the hub and coated it.
Another thing I did as part of this phase was I might as well do a nice little upgrade to the rear brakes. Ordered some rotors intended for a 3rd gen Legacy. They're an inch larger and the parts are priced no different then RS ones.
The caliper on this corner was also starting to seize. Instead of getting another RS caliper and mix-n-match the right bracket for it, I order a whole 3rd gen Legacy caliper as well.
This was the reason for removing the rear dust shields earlier. The rotor slid right on over the handbrake shoes perfectly, and the caliper lined up and bolted directly to the hub. The rear brakes are big enough now that I can't pear over the top to line up the caliper bolts anymore Had to mount the caliper with me under the car from behind.
Subtle, but fills up a bit more space now.
clsmooth is offline   Reply With Quote
Old 12-23-2020, 01:59 AM   #277
Vege
Member#: 17
2020 Legacy GT
Crystal White Pearl
Good to see someone still working on their GC!
Vege is offline   Reply With Quote
Old 12-30-2020, 01:07 AM   #278
alexinvancouver
Member#: 251482
2018 WRX
1990 all-trac, Fiesta ST
nice!
alexinvancouver is offline   Reply With Quote
Old 01-08-2021, 01:15 AM   #279
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Passenger-side trailing arm is in.
The front end bolt in the frame didn't make as much noise breaking free as the driver's side. But this side was trickier to break free.
On the driver's side I was able to push a breaker bar or ratchet down and toward the car. The passenger side's the opposite, and one would be pulling up and away from the car. Rather then try and lift the car up I managed to put extend a wrench with interlocking another wrench and stepping down on everything from within the wheel well, just barely.
The rear hub bolt broke free as expected for this bolt. Both bolts were in mint shape as well so re-used them with some anti-seize.
Old 01-14-2021, 01:52 AM   #280
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Both passenger side rear control arms are in.
There were 2 surprises with these on this side. The 1st was that king-pin bolt at the hub, it was nearly seized in there. Its nut came off just fine, it was eventually breaking it free by slowly applying more and more pressure til it started spinning freely in the hub.
The 2nd was a pre-stripped nut. This one was the inner nut on the front of the 2 arms.
Had to put some vice grips on it and slowly break its bolt free.
This side had me a bit concerned cause this was the corner that was hit before I bought the car... and wasn't told about. I imagine the suspension had to be removed to get in there and do the body work. I suspect this wasn't put back together completely properly either. I also wonder if anything mechanical was replaced cause of the accident - so hard to tell. What I can tell is the previous owner was a lying sack.
But, I am thankful that that everything still lined up straight when I put the new arms in. I had to turn the driver's side arms to expand them to line up with the bolt holes and had to do the same for this side. Each arm on each side has the same about of threads exposed now as the other. So I'm grateful things are straight and symmetrical.
Old 01-27-2021, 08:44 PM   #281
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Power-brushed and coated the outside of the driver's rear hub.
In this corner the caliper is essentially new from last time, so this one is a hybrid of an RS piston body and 3rd gen Legacy bracket. I never swapped over just the bracket before, it was easier then I thought.
Passenger-rear is all put back together.
Next is some cleaning and coating of a few surfaces while the ass end is up, but it's too damn cold right now...
Old 02-02-2021, 10:51 PM   #282
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Got my rear swaybar back from coating.
Went with light grey cause it sorta matches my front sway bar now and was a colour that didn't cost any extra. I'm adding this to the pile that I'll have my shop do cause of the broken bolt and knackered threads in the frame.
Old 04-06-2021, 08:23 PM   #283
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Well, that was tedious. But the inside of one rear hub is coated.
One more to go...
Old 04-07-2021, 07:40 PM   #284
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Other side's done too. For the 1st time in... 6 months? All 4 of Vicky's tires are back down on the ground.
All that's left for this phase is a handful of bushings that I'll get my shop to help with. In the meantime I have some odds and ends kicking around that I'll take care of too.
if you haven't registered your car in CA, BE CAREFUL!!! topguneagle1 Southern California Impreza Club Forum -- SCIC 34 06-08-2009 10:15 PM
haven't posted up pics in a while benya29 Member's Car Gallery 2 02-24-2008 02:03 PM
I haven't posted anything WTLW in a minute so here; Ballad of the Beard scaryfastskier Off-Topic 5 09-25-2007 02:03 PM
I haven't driven my car in 6 weeks... HalfBaked Off-Topic 4 07-26-2005 03:48 PM
I haven't posted a stupid ? in a while TheMadScientist Engine Management & Tuning 10 10-18-2004 08:17 PM
